Cuts-Out & Misses Diagnostics¶
- Cut-out and misses issues occur when the engine begins jerking that follows engine speed, usually pronounced as the engine load increases but normally felt below 2,000 RPM. The exhaust has a steady spitting sound at idle, low speed, or hard acceleration for the fuel starvation that can cause the engine to cut-out.
| Checks | Action |
| Preliminary Checks | N/A |
| Ignition System Checks | 1. Start the engine. 2. Check ignition for proper voltage output with a spark tester. 3. Check for any cylinder misfires. 4. Verify all spark plugs are gapped correctly. Remove all spark plugs and check for the below conditions: - Burned electrodes - Any and all deposits - Improper spark plug gaps - Any and all wear and tear Check the secondary ignition for the below conditions: - Ignition wires for arcing and proper routing - Ignition coils for any cracks and carbon tracking - Cross-firing |
| Engine Mechanical Checks | Perform a cylinder compression check for all cylinders. Check all cylinders for the following conditions: - Worn rocker arms - Worn camshaft lobes - Broken valve springs - Improper valve timing - Improper valve clearance |
| Fuel System Checks | Check the fuel system for the below conditions: - Low pressure - Plugged filters |
| Additional Checks | Check the routing for the secondary wires and their ground circuits. |
