Hesitation Diagnostics¶
- Hesitation is when the engine has a lack of response when putting it under load, this condition may cause the engine to stall if severe enough.
| Checks | Action |
| Preliminary Checks | N/A |
| Fuel System Checks | - Check the TMAP sensor response and accuracy - Check fuel pump |
| Ignition System Checks | - Check for proper ignition voltage output - Check to see if the proper OEM spec spark plugs are being used and are gapped correctly - Check for faulty spark plugs wires - Check for fouled spark plugs |
| Additional Checks | - Check for proper alternator voltage output - Check for proper manifold vacuum |
