Intermittent Diagnostics¶
- Intermittent issues may or may not turn ON the check engine light or store Diagnostic Trouble Codes (DTC).
| Checks | Action |
| Preliminary Checks | Do not use the DTC table. If a fault is intermittent, the use of the DTC tables with this condition may result in the replacement of a good part. |
| Faulty Electrical Connection & Wiring | Faulty electrical connections or wiring can cause most intermittent problems. Check the suspected circuit for the following conditions: - Faulty fuse or circuit breaker - Connectors poorly mated - Terminals not fully seated in the connector (backed out) - Terminals not properly formed or damaged - Terminal tension is insufficient - Wire terminals poorly connected - Examine any and all potential terminals for proper contact tension |
| Operational Test | Once all visual and physical examinations do not locate the problem, operate the vehicle with VCM Live and watch for any abnormal spikes in voltage with the corresponding parameter. |
| Loss of DTC Memory | To check for the loss of DTC memory perform the following: 1. Disconnect any sensor 2. Idle the engine until the check engine light illuminates 3. VCM Live should store a DTC for whichever sensor was disconnected and remain in memory when the ignition is turned OFF. If no DTC is stored, the ECU might be faulty. |
