MPVI4 Face Plate Description
Below outlines the legacy features on the face plate of the MPVI4, with a detailed description of each LED RGB (red, green, and blue) and bluetooth status icon.
  1. MPVI4 Face Plate
  2. HPTNET Screw on Connector
  3. Status LED Icon
  4. Bluetooth Low Energy (BLE) LED
  5. WiFi LED
  6. Standalone Data Log & Bluetooth Button
  7. USB-C
Warning
  • When over-voltage is detected , the MPVI4 Status LED will become solid red and will remain solid red until voltage drops below 15.5v, then it will go back to solid green. Operating the MPVI4 with voltage over 15.5v can cause damage to the MPVI4.
  • When an overcurrent event is detected, the firmware attempts recovery by cycling the bus OFF and ON up to three times, checking if the current drops below the threshold. If any attempt succeeds, normal operation resumes. However, if all three attempts fail and the current remains high, the LED turns solid red. At that point, only a power cycle or OBD reset will allow the MPVI4 to recover.
MPVI4 RGB Status LED Description Table
Color Description
No Color Off/No App Running
Solid Blue MPVI4 is powering on
Medium Blue MPVI4 Safe Mode Initiating
Blinking Blue MPVI4 Safe Mode Running
Fast Blinking Blue MPVI4 Safe Mode USB Active
White MPVI4 Safe Mode Ended Successfully
Solid Red MPVI4 Safe Mode Exit Failed
Blinking Medium Blue & Medium Yellow MPVI4 Safe Mode Firmware Update
Medium Yellow MPVI4 Safe Mode Firmware Update Successful
Blinking Medium Blue & Medium Red MPVI4 Safe Mode Firmware Update Failed
Medium Blue MPVI4 Main Application Starting
Medium Green MPVI4 Main Application Running
Fast Blinking Green MPVI4 USB Main Application Activity
White MPVI4 Main Application Exit Successful
Solid Red MPVI4 Main Application Exit Failed
Fast Blinking Medium Green Main Application USB Communication
Fast Blinking Medium Green & Medium Magenta Main Application USB+OBD Communication
Fast Blinking Medium Yellow Main Application Task Starting
Blinking Yellow Main Application Task Running
Flashes Red, Yellow and Red, Yellow again then will remain Green Main Application Task Returned False
Flashes Red, Yellow and Red, Yellow again then will remain Green Main Application Task Exception
Blinking Medium Green & Medium Yellow Main Application Firmware Update
Medium Yellow Main Application firmware Update Successful
Blinking Medium Green & Medium Red Main Application Firmware Update Failed
MPVI4 RGB BT (bluetooth) LED Description Table
Color Description
Blinking Blue When blinking slowly the MPVI4 is in pairing mode. When blinking quickly the MPVI4 is paired with the users bluetooth device.
White Bluetooth has unpaired successfully
Solid Red Bluetooth Failure Detected
Cyan Blue MPVI4 Bluetooth Device Connected
MPVI4 RGB WiFi LED Description Table
Color Description
Blinking Blue When the MPVI4 is blinking slowly, it is connected to WiFi and actively transmitting data.
MPVI4 Standalone Data Logging & Bluetooth Button
Color Description
Blinking Blue When the STAT light is slowly blinking blue safe mode is active
Blinking Yellow When the STAT light is blinking yellow standalone recording is active
Blinking Purple MPVI4 Standalone Failed to Start
