CORE ECU DTC List
DTC Code Description
C154A Brake Pressure Sensor (Front) Outside Of Expected Range
C154B Brake Pressure Sensor (Front) Circuit Low
C154C Brake Pressure Sensor (Front) Circuit High
C154D Brake Pressure Sensor (Rear) Outside Of Expected Range
C154E Brake Pressure Sensor (Rear) Circuit Low
C154F Brake Pressure Sensor (Rear) Circuit High
P0102 Mass Airflow Sensor Circuit Low
P0103 Mass Airflow Sensor Circuit High
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0565 Cruise Control ON Signal
P0566 Cruise Control OFF Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0569 Cruise Control COAST Signal
P0570 Cruise Control ACCEL Signal
P101A Cylinder 1 Primary Injector Circuit Open (Not Connected)
P101B Cylinder 1 Secondary Injector Circuit Open (Not Connected)
P101C Cylinder 1 Primary Injector Circuit High (Short to High Voltage)
P101D Cylinder 1 Secondary Injector Circuit High (Short to High Voltage)
P101E Cylinder 1 Primary Injector Circuit Over Temperature
P101F Cylinder 1 Secondary Injector Circuit Over Temperature
P102A Cylinder 2 Primary Injector Circuit Open (Not Connected)
P102B Cylinder 2 Secondary Injector Circuit Open (Not Connected)
P102C Cylinder 2 Primary Injector Circuit High (Short to High Voltage)
P102D Cylinder 2 Secondary Injector Circuit High (Short to High Voltage)
P102E Cylinder 2 Primary Injector Circuit Over Temperature
P102F Cylinder 2 Secondary Injector Circuit Over Temperature
P103A Cylinder 3 Primary Injector Circuit Open (Not Connected)
P103B Cylinder 3 Secondary Injector Circuit Open (Not Connected)
P103C Cylinder 3 Primary Injector Circuit High (Short to High Voltage)
P103D Cylinder 3 Secondary Injector Circuit High (Short to High Voltage)
P103E Cylinder 3 Primary Injector Circuit Over Temperature
P103F Cylinder 3 Secondary Injector Circuit Over Temperature
P104A Cylinder 4 Primary Injector Circuit Open (Not Connected)
P104B Cylinder 4 Secondary Injector Circuit Open (Not Connected)
P104C Cylinder 4 Primary Injector Circuit High (Short to High Voltage)
P104D Cylinder 4 Secondary Injector Circuit High (Short to High Voltage)
P104E Cylinder 4 Primary Injector Circuit Over Temperature
P104F Cylinder 4 Secondary Injector Circuit Over Temperature
P105A Cylinder 5 Primary Injector Circuit Open (Not Connected)
P105B Cylinder 5 Secondary Injector Circuit Open (Not Connected)
P105C Cylinder 5 Primary Injector Circuit High (Short to High Voltage)
P105D Cylinder 5 Secondary Injector Circuit High (Short to High Voltage)
P105E Cylinder 5 Primary Injector Circuit Over Temperature
P105F Cylinder 5 Secondary Injector Circuit Over Temperature
P1066 Fuel Level Sensor 2 Outside Of Expected Range
P1067 Fuel Level Sensor 2 Circuit Low
P1068 Fuel Level Sensor 2 Circuit High
P106A Cylinder 6 Primary Injector Circuit Open (Not Connected)
P106B Cylinder 6 Secondary Injector Circuit Open (Not Connected)
P106C Cylinder 6 Primary Injector Circuit High (Short to High Voltage)
P106D Cylinder 6 Secondary Injector Circuit High (Short to High Voltage)
P106E Cylinder 6 Primary Injector Circuit Over Temperature
P106F Cylinder 6 Secondary Injector Circuit Over Temperature
P107A Cylinder 7 Primary Injector Circuit Open (Not Connected)
P107B Cylinder 7 Secondary Injector Circuit Open (Not Connected)
P107C Cylinder 7 Primary Injector Circuit High (Short to High Voltage)
P107D Cylinder 7 Secondary Injector Circuit High (Short to High Voltage)
P107E Cylinder 7 Primary Injector Circuit Over Temperature
P107F Cylinder 7 Secondary Injector Circuit Over Temperature
P108A Cylinder 8 Primary Injector Circuit Open (Not Connected)
P108B Cylinder 8 Secondary Injector Circuit Open (Not Connected)
P108C Cylinder 8 Primary Injector Circuit High (Short to High Voltage)
P108D Cylinder 8 Secondary Injector Circuit High (Short to High Voltage)
P108E Cylinder 8 Primary Injector Circuit Over Temperature
P108F Cylinder 8 Secondary Injector Circuit Over Temperature
P1109 Engine MAP Selection Switch Circuit Low
P110A Throttle Actuator Control System - Forced Engine Shutdown (ECU Reboot/Power Cycle Required)
P110B Throttle Actuator Control System - Stuck Open (ECU Reboot/Power Cycle Required)
P110C Throttle Actuator Control System - Stuck Closed (ECU Reboot/Power Cycle Required)
P1110 Engine MAP Selection Switch Circuit High
P1111 Intake Air Temperature Sensor Outside Of Expected Range
P1112 Intake Air Temperature Below Minimum Threshold
P1113 Intake Air Temperature Above Maximum Threshold
P1116 Engine Coolant Temperature Sensor Outside Of Expected Range
P1117 Engine Coolant Temperature Below Minimum Threshold
P1118 Engine Coolant Temperature Above Maximum Threshold
P111A Electronic Throttle 1 - HBridge Supply Voltage High
P111B Electronic Throttle 1 - HBridge Supply Voltage Low
P1120 Acceleration Pedal Position Sensor Limp Mode (ECU Reboot/Power Cycle Required)
P1129 Acceleration Pedal 2 Below Minimum Threshold
P112A Electronic Throttle 1 - HBridge Circuit High (Short to High Voltage)
P112B Electronic Throttle 1 - HBridge Circuit Low (Short to Ground)
P112C Electronic Throttle 1 - HBridge Circuit Open (Not Connected)
P1130 Acceleration Pedal 2 Above Maximum Threshold
P1131 Lambda Bank 1 Sensor 1 Below Minimum Threshold
P1132 Lambda Bank 1 Sensor 1 Above Maximum Threshold
P1135 Lambda Sensor 1 Heater Open Circuit
P1136 Lambda Sensor 1 Heater Status Not Ok
P1137 Lambda Sensor 1 Heater Disconnected
P1138 Lambda Sensor 1 Heater Failed to Heat
P1139 Lambda Sensor 1 Heater Shorted to VBatt
P113A Electronic Throttle 1 - HBridge Overcurrent
P113B Electronic Throttle 1 - HBridge Over Temperature
P113C Electronic Throttle 1 - HBridge Internal Communications Fault
P1140 Lambda Sensor 1 Heater Shorted to Ground
P1141 Lambda Sensor 1 Generic Error
P1142 Lambda Sensor 1 Sensor Wire Short
P1149 Lambda Sensor 2 Outside Of Expected Range
P1150 Lambda Sensor 2 Circuit Failure
P1151 Lambda Bank 2 Sensor 1 Below Minimum Threshold
P1152 Lambda Bank 2 Sensor 1 Above Maximum Threshold
P1155 Lambda Sensor 2 Heater Open Circuit
P1156 Lambda Sensor 2 Heater Status Not Ok
P1157 Lambda Sensor 2 Heater Disconnected
P1158 Lambda Sensor 2 Heater Failed to Heat
P1159 Lambda Sensor 2 Heater Shorted to VBatt
P1160 Lambda Sensor 2 Heater Shorted to Ground
P1161 Lambda Sensor 2 Generic Error
P1162 Lambda Sensor 2 Sensor Wire Short
P1177 Flex Fuel Sensor Outside Of Expected Range
P1178 Flex Fuel Composition Below Minimum Threshold
P1179 Flex Fuel Composition Above Maximum Threshold
P1196 Engine Oil Temperature Sensor Outside Of Expected Range
P1197 Engine Oil Temperature Sensor Circuit Low
P1198 Engine Oil Temperature Sensor Circuit High
P11C4 Fuel Pressure Sensor Outside Of Expected Range
P11C5 Fuel Pressure Sensor Circuit Low
P11C6 Fuel Pressure Sensor Circuit High
P1217 Blip Control Override Active
P121A Electronic Throttle 2 - HBridge Supply Voltage High
P121B Electronic Throttle 2 - HBridge Supply Voltage Low
P1220 Electronic Throttle Override Enabled
P1229 Barometric Pressure Above Maximum Threshold
P122A Electronic Throttle 2 - HBridge Circuit High (Short to High Voltage)
P122B Electronic Throttle 2 - HBridge Circuit Low (Short to Ground)
P122C Electronic Throttle 2 - HBridge Circuit Open (Not Connected)
P1230 Barometric Pressure Sensor Circuit Low
P1231 Barometric Pressure Sensor Circuit High
P1236 Dome Pressure Sensor Outside Of Expected Range
P1237 Dome Pressure Sensor Circuit Low
P1238 Dome Pressure Sensor Circuit High
P123A Electronic Throttle 2 - HBridge Overcurrent
P123B Electronic Throttle 2 - HBridge Over Temperature
P123C Electronic Throttle 2 - HBridge Internal Communications Fault
P126C Primary Injection Time Limit (Minimum) Achieved
P126D Primary Injection Time Limit (Maximum) Achieved (Limp Mode Active - ECU Reboot/Power Cycle Required)
P126E Secondary Injection Time Limit (Minimum) Achieved
P126F Secondary Injection Time Limit (Maximum) Achieved (Limp Mode Active - ECU Reboot/Power Cycle Required)
P1309 AI AirFuel Control Not Ready – Not Trained
P1327 Knock Sensor 1 Circuit Low
P1328 Knock Sensor 1 Circuit High
P1332 Knock Sensor 2 Circuit Low
P1333 Knock Sensor 2 Circuit High
P1346 Nitrous Pressure Sensor Outside Of Expected Range
P1347 Nitrous Pressure Sensor Circuit Low
P1348 Nitrous Pressure Sensor Circuit High
P1349 Nitrous Bottle Heater Turned Off - Bottle Pressure Too Low/Not Increasing
P1451 Fuel Tank Pressure Sensor Outside Of Expected Range
P1452 Fuel Tank Pressure Sensor Circuit Low
P1453 Fuel Tank Pressure Sensor Circuit High
P1461 Fuel Level Sensor 1 Outside Of Expected Range
P1462 Fuel Level Sensor 1 Circuit Low
P1463 Fuel Level Sensor 1 Circuit High
P1511 Idle Air Control Valve Fault - Over Voltage or Over Current or Open Load
P151B Crankcase Pressure Sensor Outside Of Expected Range
P151C Crankcase Pressure Sensor Circuit Low
P151D Crankcase Pressure Sensor Circuit High
P1521 Oil Pressure Sensor Outside Of Expected Range
P1522 Oil Pressure Below Minimum Threshold
P1523 Oil Pressure Above Maximum Threshold
P1531 Air Conditioner Refrigerant Pressure Sensor Outside Of Expected Range
P1532 Air Conditioner Refrigerant Pressure Below Minimum Threshold
P1533 Air Conditioner Refrigerant Pressure Above Maximum Threshold
P1536 Air Conditioner Refrigerant Temperature Sensor Outside Of Expected Range
P1537 Air Conditioner Refrigerant Temperature Below Minimum Threshold
P1538 Air Conditioner Refrigerant Temperature Above Maximum Threshold
P1556 Brake Booster Vacuum Sensor Outside Of Expected Range
P1557 Brake Booster Vacuum Sensor Circuit Low
P1558 Brake Booster Vacuum Sensor Circuit High
P15C3 Coolant Pressure Sensor Outside Of Expected Range
P15C4 Coolant Pressure Sensor Circuit Low
P15C5 Coolant Pressure Sensor Circuit High
P161B Torque Calculation Performance
P1667 Internal Thermistor Sensor (ECU Board) Outside Of Expected Range
P16B1 Power Supply 5V Sensor 1 Status Not Ok
P16B2 Power Supply 5V Sensor 2 Status Not Ok
P1700 TurboLamik TCU Error Code Present (Check TurboLamik TCU)
P1711 Transmission Oil Temperature Sensor Outside Of Expected Range
P1712 Transmission Oil Temperature Below Minimum Threshold
P1713 Transmission Oil Temperature Above Maximum Threshold
P172E Automatic Transmission Active Drive Gear Override Enabled
P1841 Transmission Line Pressure Sensor Outside Of Expected Range
P1842 Transmission Line Pressure Below Minimum Threshold
P1843 Transmission Line Pressure Above Maximum Threshold
U1106 Lost Communication with GM6L80 TCM Module
U1700 TurboLamik TCU Error Code 33 (Lost CAN Comms - Please key cycle to reestablish comms)
