Writing to a Vehicle¶
The below step based procedures outlines how to Write any changes made within VCM Editor into your ECM and/or TCM.
- Download the latest VCM Suite here.
- We recommend Reading your vehicle and saving your original OEM stock file, see the Read Procedure section for more details.
Open the file you just saved from reading your vehicle by clicking File > Open. If you already read the vehicle and saved it, it will automatically display your read and you can begin tuning specific parameters.
- Parameters that have been modified will change to red.
- When switching between tabs (e.g., Fuel, Spark, etc.), the parameters will be saved, so there is no need to save each time you leave a tab.
Once all parameters have been modified to your liking, save the file by clicking File > Save As.
Ensure vehicle is KOEO (Key on, Engine Off).
With the MPVI device plugged into your OBDII port and the USB-C power cable plugged into your MPVI device and laptop, click the
icon. -
In the Vehicle Writer window, select the drop down arrow and select Write Calibration.
Select Write.
Warning
Do not disconnect your MPVI device or USB-C cable while writing to the vehicle as it could cause damage to your ECM.
Once the Vehicle Writer window stats Completed, you can disconnect the MPVI device from your vehicles OBDII device.
