USB File Transfer
Session data and video files can be transferred directly from your iOS or Android device to a computer via USB cable.
iOS Devices
  1. Connect your iOS device to your computer using its USB data cable and open iTunes.
  2. Select your device using the device button near the top of iTunes.
  3. Navigate to the File Sharing section and select TrackAddict.
  4. Select the desired Log- files and save them to your computer. Files can be dragged directly into a folder.
  5. The .CSV (data) and .MOV (video) files are pre-synchronized and ready for use in RaceRender.
Android Devices
  1. Connect your Android device to your computer using its USB data cable.
  2. Set the device to MTP file transfer mode by swiping down from the status bar and selecting "MTP", "File Transfer", or "Media Device".
  3. Open the device's file system using Windows Explorer or Android File Transfer (Mac).
  4. Navigate to Android/data/com.hptuners.trackaddict/files. Devices with an SD card may show two similar storage locations.
  5. Select the desired Log- files and save them to your computer. Files can be dragged directly into a folder.
  6. The .CSV (data) and .MP4 (video) files are pre-synchronized and ready for use in RaceRender.
File Management Notes
Adding, removing, or renaming files via USB is intended for advanced users only. Please observe the following:
  • Session files must follow the naming format: Log-yyyymmdd-hhmmss
  • yyyymmdd — year/month/day (e.g., 20110817 for August 17, 2011)
  • hhmmss — hour/minute/second (e.g., 154312 for 3:43:12 PM)
  • Supported file extensions:
  • Data: .csv, .tad
  • Video: .mov, .mp4
  • Session notes: .txt
  • The video file name must match the data file name exactly, differing only in extension (.mov or .mp4 instead of .csv).
  • Files not created by this app, or files that have been modified externally, may not function correctly. For rendering external data or video, refer to RaceRender.
  • The app should not be on the Sessions screen or any of its sub-views while session files are being modified, as this may cause errors or data inconsistencies.
  • Tracks.dat contains Circuit mode track records; Segments.dat contains Segment mode tracks; Trails.dat contains 4x4 Trail data. These files can be copied to or from other devices running the same version of the app.
  • If Tracks.dat, Segments.dat, or Trails.dat are modified or replaced, it is strongly recommended to fully restart the app. In all cases, navigate to the Track Selection screen and reselect the desired track to ensure data is refreshed.
  • If issues arise, restart the app as a first step.
  • As a last resort, copy all files to your computer, remove them from the app via USB, restart the app, and re-add files one at a time to isolate the cause of any issues.
