File Architecture¶
Use this to better understand the complexity of VCM Scanners open/save dialogs.
Most files are saved in .xml format to enable outside modification if desired, for advanced users.
Architecture By Function¶
VCM Scanner¶
- Stores the active Channel Configuration
- Stores the active Channel Display Properties
- Stores the active Layout Configuration
- Stores the active Layout Display Properties
- Stores user Math Parameters
- Stores user Transforms
- Stores user Preferences
Channels¶
- Reloaded from VCM Scanner.cfg on open
- Saved to VCM Scanner.cfg on close
- Can be saved/loaded from user saved files
Layout¶
Architecture By File Type¶
VCM Suite.cfg¶
- Created by the VCM Scanner/Editor applications only
- Shared between VCM Scanner/Editor instances
- Application Keys
- Unit System
- Tuning Path
VCM Scanner.cfg¶
- Created by the VCM Scanner application only
- Shared between VCM Scanner instances
- Stores Active Channel Configuration
- Stores Active Channel Display Properties
- Stores Active Layout Configuration
- Stores Active Layout Display Properties
- Stores User Math Parameters
- Stores User Transforms
- Stores Application Preferences & Settings
*.Channels.xml¶
- Default Location: \My Documents\HP Tuners\VCM Scanner\Channel Configs\
- Created by users only
- Stores Parameter ID and Source
- Stores Channel Polling Intervals
- Stores Channel Transforms
*.ChannelDisplay.xml¶
- Stores Channel Display Fonts and Colors
*.Layouts.xml¶
- Default Location: \My Documents\HP Tuners\VCM Scanner\Layouts\
Architecture By File Type - Gauges¶
*.Gauges.xml¶
- Default Location: \My Documents\HP Tuners\VCM Scanner\Gauges\
- Stores all gauges on the selected display
*.Gauge.xml¶
- Stores a single Gauge
*.GaugeDisplay.xml¶
- Stores Gauge Display Fonts and Colors
Architecture By File Type - Graphs¶
*.Graphs.xml¶
- Default Location: \My Documents\HP Tuners\VCM Scanner\Graphs\
- Stores all graphs on the selected display
*.Table.xml¶
- Stores a single Table
*.GraphDisplay.xml¶
- Stores Graph Display Fonts and Colors
Architecture By File Type - Charts¶
*.Charts.xml¶
- Default Location: \My Documents\HP Tuners\VCM Scanner\Charts\
- Stores all charts on the selected display
*.Chart.xml¶
- Stores a single Chart and its associated Series
*.Series.xml¶
- Stores a single series
*.ChartDisplay.xml¶
- Stores Chart Display Fonts and Colors
