Introduction
VCM Scanner Chanelog
VCM Scanner 5.2
Improved performance
Additional vehicle support
New log file format with improved performance and reduced size
MPVI4 support
VCM Scanner 5.0
General
MPVI3 and RTD Gen 3 support
Multi-language support (work in progress)
Improved Vehicle Profile Editor (load/save/import from log files)
Scanning
Marker support (M key during scanning)
Layouts
Drive Cycle panel for emissions and fuel economy testing
Histogram graph support
VCM Scanner 4.12
Scanning
Advanced channel properties: OS Fallback and OS Override
Parameters
Improved definition support for multiple platforms
VCM Scanner 4.10
Parameters
Diagnostics & Info
Enhanced DTC polling and clearing
KWP2000 DTC support (varies by vehicle)
MPVI2
Standalone datalogging (Pro Feature Set required)
VCM Scanner 4.8
Parameters
Diagnostics & Info
GM HS-CAN module support
Unified Diagnostic Services DTC reporting
MPVI2
Additional CAN sensor support (MPVI2 + ProLink)
Bosch LT2
AEM 30-0306 Boost Gauge
Controls & Special Functions
Porsche Service Reminder Reset
Ford Super Duty (Remote Start Duration, TPMS Thresholds)
VCM Scanner 4.6
Scanning
Improved scanning performance for older vehicles
Parameters
Additional parameters added
Layouts > Gauges
Improved Range level 3 background alert activation
Maths
User maths increased to 40.
Added a Shift() function.
Diagnostics & Info
Manufacturer specific DTC descriptions have been added for many platforms.
MPVI2
External CAN sensors via ProLink now supported
External CAN sensors can be monitored without a vehicle present.
VCM Scanner 4.4
General
Vehicle info added to log Details tab
VCM Scanner 4.2
General
CSV export alignment fixes
Scanning
MPVI2 Pro Link support
Dodge scanning fixes
Parameters
More parameters have been added.
More controls & special functions have been added for many newer vehicles.
VCM Scanner 4.0
General
Update availability checks
Improved interface disconnect handling
.NET Framework 4.6.1 requirement
Application key prompt improvements
Scanning
Fixed channel interval prioritization bug
Parameters
MPVI2
Initial hardware release
USB scanning support
VCM Scanner 3.6
General
Diagnostics and Info Readiness Tests now list tests that are Not Supported.
Scanning
Fixed a bug where the scanner would randomly stop after an arbitrary length of time.
Parameters
Additional parameters added.
Several issues on GM vehicles have been resolved, including VATS Relink, Transmission Gear control.
VCM Scanner 3.4
General
Improved overall performance
Additional RTT features
Scanning
Improved protocol detection (ISO 9141 support)
VCM Scanner 3.2
Files
Legacy config and histogram file support
Scanning
Increased scan rate for GM 97 V6 and 97–98 LS1
Expanded controller support
Parameters
Additional parameters and transforms
Improved search matching
GM VATS Relink
GM Change VIN
Ford KAM Reset & Crank Relearn
Dodge ETC Learn, Traction Control, Adaptive Reset
VCM Scanner 3.0
Global
Multiple application key support
Improved VCM Suite Info
Vehicle profile history support
Core
Auto-saving layout and config
Multiple instance display objects
Auto-scaling UI
Files
.hpl files are saved using a new file format.
You can now open third party .csv files.
Scanning
All scanned marketers are now managed through one display: the Channels Form. This combines the displays from VCM Scanner 2.x, Table Display and Status Bit Display.
The internal scanning methods have been improved for faster scan rates.
OBD Support for CAN 250 kb/s and ISO 14230 (European KWP 2000).
Windows Screen Saver and Sleep is suspended while scanning.
Parameters
Broadcast parameters now supported.
Parameters now have default polling intervals set. These intervals can be adjusted.
SAE parameters have been added.
Ford and Dodge pmeters have been added.
Parameters have been organized and grouped more appropriately.
Channels
Load Vehicle Defaults added, which take into account each vehicle specifically.
Serial port wideband support added.
Layouts
Default Layouts are now built into VCM Scanner.
Many more options available.
Layouts > Chart vs Time
Much faster back end.
Acts in a better fashion near the front and end of logs.
Layouts > Graph
Formerly known as "Histogram". We inappropriately used the term "histogram" since VCM Scanner 1.x.
Supports multiple cell selection with the ctrl key.
Maths
Table Filters and Math pmeters now support avg() and slope().
Variable Wizard added to help expression creation
Unsupported variables are highlighted in Pink
Diagnostics & Info
Freeze Frame support added
MPVI Interface
Standalone Datalogging format has changed.
You will need to write your config to the interface using VCM Scanner 3.0 or newer.
You will not be able to read logs from the interface configured with older versions of VCM Scanner.
Misc
Many bugs have been fixed from 2.24.
Back to top
