VCM Live Changelog
VCM Live 1.1.386
  • Tune Comparison implementation
  • CAN Config updates
  • New predefined CAN config updates
  • New setup wizard groups and sensors
  • Updated layouts
  • New/Updated icons
  • Simplified log navigation via arrow keys
  • AI AirFuel dialog improvement
  • Live tunable parameter indicator
  • Auto resizing characteristics tables
  • Dark theme improvements and controls
  • Performance and memory improvements
  • Framework improvements
  • Logic and workflow improvements
VCM Live 1.1.329
  • Setup Wizard Updates
  • UI Updates
VCM Live 1.1.320
UI Improvements
  • Changed the style of most of the UI controls used in Dialogs;
  • Dark theme UI for most of the dialogs;
  • Sorting for lists;
  • Freezes fixes;
  • Default unit type is applied from Options dialog to all layout groups, including Predefined;
  • Nav Tree loading speed improved;
  • Older Layouts updated;
  • Added new layouts and the "User Defined" group;
3D Graph Improvements
  • Overhauled UI representation with added info labels and a position Reset button
  • Bidirectional cell selection sync between the 3D Graph and data table
  • Live Tracing support implemented
Read/Write Tune Improvements
  • Increased measurement logging limit
  • Frequency can now be changed for multiple selected measurements simultaneously
  • Redesigned ECU Logs tab with improved log list and status display
  • Added options to open a log in-app or navigate to its folder location
  • Faster log unpacking after download
CAN Config Improvements
  • Added IEEEFloat type support
  • Added Intel and Motorola inversions in the Bytes map
Setup Wizard Improvements
  • Sensor selection now clears when linked table/characteristic data is modified
  • Added "Engine Type" group for engine type selection
  • Updated throttle body data; added Mopar 53034251AB sensor
  • Refreshed and corrected data for several sensors
VCM Live 1.1.268
  • New histogram view for overlaying logged data.
  • New indication for cells that have been modified.
  • Improved undo function.
  • Improved DTC interface.
  • Improved tune upgrade.
  • Improved setup wizards.
  • New auto calibration process for TPS and APP sensors.
  • Improved layout tabs.
  • Improved readability of font.
  • Bug fixes and performance enhancements.
  • Introduced "Splash Screen" on initial app setup
  • Saving predefined layout changes
  • Introduction to critical DTCs
  • Improvements in Characteristics Editor, Saving table configs, smoothing and saving selected parameter
  • Multiple QOL (quality of life) Improvements
VCM Live 1.1.235
  • Implemented setup wizard
  • Implemented DTC
  • Implemented undo functionality
  • Updated setup wizard data
  • Implementation of Layout groups and layout group tabs
  • DTC list updated
  • Added 12 default tune variants
  • AI AirFuel
VCM Live 1.0
  • Initial release
