Main Power🔗
The ECU's main power is through connector pin D7 on connector D, with a max current of 10 amps. The main power for the ignition switch is found at pin C1 on connector C and the main power for the throttle body can be found at pin A1 on connector A. Both the ignition and throttle body have a max current of 10 amps.
