HP TUNERS DOCS
OBDII Adapter Cable (s)
Initializing search
CORE ECU Control Systems Guide
CORE ECU Diagnostic Manual
CORE ECU Install Guide
CORE ECU Parameter Guide
CORE VCM Live
Electrical Schematics
Knowledge Base Articles
MPVI3
TDN APP & RTD4 User Guide
TDN Tuner Portal Help System
Toyota Smart Access Cable
TrackAddict User Guide
Tuner Tools
Contacting Customer Support
AI Airfuel
AI Airfuel
AI Airfuel
AI Traction Control
AI Traction Control
AI Traction Control
Boost Control
Boost Control
Boost Control
COâ‚‚ Boost Control
Launch Control
Launch Control
Launch Control
Misfire Detection
Misfire Detection
Misfire Detection
DTC's
DTC's
CORE ECU DTC List
DTC P06B1
DTC P06B4
DTC P0103
DTC P0107
DTC P0108
DTC P0112
DTC P0113
DTC P0117
DTC P0118
DTC P0130
DTC P0131
DTC P0132
DTC P0134
DTC P0135
DTC P0150
DTC P0151
DTC P0152
DTC P0154
DTC P0155
DTC P0178
DTC P0179
DTC P0227
DTC P0228
DTC P0327
DTC P0328
DTC P0332
DTC P0333
DTC P0511
DTC P0522
DTC P0523
DTC P0532
DTC P0533
DTC P0537
DTC P0538
DTC P0562
DTC P0563
DTC P0570
DTC P0571
DTC P0572
DTC P0573
DTC P0668
DTC P0669
DTC P0712
DTC P0713
DTC P0719
DTC P0720
DTC P0721
DTC P0722
DTC P0842
DTC P0843
DTC P1102
DTC P1103
DTC P1107
DTC P1108
DTC P1112
DTC P1113
DTC P1117
DTC P1118
DTC P1122
DTC P1123
DTC P1127
DTC P1128
DTC P1129
DTC P1130
DTC P1131
DTC P1132
DTC P1151
DTC P1152
DTC P1178
DTC P1179
DTC P1226
DTC P1227
DTC P1228
DTC P1229
DTC P1347
DTC P1348
DTC P1350
DTC P1351
DTC P1360
DTC P1361
DTC P1362
DTC P1363
DTC P1364
DTC P1365
DTC P1366
DTC P1367
DTC P1522
DTC P1523
DTC P1532
DTC P1533
DTC P1537
DTC P1538
DTC P1712
DTC P1713
DTC P1842
DTC P1843
DTC P2109
DTC P2122
DTC P2123
DTC P2129
DTC P2130
DTC P2132
DTC P2133
DTC P2228
DTC P2229
CORE Inputs & Outputs
Backfire Diagnostics
Cuts-Out & Misses Diagnostics
Fuel System Diagnostics
Hard Start Diagnostics
Hesitation Diagnostics
Intermittent Diagnostics
No Start Diagnostics
Introduction
Introduction
Introduction
Dimensions
VCM Live Requirements
ECU Installation
ECU Installation
ECU Installation
Pre-Start Setup Wizard
Main Power
CORE Connectors
Pinouts
Pinouts
Pinouts
Sensors & Connectors
Ignition & Injection Wiring
Dual Injection Configuration
Ethernet Configuration
Wiring Harness
Wiring Harness
Wiring Harness
Accelerator Pedal
Accelerator Pedal
Acceleration Pedal Position Automatic Calibration
Measurements
Measurements
Acceleration Pedal Position 1 Voltage Full Close
Acceleration Pedal Position 1 Voltage Full Open
Acceleration Pedal Position 2 Voltage Full Close
Acceleration Pedal Position 2 Voltage Full Open
Acceleration Pedal Position Automatic Calibration Active
Acceleration Pedal Position Automatic Calibration Pre-Check Successful
Acceleration Pedal Position Automatic Calibration Start Successful
Acceleration Pedal Position Automatic Calibration State
Final Pedal Position
Measurements
Measurements
Acceleration Pedal (APP) Position
Pedal Position Sensor 1
Measurements
Measurements
Acceleration Pedal 1 (APP1) DTC Active
Acceleration Pedal 1 (APP1) Position
Acceleration Pedal 1 (APP1) Sensor Voltage
Tunable Parameters
Tunable Parameters
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Filter Frequency
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Position Scaled Endpoints
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Sensor DTC Maximum
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Sensor DTC Maximum Voltage
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Sensor DTC Minimum
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Sensor DTC Minimum Voltage
Acceleration Pedal Position 1 (ACCEL PEDAL 1) Sensor Input
Pedal Position Sensor 2
Measurements
Measurements
Acceleration Pedal 2 (APP2) DTC Active
Acceleration Pedal 2 (APP2) Position
Acceleration Pedal 2 (APP2) Sensor Voltage
Tunable Parameters
Tunable Parameters
Acceleration Pedal 2 (ACCEL PEDAL 2) Filter Frequency
Acceleration Pedal 2 (ACCEL PEDAL 2) Position Scaled Endpoints
Acceleration Pedal 2 (ACCEL PEDAL 2) Sensor DTC Maximum
Acceleration Pedal 2 (ACCEL PEDAL 2) Sensor Input
Acceleration Pedal Position 2 (ACCEL PEDAL 2) Sensor DTC Minimum
Acceleration Pedal Position 2 (ACCEL PEDAL 2) Sensor DTC Minimum Voltage
Acceleration Pedal 2 Sensor DTC Maximum Voltage
Pedal Security
Pedal Security
Measurements
Measurements
Acceleration Pedal (APP) Limp Control Requested
Acceleration Pedal (APP) Security Active
Tunable Parameters
Tunable Parameters
Acceleration Pedal (APP) Correlation Activation Delay
Acceleration Pedal (APP) Correlation Error Threshold
Acceleration Pedal (APP) Security Activation Delay
Acceleration Pedal (APP) Security Enabled
Acceleration Pedal (Accel Pedal) Security Threshold
Acceleration Pedal (Accel Pedal) Security Time
AI (Artificial Intelligence)
Measurements
Measurements
AI - Air Fuel DTC Active
AI - Air Fuel Requested
Airflow
Airflow
Airflow
Final Airflow
Final Airflow
Measurements
Measurements
Cylinder Airmass
Cylinder Airmass Delta
Hybrid Mass Airflow
Lower To Upper Transition Requested
Mass Airflow Filtered
Volumetric Efficiency
Tunable Parameter
Tunable Parameter
Airflow Calculation Mode
Engine Speed Hybrid Threshold
Engine Speed Hybrid Threshold Hysteresis
Hybrid Mass Airflow Filter Coefficient
Hybrid Mode Blending Step
Hybrid Mode Switching Behavior
Hybrid Switching Mode
Manifold Absolute Pressure Hybrid Threshold
Manifold Absolute Pressure Hybrid Threshold Hysteresis
Mass Airflow Hybrid Threshold
Mass Airflow Hybrid Threshold Hysteresis
Mass Airflow To Speed Density
Throttle Position Hybrid Threshold
Throttle Position Hybrid Threshold Hysteresis
Speed Density
Speed Density
Measurements
Measurements
Cylinder Charge Temperature
Mass Airflow Calculated
Mass Airflow Estimated
Uncorrected Estimated Mass Airflow
Volumetric Efficiency Correction
Volumetric Efficiency Correction Bias Active
Volumetric Efficiency Map Selected
Tunable Parameter
Tunable Parameter
Cranking To Running SD Correction Startup Delay
Cranking Volumetric Efficiency
Cranking Volumetric Efficiency Barometric Pressure Multiplier
Cylinder Charge Temperature Bias
Speed Density Airflow Filter Coefficient
Speed Density Charge Temperature Correction
Speed Density Manifold Absolute Pressure Delta Filing Compensation
Speed Density Throttle Position Delta Filing Compensation
Volumetric Efficiency (Map #1)
Volumetric Efficiency Map #2
Volumetric Efficiency Map #3
Volumetric Efficiency Map #4
Blip Control
Blip Control
Measurements
Measurements
Blip Control
Blip Control Active
Blip Control Allowed
Blip Control Throttle Position Requested
Tunable Parameters
Tunable Parameters
Blip Control Active Time
Blip Control Enable Drive Gear Minimum
Blip Control Enabled
Blip Control Mode
Blip Control Override Enabled
Boost
Boost
Boost Control Demand
Measurements
Measurements
CO2 Exhaust Wastegate Actuator Duty Cycle
CO2 Exhaust Wastegate Actuator Output Status
CO2 Exhaust Wastegate Override Demand
CO2 Exhaust Wastegate Override Enabled
CO2 Fill Wastegate Actuator Duty Cycle
CO2 Fill Wastegate Actuator Output Status
CO2 Fill Wastegate Override Demand
CO2 Fill Wastegate Override Enabled
Wastegate Actuator #1 Duty Cycle
Wastegate Actuator #1 Output Status
Wastegate Actuator #2 Duty Cycle
Wastegate Actuator #2 Output Status
Wastegate Duty Cycle #1 Engine Coolant Temperature Correction
Wastegate Duty Cycle #1 Gear Correction
Wastegate Duty Cycle #1 Intake Air Temperature Correction
Wastegate Duty Cycle #2 Engine Coolant Temperature Correction
Tunable Parameters
Tunable Parameters
CO2 Exhaust Wastegate Actuator Output Frequency
CO2 Fill Wastegate Actuator Output Frequency
CO2 Wastegate Actuator Output Inverted
Nitrous Deactivation Boost Control Duty Cycle Cut Delay
Wastegate Actuator #1 Demand
Wastegate Actuator #1 Output Frequency
Wastegate Actuator #1 Override
Wastegate Actuator #2 Demand
Wastegate Actuator #2 Duty Cycle Correction
Wastegate Actuator #2 Output Frequency
Wastegate Actuator #2 Override
Wastegate Duty Cycle #1 Barometric Correction
Wastegate Duty Cycle #1 Barometric Pressure Correction
Wastegate Duty Cycle #2 Barometric Correction
Wastegate Duty Cycle #2 Barometric Pressure Correction
Wastegate Duty Cycle #2 Gear Correction
Wastegate Duty Cycle #2 Intake Air Temperature Correction
Wastegate Duty Cycle Maximum
Wastegate Duty Cycle Minimum
Boost Control Regulation
Measurements
Measurements
Boost Control Active
Boost Control Integral Term
Boost Control Proportional Term
Boost Control State
Boost Pressure Error
CO2 Boost Control Active Actuator
CO2 Boost Control Drain Active
CO2 Boost Control Drain Wastegate Duty Cycle
Close Loop Boost Control Active
Open Loop CO2 Wastegate Duty Cycle
Open Loop Wastegate Duty Cycle
Timed Boost Active Time
Wastegate Duty Cycle Requested
Tunable Parameters
Tunable Parameters
Boost Control Closed Loop Maximum
Boost Control Closed Loop Minimum
Boost Control Enabled
Boost Control Integral Deadband
Boost Control Integral Gain
Boost Control Integral Reset Request
Boost Control Integral Reset Value
Boost Control Integral Term Maximum
Boost Control Integral Term Minimum
Boost Control Manifold Relative Pressure Threshold
Boost Control Manifold Relative Pressure Threshold Hysteresis
Boost Control Mode
Boost Control Proportional Gain
Boost Control Proportional Term Maximum
Boost Control Proportional Term Minimum
CO2 Boost Control Boost Pressure Error Threshold
CO2 Boost Control Boost Pressure Error Threshold Hysteresis
CO2 Boost Control Drain Deactivate Pressure Minimum
CO2 Boost Control Drain Rate Limiter Down
CO2 Boost Control Drain Rate Limiter Up
CO2 Boost Setpoint Mode
Launch Boost Fuel Correction
Launch Boost Ignition Correction
Launch Boost Open Loop Wastegate Duty Cycle
Open Loop CO2 Exhaust Wastegate Duty Cycle (Map #1)
Open Loop CO2 Exhaust Wastegate Duty Cycle Map #2
Open Loop CO2 Exhaust Wastegate Duty Cycle Map #3
Open Loop CO2 Exhaust Wastegate Duty Cycle Map #4
Open Loop CO2 Fill Wastegate Duty Cycle (Map #1)
Open Loop CO2 Fill Wastegate Duty Cycle Map #2
Open Loop CO2 Fill Wastegate Duty Cycle Map #3
Open Loop CO2 Fill Wastegate Duty Cycle Map #4
Open Loop Wastegate Duty Cycle (Map #1)
Open Loop Wastegate Duty Cycle Map #2
Open Loop Wastegate Duty Cycle Map #3
Open Loop Wastegate Duty Cycle Map #4
Scramble Boost Open Loop Wastegate Duty Cycle Adder
Timed Boost Activation Mode
Timed Boost Arming Switch Engage (Press) Time
Timed Boost Enable Vehicle Speed Maximum
Timed Boost Open Loop Wastegate Duty Cycle (Map #1)
Timed Boost Open Loop Wastegate Duty Cycle Map #2
Timed Boost Open Loop Wastegate Duty Cycle Map #3
Timed Boost Open Loop Wastegate Duty Cycle Map #4
Boost Pressure Target
Measurements
Measurements
Boost Control Map Selected
Boost Pressure Setpoint
Tunable Parameters
Tunable Parameters
Boost Pressure Setpoint Barometric Pressure Correction
Boost Pressure Setpoint Engine Coolant Temperature Correction
Boost Pressure Setpoint Gear Correction
Boost Pressure Setpoint Intake Air Temperature Correction
Boost Pressure Setpoint (Map #1)
Boost Pressure Setpoint Map #2
Boost Pressure Setpoint Map #3
Boost Pressure Setpoint Map #4
Launch Boost Pressure Sepoint
Scramble Boost Pressure Sepoint Adder
Over Boost Hard Limiter
Measurements
Measurements
Over Boost Hard Limiter Active
Over Boost Hard Limiter Ignition Cut Active
Over Boost Hard Limiter Ignition Cut Pattern Requested
Over Boost Hard Limiter Injection Cut Active
Over Boost Hard Limiter Injection Cut Pattern Requested
Over Boost Hard Limiter Throttle Position Cut Active
Over Boost Hard Limiter Throttle Position Cut Pattern Requested
Over Boost Hard Limiter Wastegate Duty Cycle Cut Active
Over Boost Hard Limiter Wastegate Duty Cycle Cut Pattern Requested
Tunable Parameters
Tunable Parameters
Over Boost Hard Limiter Cut Delay (Map #1)
Over Boost Hard Limiter Map #2 Cut Delay
Over Boost Hard Limiter Map #3 Cut Delay
Over Boost Hard Limiter Map #4 Cut Delay
Over Boost Hard Limiter Ignition Cut Enabled
Over Boost Hard Limiter Ignition Cut Rate Limiter Down
Over Boost Hard Limiter Ignition Cut Rate Limiter Up
Over Boost Hard Limiter Injection Cut Enabled
Over Boost Hard Limiter Injection Cut Rate Limiter Down
Over Boost Hard Limiter Injection Cut Rate Limiter Up
Over Boost Hard Limiter Manifold Relative Pressure Threshold Hysteresis
Over Boost Hard Limiter Manifold Relative Pressure Threshold Hysteresis Map #2
Over Boost Hard Limiter Manifold Relative Pressure Threshold Hysteresis Map #3
Over Boost Hard Limiter Manifold Relative Pressure Threshold Hysteresis Map #4
Over Boost Hard Limiter Manifold Relative Pressure Threshold (Map #1)
Over Boost Hard Limiter Manifold Relative Pressure Threshold Map #2
Over Boost Hard Limiter Manifold Relative Pressure Threshold Map #3
Over Boost Hard Limiter Manifold Relative Pressure Threshold Map #4
Over Boost Hard Limiter Throttle Position Cut Enabled
Over Boost Hard Limiter Throttle Position Cut Rate Limiter Down
Over Boost Hard Limiter Throttle Position Cut Rate Limiter Up
Over Boost Hard Limiter Wastegate Duty Cycle Cut Rate Limiter Down
Over Boost Hard Limiter Wastegate Duty Cycle Cut Rate Limiter Up
Over Boost Soft Limiter
Measurements
Measurements
Over Boost Soft Limiter Feed Forward Term
Over Boost Soft Limiter Integral Term
Over Boost Soft Limiter Manifold Relative Pressure Error
Over Boost Soft Limiter Proportional Term
Over Boost Soft Limiter Throttle Position Cut Active
Over Boost Soft Limiter Throttle Position Requested
Over Boost Soft Limiter Wastegate Duty Cycle Cut Pattern Requested
Tunable Parameters
Tunable Parameters
Over Boost Soft Limiter Closed Loop Maximum
Over Boost Soft Limiter Closed Loop Minimum
Over Boost Soft Limiter Integral Deadband
Over Boost Soft Limiter Integral Gain
Over Boost Soft Limiter Integral Term Maximum
Over Boost Soft Limiter Integral Term Minimum
Over Boost Soft Limiter Proportional Gain
Over Boost Soft Limiter Proportional Term Maximum
Over Boost Soft Limiter Proportional Term Minimum
Over Boost Soft Limiter Threshold Hysteresis (Map #1)
Over Boost Soft Limiter Threshold Hysteresis Map #2
Over Boost Soft Limiter Threshold Hysteresis Map #3
Over Boost Soft Limiter Threshold Hysteresis Map #4
Over Boost Soft Limiter Threshold (Map #1)
Over Boost Soft Limiter Threshold Map #2
Over Boost Soft Limiter Threshold Map #3
Over Boost Soft Limiter Threshold Map #4
Over Boost Soft Limiter Throttle Position Cut Enabled
Over Boost Soft Limiter Wastegate Duty Cycle Cut Decay
Over Boost Soft Limiter Wastegate Duty Cycle Cut Enabled
Over Boost Soft Limiter Wastegate Duty Cycle Cut (Map #1)
Over Boost Soft Limiter Wastegate Duty Cycle Cut Map #2
Over Boost Soft Limiter Wastegate Duty Cycle Cut Map #3
Over Boost Soft Limiter Wastegate Duty Cycle Cut Map #4
Over Boost Soft Limiter Wastegate Duty Cycle Cut Rate Limiter Up
Critical Sensors
Critical Sensors
Measurements
Measurements
Critical Sensor Fault Active
Critical Sensor Fault Engine Speed (REV) Cut
Critical Sensor Fault Engine Speed (REV) Limiter Active
Critical Sensor Fault Ignition Angle
Critical Sensor Fault Throttle Limp Active
Tunable Parameters
Tunable Parameters
Critical Sensor Fault Limiter Engine Speed Threshold
Critical Sensor Fault Limiter Engine Speed Threshold Hysteresis
Engine Input
Engine Input
Alternator
Alternator
Alternator
Measurements
Measurements
Alternator Active
Alternator Actuator Duty Cycle
Alternator Requested
Tunable Parameters
Tunable Parameters
Alternator Actuator Output
Alternator Actuator Output Frequency
Alternator Actuator Output Inverted
Alternator Delay Time
Alternator Override Enabled
Barometric Pressure
Barometric Pressure
Barometric Pressure
Measurements
Measurements
Barometric Pressure
Barometric Pressure (Baro) DTC Fault Active
Barometric Pressure Sensor Voltage
Pressure Ratio
Tunable Parameters
Tunable Parameters
Barometric Pressure (Baro) Default
Barometric Pressure (Baro) Filter Coefficient
Barometric Pressure (Baro) Scaled Endpoints
Barometric Pressure (Baro) Sensor DTC Maximum
Barometric Pressure (Baro) Sensor DTC Maximum Volts
Barometric Pressure (Baro) Sensor DTC Minimum
Barometric Pressure (Baro) Sensor DTC Minimum Volts
Barometric Pressure (Baro) Sensor Input
Barometric Pressure (Baro) Sensor Inverted
Battery
Battery
Measurements
Measurements
Battery Voltage
Battery Voltage DTC Active
Tunable Parameters
Tunable Parameters
Battery Voltage Filter Coefficient
Battery Voltage Sensor DTC Maximum
Battery Voltage Sensor DTC Minimum
Battery Voltage Sensor Input
Dome Pressure
Dome Pressure
Measurements
Measurements
Dome Pressure
Dome Pressure DTC Fault Active
Dome Pressure Sensor Voltage
Tunable Parameters
Tunable Parameters
Dome Pressure DTC Maximum
Dome Pressure DTC Maximum Voltage
Dome Pressure DTC Minimum
Dome Pressure DTC Minimum Voltage
Dome Pressure Filter Frequency
Dome Pressure Noise Filter Frequency
Dome Pressure Noise Threshold
Dome Pressure Persistent Noise Filter Frequency
Dome Pressure Persistent Noise Threshold
Dome Pressure Persistent Noise Time Threshold
Dome Pressure Scaled Endpoints
Dome Pressure Sensor Default
Dome Pressure Sensor Inverted
Dome Pressure Sensor Resource
Dome Pressure Stuck Time Threshold
Engine Coolant Temperature (ECT) Sensor
Measurements
Measurements
Engine Coolant Temperature (ECT) Sensor Resistance
Engine Coolant Temperature (ECT) DTC Fault Active
Engine Coolant Temperature (ECT) Sensor Voltage
Tunable Parameters
Tunable Parameters
Engine Coolant Temperature (ECT) Filter Coefficient
Engine Coolant Temperature (ECT) Scaled Endpoints
Engine Coolant Temperature (ECT) Sensor DTC Maximum
Engine Coolant Temperature (ECT) Sensor DTC Maximum Volts
Engine Coolant Temperature (ECT) Sensor DTC Minimum
Engine Coolant Temperature (ECT) Sensor DTC Minimum Volts
Engine Coolant Temperature (ECT) Sensor Default
Engine Coolant Temperature (ECT) Sensor Input
Intake Air Temperature Sensor (IAT)
Measurements
Measurements
Intake Air Temperature (IAT) Sensor Resistance
Intake Air Temperature (IAT) DTC Fault Active
Intake Air Temperature (IAT) Sensor Voltage
Tunable Parameters
Tunable Parameters
Intake Air Temperature (IAT) Filter Coefficient
Intake Air Temperature (IAT) Scaled Endpoints
Intake Air Temperature (IAT) Sensor DTC Maximum
Intake Air Temperature (IAT) Sensor DTC Maximum Voltage
Intake Air Temperature (IAT) Sensor DTC Minimum
Intake Air Temperature (IAT) Sensor DTC Minimum Voltage
Intake Air Temperature (IAT) Sensor Default
Intake Air Temperature (IAT) Sensor Input
Intercooler Pump
Intercooler Pump
Measurements
Measurements
Intercooler Pump Active
Intercooler Pump Actuator Output Status
Tunable Parameters
Tunable Parameters
Intercooler Pump Override
Minimum Intercooler Pump Engine Run Time
Internal Thermistor
Internal Thermistor
Internal Thermistor
Measurements
Measurements
Internal Thermistor Sensor Voltage
Internal Thermistor Temperature
Internal Thermistor Temperature DTC Active
Internal Thermistor Temperature Maximum
Internal Thermistor Temperature Sensor Resistance
Tunable Parameters
Tunable Parameters
Internal Thermistor Sensor Input
Internal Thermistor Temperature Default
Internal Thermistor Temperature Filter Coefficient
Internal Thermistor Temperature Scaled Endpoints
Internal Thermistor Temperature Sensor DTC Maximum
Internal Thermistor Temperature Sensor DTC Minimum
Lambda Sensor
Lambda Sensor
Lambda Sensor
Measurements
Measurements
Air Fuel Ratio (AFR) Sensor 1
Air Fuel Ratio (AFR) Sensor 2
Air Fuel Ratio (AFR) Setpoint
Injector Inactive Lambda DTC Disable Active
Lambda Bank #1 DTC Fault Active
Lambda Bank #2 DTC Fault Active
Lambda Sensor 1
Lambda Sensor 1 DTC Status
Lambda Sensor 1 Input Status
Lambda Sensor 1 Voltage
Lambda Sensor 2
Lambda Sensor 2 DTC Status
Lambda Sensor 2 Input Status
Lambda Sensor 2 Voltage
Tunable Parameters
Tunable Parameters
Injector Inactive Lambda DTC Disable Time
Lambda Sensor DTC Maximum
Lambda Sensor DTC Maximum Voltage
Lambda Sensor DTC Minimum
Lambda Sensor DTC Minimum Voltage
Lambda Sensor Default
Manifold Absolute Pressure Sensor (MAP)
Measurements
Measurements
Manifold Absolute Pressure (MAP)
Manifold Absolute Pressure (MAP) DTC Fault Active
Manifold Absolute Pressure (MAP) Sensor Delta
Manifold Absolute Pressure (MAP) Sensor Voltage
Tunable Parameters
Tunable Parameters
Manifold Absolute Pressure (MAP) Scaled Endpoints
Manifold Absolute Pressure (MAP) Sensor DTC Maximum
Manifold Absolute Pressure (MAP) Sensor DTC Maximum Voltage
Manifold Absolute Pressure (MAP) Sensor DTC Minimum
Manifold Absolute Pressure (MAP) Sensor DTC Minimum Volts
Manifold Absolute Pressure (MAP) Sensor Default
Manifold Absolute Pressure (MAP) Sensor Input
Manifold Absolute Pressure (MAP) Sensor Inverted
Mass Airflow Sensor (MAF)
Measurements
Measurements
Mass Airflow (MAF)
Mass Airflow (MAF) DTC Fault Active
Mass Airflow (MAF) Sensor Duty Cycle
Mass Airflow (MAF) Sensor Frequency
Tunable Parameters
Tunable Parameters
Mass Airflow (MAF) Correction
Mass Airflow (MAF) Scaled Endpoints
Mass Airflow (MAF) Sensor DTC Maximum
Mass Airflow (MAF) Sensor DTC Maximum Frequency
Mass Airflow (MAF) Sensor DTC Minimum
Mass Airflow (MAF) Sensor DTC Minimum Frequency
Mass Airflow (MAF) Sensor Default
Mass Airflow (MAF) Sensor Input
Mass Airflow (MAF) Smoothing Factor
Nitrous Pressure
Nitrous Pressure
Measurements
Measurements
Nitrous Pressure (NOS)
Nitrous Pressure (NOS) DTC Fault Active
Nitrous Pressure (NOS) Sensor Voltage
Tunable Parameters
Tunable Parameters
Nitrous Pressure (NOS) Filter Coefficient
Nitrous Pressure (NOS) Sensor DTC Maximum
Nitrous Pressure (NOS) Sensor DTC Maximum Volts
Nitrous Pressure (NOS) Sensor DTC Minimum
Nitrous Pressure (NOS) Sensor DTC Minimum Volts
Nitrous Pressure (NOS) Sensor Default
Nitrous Pressure (NOS) Sensor Input
Nitrous Pressure (NOS) Sensor Inverted
Oil Pressure Sensor
Oil Pressure Sensor
Measurements
Measurements
Oil Pressure
Oil Pressure DTC Fault Active
Oil Pressure Sensor Voltage
Tunable Parameters
Tunable Parameters
Oil Pressure Default
Oil Pressure Filter Coefficient
Oil Pressure Sensor DTC Maximum
Oil Pressure Sensor DTC Maximum Voltage
Oil Pressure Sensor DTC Minimum
Oil Pressure Sensor DTC Minimum Voltage
Oil Pressure Sensor Input
Oil Pressure Sensor Inverted
Turbo Speed
Turbo Speed
Measurements
Measurements
Turbo Speed 1 (Left)
Turbo Speed 1 (Left) Sensor Frequency
Turbo Speed 2 (Right)
Turbo Speed 2 (Right) Sensor Frequency
Tunable Parameters
Tunable Parameters
Number of Teeth on Turbo 1 (Left) Wheel
Number of Teeth on Turbo 2 (Right) Wheel
Turbo Speed 1 (Left) Default
Turbo Speed 1 (Left) Filter Coefficient
Turbo Speed 1 (Left) Noise Filter Frequency
Turbo Speed 1 (Left) Noise Threshold
Turbo Speed 1 (Left) Persistent Noise Filter Frequency
Turbo Speed 1 (Left) Persistent Noise Threshold
Turbo Speed 1 (Left) Persistent Noise Time Threshold
Turbo Speed 1 (Left) Sensor DTC Maximum
Turbo Speed 1 (Left) Sensor DTC Maximum Frequency
Turbo Speed 1 (Left) Sensor DTC Minimum
Turbo Speed 1 (Left) Sensor DTC Minimum Frequency
Turbo Speed 1 (Left) Sensor Input
Turbo Speed 1 (Left) Stuck Time Threshold
Turbo Speed 2 (Right) Default
Turbo Speed 2 (Right) Filter Coefficient
Turbo Speed 2 (Right) Noise Filter Frequency
Turbo Speed 2 (Right) Noise Threshold
Turbo Speed 2 (Right) Persistent Noise Filter Frequency
Turbo Speed 2 (Right) Persistent Noise Threshold
Turbo Speed 2 (Right) Persistent Noise Time Threshold
Turbo Speed 2 (Right) Sensor DTC Maximum
Turbo Speed 2 (Right) Sensor DTC Maximum Frequency
Turbo Speed 2 (Right) Sensor DTC Minimum
Turbo Speed 2 (Right) Sensor DTC Minimum Frequency
Turbo Speed 2 (Right) Sensor Input
Turbo Speed 2 (Right) Stuck Time Threshold
Engine Protection
Engine Protection
Deceleration Fuel Cut
Measurements
Measurements
Deceleration Fuel Cut (DFCO) Active
Deceleration Fuel Cut (DFCO) Ignition Retard
Deceleration Fuel Cut (DFCO) Requested
Tunable Parameter
Tunable Parameter
Deceleration Fuel Cut (DFCO) Delay
Deceleration Fuel Cut (DFCO) Disable Ignition Angle Retard
Deceleration Fuel Cut (DFCO) Disable Ignition Retard Recovery Time
Deceleration Fuel Cut (DFCO) Enable Engine Coolant Temperature Minimum
Deceleration Fuel Cut (DFCO) Enable Engine Speed Minimum
Deceleration Fuel Cut (DFCO) Enable Throttle Position
Deceleration Fuel Cut (DFCO) Enabled
Deceleration Fuel Cut (DFCO) Engine Speed Maximum Threshold
Deceleration Fuel Cut (DFCO) Engine Speed Maximum Threshold Hysteresis
Deceleration Fuel Cut (DFCO) Engine Speed Minimum Threshold
Deceleration Fuel Cut (DFCO) Engine Speed Minimum Threshold Hysteresis
Deceleration Fuel Cut (DFCO) Entry Enable MAP
Deceleration Fuel Cut (DFCO) Exit Enable MAP
Fuel Pressure Limiter
Measurements
Measurements
Base Fuel Pressure
Base Fuel Pressure Error
Fuel Pressure Engine Speed Limiter Active
Fuel Pressure Engine Speed (Rev) Limiter Cut Requested
Fuel Pressure Limiter Active
Fuel Pressure Limiter Allowed
Fuel Pressure Limiter Fuel Enrichment
Tunable Parameters
Tunable Parameters
Base Fuel Pressure Setpoint
Fuel Pressure Engine Speed (Rev) Limiter Cut Mode
Fuel Pressure Engine Speed (Rev) Limiter Enabled
Fuel Pressure Limiter Cut Delay
Fuel Pressure Limiter Enable Base Fuel Pressure Error Maximum
Fuel Pressure Limiter Enable Base Fuel Pressure Error Minimum
Fuel Pressure Limiter Enabled
Fuel Pressure Limiter Engine Speed Threshold
Fuel Pressure Limiter Engine Speed Threshold Hysteresis
Fuel Pressure Regulator Type
Hard Limiter
Hard Limiter
Hard Limiter
Measurements
Measurements
Hard Limiter Active
Hard Limiter Map Selected
Hard Limiter State
Tunable Parameters
Tunable Parameters
Hard Limiter Cut Mode
Hard Limiter Engine Speed Threshold Hysteresis (Map 1)
Hard Limiter Engine Speed Threshold Hysteresis Map #2
Hard Limiter Engine Speed Threshold Hysteresis Map #3
Hard Limiter Engine Speed Threshold Hysteresis Map #4
Hard Limiter Engine Speed Threshold (Map #1)
Hard Limiter Engine Speed Threshold Map #2
Hard Limiter Engine Speed Threshold Map #3
Hard Limiter Engine Speed Threshold Map #4
Hard Limiter Time Hysteresis
Launch Control
Launch Control
Launch Control
Measurements
Measurements
Launch Control Active
Launch Control Confirmed
Launch Control Confirmed Time
Launch Control Cut Request
Launch Control Map Selected
Launch Control State
Tunable Parameters
Tunable Parameters
Launch Control Activation Mode
Launch Control Boost Build Engine Speed Threshold
Launch Control Boost Build Engine Speed Threshold Rate Limiter Down
Launch Control Boost Build Engine Speed Threshold Rate Limiter Up
Launch Control Confirm Throttle Position Minimum
Launch Control Cut Mode
Launch Control Enable Throttle Position Minimum (Map #1)
Launch Control Enable Throttle Position Minimum Map #2
Launch Control Enable Throttle Position Minimum Map #3
Launch Control Enable Throttle Position Minimum Map #4
Launch Control Enable Vehicle Speed Maximum (Map #1)
Launch Control Enable Vehicle Speed Maximum Map #2
Launch Control Enable Vehicle Speed Maximum Map #3
Launch Control Enable Vehicle Speed Maximum Map #4
Launch Control Enabled
Launch Control Engine Speed Threshold Hysteresis (Map #1)
Launch Control Engine Speed Threshold Hysteresis Map #2
Launch Control Engine Speed Threshold Hysteresis Map #3
Launch Control Engine Speed Threshold Hysteresis Map #4
Launch Control Engine Speed Threshold (Map #1)
Launch Control Engine Speed Threshold Map #2
Launch Control Engine Speed Threshold Map #3
Launch Control Engine Speed Threshold Map #4
Misfire Detection
Misfire Detection
Measurements
Measurements
Cylinder 1 Misfire Active
Cylinder 1 Misfire Count
Cylinder 2 Misfire Active
Cylinder 2 Misfire Count
Cylinder 3 Misfire Active
Cylinder 3 Misfire Count
Cylinder 4 Misfire Active
Cylinder 4 Misfire Count
Cylinder 5 Misfire Active
Cylinder 5 Misfire Count
Cylinder 6 Misfire Active
Cylinder 6 Misfire Count
Cylinder 7 Misfire Active
Cylinder 7 Misfire Count
Cylinder 8 Misfire Active
Cylinder 8 Misfire Count
Misfire Detection Active
Tunable Parameters
Tunable Parameters
Misfire Detection Activation Delay Cycles
Misfire Detection Enable Minimum Engine Run Time
Misfire Detection Enabled
Misfire Detection Threshold
Nitrous Control
Nitrous Control
Measurements
Measurements
Nitrous (NOS) State
Nitrous (NOS) Active
Nitrous (NOS) Active Duty Cycle
Nitrous (NOS) Bottle Heater Actuator Output Status
Nitrous (NOS) Bottle Heater Control Active
Nitrous (NOS) Control Actuator Output Status
Nitrous (NOS) Control Duty Cycle Gear Correction
Nitrous (NOS) Fuel Enrichment
Nitrous (NOS) Ignition Retard
Nitrous (NOS) Ignition Retard Active
Timed Nitrous (NOS) Active Time
Tunable Parameters
Tunable Parameters
Gear Shift Nitrous (NOS) Control Allowed
Nitrous (NOS) Active Duty Cycle On Delay
Nitrous (NOS) Control Actuator Override
Nitrous (NOS) Control Actuator Override Demand
Nitrous (NOS) Control Hard Limiter Engine Speed Offset
Nitrous (NOS) Fuel Enrichment Off Delay
Nitrous (NOS) Fuel Enrichment On Delay
Nitrous (NOS) Ignition Retard Off Delay
Nitrous (NOS) Ignition Retard On Delay
Nitrous (NOS) Lambda Setpoint Correction
Nitrous (NOS) Active Duty Cycle Rate Limiter Down
Nitrous (NOS) Active Duty Cycle Rate Limiter Up
Nitrous (NOS) Bottle Heater Check Time
Nitrous (NOS) Bottle Heater Control Enabled
Nitrous (NOS) Bottle Heater Disables Nitrous Pressure Threshold
Nitrous (NOS) Bottle Heater Disables Nitrous Pressure Threshold Hysteresis
Nitrous (NOS) Bottle Heater Override
Nitrous (NOS) Control Actuator Output Frequency
Nitrous (NOS) Control Actuator Output Inverted
Nitrous (NOS) Control Duty Cycle Maximum
Nitrous (NOS) Control Duty Cycle Minimum
Nitrous (NOS) Control Enabled
Nitrous (NOS) Control Engine Coolant Temperature Threshold
Nitrous (NOS) Control Engine Coolant Temperature Threshold Hysteresis
Nitrous (NOS) Control Engine Speed Maximum Threshold
Nitrous (NOS) Control Engine Speed Maximum Threshold Hysteresis
Nitrous (NOS) Control Engine Speed Minimum Threshold
Nitrous (NOS) Control Engine Speed Minimum Threshold Hysteresis
Nitrous (NOS) Control Fuel Enrichment Rate Limiter Down
Nitrous (NOS) Control Fuel Enrichment Rate Limiter Up
Nitrous (NOS) Control Ignition Retard Rate Limiter Down
Nitrous (NOS) Control Ignition Retard Rate Limiter Up
Nitrous (NOS) Control Nitrous Pressure Maximum Threshold
Nitrous (NOS) Control Nitrous Pressure Maximum Threshold Hysteresis
Nitrous (NOS) Control Nitrous Pressure Minimum Threshold
Nitrous (NOS) Control Nitrous Pressure Minimum Threshold Hysteresis
Nitrous (NOS) Control Throttle Position Threshold
Nitrous (NOS) Control Throttle Position Threshold Hysteresis
Nitrous (NOS) Control Vehicle Speed Threshold
Nitrous (NOS) Control Vehicle Speed Threshold Hysteresis
Nitrous Pressure Scaled Endpoints
Scramble Nitrous (NOS) Active Duty Cycle Adder
Scramble Nitrous (NOS) Fuel Enrichment Adder
Scramble Nitrous (NOS) Ignition Retard Adder
Timed Nitrous Activation Mode
Timed Nitrous Enable Vehicle Speed Maximum
Timed Nitrous (NOS) Active Duty Cycle
Oil Pressure Limiter
Measurements
Measurements
Oil Pressure Limiter Active
Oil Pressure Limiter Allowed
Oil Pressure Limiter Cut Requested
Tunable Parameters
Tunable Parameters
Oil Pressure Limiter Cut Delay
Oil Pressure Limiter Cut Mode
Oil Pressure Limiter Enabled
Oil Pressure Limiter Engine Run Time Minimum
Oil Pressure Limiter Engine Speed Threshold
Oil Pressure Limiter Engine Speed Threshold Hysteresis
Oil Pressure Scaled Endpoints
Soft Limiter
Soft Limiter
Soft Limiter
Measurements
Measurements
Soft Limiter Active
Soft Limiter Engine Speed Error
Soft Limiter Ignition Retard
Soft Limiter Ignition Retard Active
Soft Limiter Ignition Retard Decay
Soft Limiter Map Selected
Tunable Parameter
Tunable Parameter
Soft Limiter
Soft Limiter Enabled
Soft Limiter Feed Forward (Map 1)
Soft Limiter Feed Forward Map 2
Soft Limiter Feed Forward Map 3
Soft Limiter Feed Forward Map 4
Soft Limiter Ignition Retard Enabled
Soft Limiter Ignition Retard (Map 1)
Soft Limiter Ignition Retard Map 2
Soft Limiter Ignition Retard Map 3
Soft Limiter Ignition Retard Map 4
Soft Limiter Threshold Hysteresis (Map 1)
Soft Limiter Threshold Hysteresis Map 2
Soft Limiter Threshold Hysteresis Map 3
Soft Limiter Threshold Hysteresis Map 4
Soft Limiter Threshold (Map 1)
Soft Limiter Threshold Map 2
Soft Limiter Threshold Map 3
Soft Limiter Threshold Map 4
Engine Status
Engine Status
Cylinder Number
Cylinder Number
Measurements
Measurements
Current Cylinder Number
Engine Position
Data Logging Info
Data Logging Info
Measurements
Measurements
Internal Data Logger Active
Internal Data Logger Storage Used
Diagnostic Check Condition
Measurements
Measurements
Diagnostic Check Condition 1 Active
Diagnostic Check Condition 2 Active
Diagnostic Check Condition 3 Active
Diagnostic Check Condition 4 Active
Tunable Parameters
Tunable Parameters
Diagnostic Check Condition 2 Manifold Absolute Pressure Delta Threshold
Diagnostic Check Condition 2 Manifold Absolute Pressure Delta Threshold Hysteresis
Diagnostic Check Condition 2 Throttle Position Delta Threshold
Diagnostic Check Condition 2 Throttle Position Delta Threshold Hysteresis
Diagnostic Check Condition 4 Minimum Engine Run Time
Engine Speed
Engine Speed
Measurements
Measurements
Engine Speed (RPM)
Engine Speed (RPM) Average
Engine Speed (RPM) Instantaneous
Tunable Parameters
Tunable Parameters
Engine Speed (RPM) Filter Coefficient
Engine State
Engine State
Engine State
Measurements
Measurements
Engine Run Status
Engine Run Time
Engine State
Soak Time
Tunable Parameters
Tunable Parameters
Engine Speed (RPM) Cranking Threshold
Engine Speed (RPM) Ramping Threshold
Engine Speed (RPM) Running Threshold
GPID Expander Status
Measurements
Measurements
Battery Load Dump Status OK
HBridge 1 Load Dump Status OK
HBridge 1 Status OK
HBridge 2 Load Dump Status OK
HBridge 2 Status OK
High Side Driver 1 Status OK
High Side Driver 2 Status OK
High Side Driver 3 Status OK
High Side Driver 4 Status OK
Idle Air Control Valve DTC Active
Idle Air Control Valve EF1 Status OK
Idle Air Control Valve EF2 Status OK
Idle Air Control Valve Fault
Lambda Heater DTC Active
Lambda Sensor 1 Heater Status OK
Lambda Sensor 2 Heater Status OK
Low Side Driver 10 Status OK
Low Side Driver 11 Status OK
Low Side Driver 12 Status OK
Low Side Driver 13 Status OK
Low Side Driver 14 Status OK
Low Side Driver 1 Status OK
Low Side Driver 2 Status OK
Low Side Driver 3 Status OK
Low Side Driver 4 Status OK
Low Side Driver 5 Status OK
Low Side Driver 6 Status OK
Low Side Driver 7 Status OK
Low Side Driver 8 Status OK
Low Side Driver 9 Status OK
Power Supply 5V DTC Active
Power Supply 5V Local Status OK
Power Supply 5V Sensor 1 Status OK
Power Supply 5V Sensor 2 Status OK
Switched 6V Power Status OK
Switched Ignition Load Dump Status OK
Syncrhro State
Syncrhro State
Measurements
Measurements
Current Engine Synchronous Event
Engine Synchronous Event Counter
Virtual Torque
Virtual Torque
Measurements
Measurements
Estimated Engine Torque
Tunable Parameters
Tunable Parameters
Cylinder Airmass Torque Coefficient
Engine Speed Torque Coefficient
Spark Airmass Torque Coefficient
Spark Squared Airmass Torque Coefficient
Spark Squared Torque Coefficient
Spark Torque Coefficient
Synchro State
Virtual Torque
Fuel
Fuel
Closed Loop Lambda
Closed Loop Lambda
Closed Loop Lambda Control
Measurements
Measurements
Lambda Bank 1 Closed Loop Active
Lambda Bank 1 Closed Loop Control State
Lambda Bank 1 Closed Loop Freeze Active
Lambda Bank 1 Correction
Lambda Bank 1 Error
Lambda Bank 1 Integral Gain
Lambda Bank 1 Proportional Term
Lambda Bank 1 Transport Delay
Lambda Bank 2 Closed Loop Active
Lambda Bank 2 Closed Loop Control State
Lambda Bank 2 Closed Loop Freeze Active
Lambda Bank 2 Correction
Lambda Bank 2 Error
Lambda Bank 2 Integral Gain
Lambda Bank 2 Integral Term
Lambda Bank 2 Proportional Term
Lambda Bank 2 Transport Delay
Short Term Fuel Trim Bank 1
Short Term Fuel Trim Bank 2
Tunable Parameters
Tunable Parameters
Closed Loop Lambda Control Enable
Closed Loop Lambda Control Enable Delay
Closed Loop Lambda Control Engine Coolant Temperature Threshold
Closed Loop Lambda Control Engine Coolant Temperature Threshold Hysteresis
Corrections
Lambda Bank 1 Integral Term
Lambda Bank 1 Proportional Gain
Lambda Bank 1 Transport Delay Weighting Factor
Lambda Bank 2 Proportional Gain
Lambda Bank 2 Transport Delay Weighting Factor
Lambda Close Loop Freeze Maximum Threshold
Lambda Close Loop Freeze Minimum Threshold
Lambda Closed Loop Maximum
Lambda Closed Loop Minimum
Lambda Integral Deadband
Lambda Integral Reset Threshold
Lambda Integral Reset Threshold Hysteresis
Lambda Integral Term Maximum
Lambda Integral Term Minimum
Lambda Integrator Enable Maximum Threshold
Lambda Integrator Enable Minimum Threshold
Lambda Proportional Term Maximum
Lambda Proportional Term Minimum
Lambda Transport Delay Integral Deadband
Lambda Transport Delay Integral Gain
Lambda Transport Delay Integral Term Maximum
Lambda Transport Delay Integral Term Minimum
Lambda Transport Delay Proportional Gain
Lambda Transport Delay Proportional Term Maximum
Lambda Transport Delay Proportional Term Minimum
Nitrous Active Lambda Closed Loop Maximum
Nitrous Active Lambda Closed Loop Minimum
Short Term Fuel Trim Filter Coefficient
Corrections
Corrections
Corrections
Measurements
Measurements
Fuel Mass Engine Coolant Temperature Correction
Fuel Mass Intake Air Temperature Correction
Tunable Parameters
Tunable Parameters
Fuel Mass Engine Coolant Temperature Correction Delay
Cylinder Specific Fuel Correction
Cylinder-Specific Fuel Correction
Measurements
Measurements
Cylinder 1 Fuel Correction Request
Cylinder 2 Fuel Correction Request
Cylinder 3 Fuel Correction Request
Cylinder 4 Fuel Correction Request
Cylinder 5 Fuel Correction Request
Cylinder 6 Fuel Correction Request
Cylinder 7 Fuel Correction Request
Cylinder 8 Fuel Correction Request
Tunable Parameters
Tunable Parameters
Flex Fuel
Flex Fuel
Flex Fuel
Measurements
Measurements
Flex Fuel Active
Flex Fuel Composition
Flex Fuel Composition Filtered
Flex Fuel DTC Fault Active
Flex Fuel Sensor Frequency
Tunable Parameters
Tunable Parameters
Flex Fuel Composition DTC Maximum
Flex Fuel Composition DTC Maximum Frequency
Flex Fuel Composition DTC Minimum
Flex Fuel Composition DTC Minimum Frequency
Flex Fuel Composition Lock Cylinder Airmass
Flex Fuel Composition Lock Engine Speed
Flex Fuel Composition Lock Throttle Position
Flex Fuel Composition Sensor Default
Flex Fuel Enabled
Flex Fuel Filter Coefficient
Flex Fuel Sensor Input
Flood Clear
Flood Clear
Flood Clear
Measurements
Measurements
Flood Clear Active
Tunable Parameters
Tunable Parameters
Flood Clear Enabled
Flood Clear Throttle Position Hysteresis
Flood Clear Throttle Position Threshold
Fuel Density
Fuel Density
Measurements
Measurements
Fuel Density Requested
Tunable Parameters
Tunable Parameters
Flex Fuel Density
Fuel Mass
Fuel Mass
Fuel Mass
Measurements
Measurements
Fuel Mass
Stoichiometric Ratio Request
Stoichiometric Ratio Requested
Tunable Parameters
Tunable Parameters
Flex Fuel Stoichiometric Ratio
Fuel Metering
Fuel Metering
Fuel Metering
Measurements
Measurements
Distance Traveled Since Fuel Reset
Distance Traveled Since Last Stop
Distance Traveled Since Trip Reset
Distance Traveled Total
Fuel Consumed Since Fuel Reset
Fuel Consumed Since Last Stop
Fuel Consumed Since Trip Reset
Fuel Consumed Total
Fuel Economy Since Fuel Reset
Fuel Economy Since Last Stop
Fuel Economy Since Trip Reset
Fuel Economy Total
Fuel Mass Consumed Since Fuel Reset
Fuel Mass Consumed Since Last Stop
Fuel Mass Consumed Since Trip Reset
Fuel Mass Consumed Total
Fuel Remain In Tank
Instantaneous Average Fuel Mass
Vehicle Run Time
Tunable Parameters
Tunable Parameters
Fuel Consumed Offset
Fuel Pressure
Fuel Pressure
Measurements
Measurements
Fuel Pressure
Fuel Pressure DTC Fault Active
Fuel Pressure Sensor Voltage
Tunable Parameters
Tunable Parameters
Fuel Pressure Filter Coefficient
Fuel Pressure Scaled Endpoints
Fuel Pressure Sensor DTC Maximum
Fuel Pressure Sensor DTC Maximum Voltage
Fuel Pressure Sensor DTC Minimum
Fuel Pressure Sensor DTC Minimum Voltage
Fuel Pressure Sensor Default
Fuel Pressure Sensor Input
Fuel Pressure Sensor Inverted
Fuel Priming
Fuel Priming
Fuel Priming
Measurements
Measurements
Priming Fuel Mass
Priming Fuel Time
Tunable Parameters
Tunable Parameters
Fuel Priming Enabled
Priming Fuel Mass
Priming Fuel Mass Soak Time Multiplier
Fuel Pump
Fuel Pump
Measurements
Measurements
Fuel Pump Active
Fuel Pump Requested
Second Fuel Pump Active
Second Fuel Pump Requested
Third Fuel Pump Active
Third Fuel Pump Requested
Tunable Parameters
Tunable Parameters
Fuel Pump Actuator Output
Fuel Pump Override Enabled
Fuel Pump Prime Time
Injection Phase Angle
Primary Bank 1 Pulse Width
Second Fuel Pump Actuator Output
Second Fuel Pump Engine Speed Threshold
Second Fuel Pump Engine Speed Threshold Hysteresis
Second Fuel Pump Manifold Absolute Pressure Threshold
Second Fuel Pump Manifold Absolute Pressure Threshold Hysteresis
Second Fuel Pump Override
Second Fuel Pump Prime Time
Second Fuel Pump Throttle Position Threshold
Second Fuel Pump Throttle Position Threshold Hysteresis
Third Fuel Pump Actuator Output
Third Fuel Pump Engine Speed Threshold
Third Fuel Pump Engine Speed Threshold Hysteresis
Third Fuel Pump Manifold Absolute Pressure Threshold
Third Fuel Pump Manifold Absolute Pressure Threshold Hysteresis
Third Fuel Pump Override
Third Fuel Pump Prime Time
Third Fuel Pump Throttle Position Threshold
Third Fuel Pump Throttle Position Threshold Hysteresis
Individual Cylinder Fuel Correction
Measurements
Measurements
Individual Cylinder Fuel Correction Average
Tunable Parameters
Tunable Parameters
Individual Cylinder Fuel Correction Enabled
Individual Cylinder Ignition Correction Enabled
Injection Time
Injection Time
Measurements
Measurements
Bank 1 Primary Injection Time Request
Bank 1 Secondary Injection Time Request
Bank 2 Primary Injection Time Request
Bank 2 Secondary Injection Time Request
Closed Loop Lambda Correction
Primary Bank 1 Fuel Mass
Primary Bank 1 Injector Duty Cycle
Primary Bank 2 Fuel Mass
Primary Bank 2 Injector Duty Cycle
Primary Bank 2 Pulse Width
Secondary Bank 1 Fuel Mass
Secondary Bank 1 Injector Duty Cycle
Secondary Bank 1 Pulse Width
Secondary Bank 2 Fuel Mass
Secondary Bank 2 Injector Duty Cycle
Secondary Bank 2 Pulse Width
Tunable Parameters
Tunable Parameters
Lambda Sensor Cylinder Selection
Maximum Pulse Width Correction
Pressure Reference Selection
Primary Pulse Width Minimum
Primary Short Pulse Adder
Primary Short Pulse Limit
Secondary Pulse Width Minimum
Secondary Short Pulse Adder
Secondary Short Pulse Limit
Injector Characteristics
Measurements
Measurements
Manifold Vacuum
Primary Injector Dead Time
Primary Injector Flow Rate
Secondary Injector Dead Time
Secondary Injector Flow Rate
Tunable Parameters
Tunable Parameters
Injector Cut
Injector Cut
Measurements
Measurements
Secondary Injector Active
Injector Fault
Injector Fault
Measurements
Measurements
Injector 10 Fault
Injector 11 Fault
Injector 12 Fault
Injector 13 Fault
Injector 14 Fault
Injector 15 Fault
Injector 16 Fault
Injector 1 Fault
Injector 2 Fault
Injector 3 Fault
Injector 4 Fault
Injector 5 Fault
Injector 6 Fault
Injector 7 Fault
Injector 8 Fault
Injector 9 Fault
Injector Fault
Injector Phase Angle
Measurements
Measurements
Primary Injection Phase Angle Request
Secondary Injection Phase Angle Request
Tunable Parameters
Tunable Parameters
Injector Target Demand
Measurements
Measurements
Injection Cut Source
Maximum Pulse Width Limiter Active
Primary Injection #1 Time Demanded
Primary Injection #2 Time Demanded
Primary Injection #3 Time Demanded
Primary Injection #4 Time Demanded
Primary Injection #5 Time Demanded
Primary Injection #6 Time Demanded
Primary Injection #7 Time Demanded
Primary Injection #8 Time Demanded
Primary Injection Phase Angle Demanded
Primary Injection Time Average
Primary Injector #1 Active
Primary Injector #2 Active
Primary Injector #3 Active
Primary Injector #4 Active
Primary Injector #5 Active
Primary Injector #6 Active
Primary Injector #7 Active
Primary Injector #8 Active
Primary Injector Duty Cycle Average
Primary Injector # Of Cylinders Active
Secondary Injection #1 Time Demanded
Secondary Injection #2 Time Demanded
Secondary Injection #3 Time Demanded
Secondary Injection #4 Time Demanded
Secondary Injection #5 Time Demanded
Secondary Injection #6 Time Demanded
Secondary Injection #7 Time Demanded
Secondary Injection #8 Time Demanded
Secondary Injection Phase Angle Demanded
Secondary Injection Time Average
Secondary Injector #1 Active
Secondary Injector #2 Active
Secondary Injector #3 Active
Secondary Injector #4 Active
Secondary Injector #5 Active
Secondary Injector #6 Active
Secondary Injector #7 Active
Secondary Injector #8 Active
Secondary Injector Duty Cycle Average
Secondary Injector # Of Cylinders Active
Traction Control Primary Injection Cut Demanded
Traction Control Secondary Injection Cut Demanded
Tunable Parameters
Tunable Parameters
Injector #1 Enabled
Injector #2 Enabled
Injector #3 Enabled
Injector #4 Enabled
Injector #5 Enabled
Injector #6 Enabled
Injector #7 Enabled
Injector #8 Enabled
Lambda Control
Lambda Control
Lambda Control
Measurements
Measurements
After Start Enrichment Active
Lambda Setpoint
Lambda Setpoint Map Selected
Running Lambda Setpoint
Tunable Parameters
Tunable Parameters
After Start Enrichment Activation Delay
After Start Enrichment Decay Delay
After Start Enrichment Lambda Setpoint
Cranking Commanded Fuel Enleanment
Cranking Lambda Setpoint
Lambda Reading Selection Mode
Power Enrichment Blending Step
Power Enrichment Cold Throttle Position Threshold
Power Enrichment Hot Select Threshold
Power Enrichment Hot Throttle Position Threshold
Power Enrichment Manifold Absolute Pressure Threshold
Power Enrichment Manifold Absolute Pressure Threshold Hysteresis
Running Lambda Setpoint Engine Coolant Temperature Correction
Running Lambda Setpoint Intake Air Temperature Correction
Running Lambda Setpoint Map 1
Running Lambda Setpoint Map 2
Running Lambda Setpoint Map 3
Running Lambda Setpoint Map 4
Running Lambda Startup Delay
Pulse Width Limiter
Pulse Width Limiter
Tunable Parameters
Tunable Parameters
Maximum Pulse Width Engine Speed (Rev) Limiter Cut Mode
Maximum Pulse Width Limiter Enabled
Maximum Pulse Width Limiter Engine Speed Threshold
Maximum Pulse Width Limiter Engine Speed Threshold Hysteresis
Maximum Pulse Width Limiter Throttle Position
Secondary Fueling
Secondary Fueling
Secondary Fueling
Measurements
Measurements
Fuel Mass Split Ratio (Measurement)
Primary Fuel Mass
Primary Fuel Mass to Cylinder Request
Secondary Fuel Mass
Secondary Fuel Mass to Cylinder Request
Secondary Fueling Active
Tunable Parameters
Tunable Parameters
Fuel Mass Split Ratio Offset
Secondary X-Tau Maximum Acceleration Enrichment
Secondary X-Tau Maximum Deceleration Enleanment
Twin Injection X-Tau (Acceleration Enrichment) Fuel Split Mode
X Tau Direct
X Tau Direct
X-Tau Direct
Measurements
Measurements
Injection Fuel Mass Predicted
Puddle Fuel Mass
Tau
Transient Fuel Compensation Mass
Transient Fuel Compensation (TFC) Mass Corrected
X-Tau Acceleration Active
X-Tau Deceleration Active
X
Tunable Parameters
Tunable Parameters
Minimum X-Tau Enable Acceleration Pedal Position
Secondary Tau Acceleration Time Factor
Secondary Tau Deceleration Time Factor
Secondary X Acceleration Puddling Factor
Secondary X Deceleration Puddling Factor
Tau Time Factor Engine Coolant Temperature Correction
X-Tau Acceleration MAP Rate Threshold
X-Tau Active
X-Tau Allowed
X-Tau Deceleration MAP Rate Threshold
X-Tau Deceleration Transient Enabled
X-Tau Direct Enabled
X-Tau Enable Throttle Position Derivative Threshold
X-Tau Enable Throttle Position Derivative Threshold Hysteresis
X Puddling Factor Engine Coolant Temperature Correction
X Tau Accel/Decel Ratio
X Tau Enable Manifold Absolute Pressure Derivative Threshold
X Tau Enable Manifold Absolute Pressure Derivative Threshold Hysteresis
X Tau Maximum Acceleration Enrichment
X Tau Maximum Deceleration Enleanment
Idle
Idle
Idle Control Demands
Idle Control Demand
Measurements
Measurements
Idle Active
Idle Active Hysteresis
Idle Active Threshold
Idle Active Threshold Multiplier
Idle Speed Setpoint (Measurement)
Idle Trajectory Error
Tunable Parameters
Tunable Parameters
Idle Active Engine Speed Startup Threshold
Idle Active Engine Speed Threshold
Idle Active Engine Speed Threshold Hysteresis
Idle Active Engine Speed Threshold Multiplier
Idle Active Engine Speed Threshold Rate Limiter Down
Idle Active Engine Speed Threshold Rate Limiter Up
Idle Airflow Integral Gain (Airflow)
Idle Airflow Proportional Gain (Airflow)
Idle Ignition Angle Control (Ignition Angle)
Idle Speed Setpoint
Maximum Throttle Position Delta for Idle Enable
Maximum Throttle Position for Idle Enable
Park Idle Ignition Angle Control (Ignition Angle)
Park Idle Speed Setpoint
Idle Normalization
Idle Normalization
Idle Normalization
Measurements
Measurements
Idle Airflow Control Steps
Idle Airflow Percentage
Idle Airflow Requested
Idle Desired Airflow
Idle Ignition Angle Control (Ignition Angle) (Measurement)
Idle Ignition Requested
Idle Integral Term
Tunable Parameters
Tunable Parameters
Idle Airflow Control Delay (Airflow)
Idle Airflow Control Enabled (Airflow)
Idle Airflow Integral Deadband
Idle Airflow Integral Term Maximum
Idle Airflow Integral Term Minimum
Idle Airflow Percentage Maximum
Idle Airflow Percentage (Measurement)
Idle Airflow Percentage Minimum
Idle Airflow Proportional Term Maximum
Idle Airflow Proportional Term Minimum
Idle Airflow Rate Limiter Down
Idle Airflow Rate Limiter Up
Idle Enable Acceleration Pedal Position Delta Maximum
Idle Enable Acceleration Pedal Position Maximum
Idle Ignition Angle Control Maximum
Idle Ignition Angle Control Minimum
Idle Ignition Control Delay (Ignition Angle)
Park Idle Airflow Percentage
Percentage Airflow to IAC Counts Conversion
Percentage Airflow to Idle Throttle Conversion
Reverse Gear Idle Airflow Percentage Adder
Running Idle Airflow Multiplier
Startup Idle Airflow Percentage
Idle Target Demands
Idle Target Demands
Measurements
Measurements
Idle Air Control Calibrate Active
Installation
Installation
Engine Configuration
Tunable Parameters
Tunable Parameters
CAM Sensor Type
Crank CAM Offset
Crank Sensor Type
Crank Trigger Edge
Input Shaft Speed Sensor Fitted
Lambda Mode
Reluctor Wheel Type
TDC Offset
Twin Injection Enabled
Fitted Flags
Fitted Flags
Tunable Parameters
Tunable Parameters
Acceleration Pedal 1 Position 1 Fitted
Acceleration Pedal 2 Position 1 Fitted
Air Conditioner Refrigerant Pressure
Boost Arming Switch Sensor Fitted
Clutch Pedal Sensor Fitted
First Stage Fan Fitted
Flex Sensor Fitted
Front Brake Pressure Sensor Fitted
Front Wheel 1 Speed Sensor Fitted
Front Wheel 2 Speed Sensor Fitted
Fuel Pressure Sensor Fitted
Gear Selector Sensors Fitted
Intake Air Temperature Sensor Fitted
Intercooler Pump Fitted
Knock Bank #1 Sensor Fitted
Knock Bank #2 Sensor Fitted
Manifold Absolute Pressure Sensor Fitted
Map Selection Switch Fitted
Mass Airflow Fitted
Neutral Position Switch Sensor Fitted
Nitrous Pressure Sensor Fitted
Oil Pressure Sensor Fitted
Rear Brake Pressure Sensor Fitted
Rear Wheel 1 Speed Sensor Fitted
Rear Wheel 2 Speed Sensor Fitted
Reverse Lock-Out Fitted
Second Stage Fan Fitted
Secondary Fuel Pump Fitted
Speedometer Gauge Fitted
Tachometer Gauge Fitted
Third Fuel Pump Fitted
Throttle Position Sensor 1 Fitted
Throttle Position Sensor 2 Fitted
Traction Control Arming Switch Fitted
Trans-Brake Arming Switch Fitted
Transmission Line Pressure Sensor Fitted
Transmission Oil Temperature Sensor Fitted
Transmission Shift Mode Arming Switch Fitted
Turbo Speed Sensor 1 Fitted
Turbo Speed Sensor 2 Fitted
Vehicle Speed Sensor Fitted
Knock
Knock
Knock Characteristics
Measurements
Measurements
Cylinder #1 Knock Detection Threshold (Measurement)
Cylinder #2 Knock Detection Threshold (Measurement)
Cylinder #3 Knock Detection Threshold (Measurement)
Cylinder #4 Knock Detection Threshold (Measurement)
Cylinder #5 Knock Detection Threshold (Measurement)
Cylinder #6 Knock Detection Threshold (Measurement)
Cylinder #7 Knock Detection Threshold (Measurement)
Cylinder #8 Knock Detection Threshold (Measurement)
Knock Detection Active
Knock Retard Limit (Measurement)
Tunable Parameters
Tunable Parameters
Knock Control Enabled
Knock Retard Limit
Knock Retard Limit (Power Enrichment Mode)
Knock Configuration
Knock Configuration
Tunable Parameters
Tunable Parameters
Cylinder #1 Knock Gain
Cylinder #2 Knock Gain
Cylinder #3 Knock Gain
Cylinder #4 Knock Gain
Cylinder #5 Knock Gain
Cylinder #6 Knock Gain
Cylinder #7 Knock Gain
Cylinder #8 Knock Gain
Knock Bandpass Center Frequency
Knock Gain
Knock Sensor Types
Knock Start Window ATDC
Knock Stop Window ATDC
Knock Time Constant
Knock Detection
Knock Detection
Knock Detection
Measurements
Measurements
Ignition Knock Occurring Cylinder #1
Ignition Knock Occurring Cylinder #2
Ignition Knock Occurring Cylinder #3
Ignition Knock Occurring Cylinder #4
Ignition Knock Occurring Cylinder #5
Ignition Knock Occurring Cylinder #6
Ignition Knock Occurring Cylinder #7
Ignition Knock Occurring Cylinder #8
Ignition Knock Retard Active Cylinder #1
Ignition Knock Retard Active Cylinder #2
Ignition Knock Retard Active Cylinder #3
Ignition Knock Retard Active Cylinder #4
Ignition Knock Retard Active Cylinder #5
Ignition Knock Retard Active Cylinder #6
Ignition Knock Retard Active Cylinder #7
Ignition Knock Retard Active Cylinder #8
Ignition Knock Retard Cylinder #1
Ignition Knock Retard Cylinder #2
Ignition Knock Retard Cylinder #3
Ignition Knock Retard Cylinder #4
Ignition Knock Retard Cylinder #5
Ignition Knock Retard Cylinder #6
Ignition Knock Retard Cylinder #7
Ignition Knock Retard Cylinder #8
Tunable Parameters
Tunable Parameters
Ignition Knock Cooling Cycles
Ignition Knock Retard Feed Forward
Ignition Knock Retard First Step Offset
Ignition Knock Retard Proportional Gain
Ignition Knock Retard Recovery
Knock Control Enable Engine Speed Maximum
Knock Control Enable Engine Speed Minimum
Knock Control Enable Manifold Absolute Pressure Maximum
Knock Control Enable Manifold Absolute Pressure Minimum
Knock Detection Activation Delay Cycles
Knock Detection Threshold Hysteresis
Knock Sensor
Knock Sensor
Measurements
Measurements
Knock Count Read
Knock Sensor Voltage Cylinder #1
Knock Sensor Voltage Cylinder #2
Knock Sensor Voltage Cylinder #3
Knock Sensor Voltage Cylinder #4
Knock Sensor Voltage Cylinder #5
Knock Sensor Voltage Cylinder #6
Knock Sensor Voltage Cylinder #7
Knock Sensor Voltage Cylinder #8
Knock Voltage
Knock Voltage
Measurements
Measurements
Knock Bank #1 DTC Fault Active
Knock Bank #2 DTC Fault Active
Tunable Parameters
Tunable Parameters
Knock Bank 1 Sensor DTC Maximum Voltage
Knock Bank 1 Sensor DTC Minimum Voltage
Knock Bank 1 Sensor Default
Knock Bank 2 Sensor DTC Maximum Voltage
Knock Bank 2 Sensor DTC Minimum Voltage
Knock Bank 2 Sensor Default
Knock Sensor Voltage Filter Frequency
Spark
Spark
Spark
Cylinder Specific Ignition Correction
Cylinder-Specific Ignition Correction
Measurements
Measurements
Cylinder #1 Ignition Correction Request
Cylinder #2 Ignition Correction Request
Cylinder #3 Ignition Correction Request
Cylinder #4 Ignition Correction Request
Cylinder #5 Ignition Correction Request
Cylinder #6 Ignition Correction Request
Cylinder #7 Ignition Correction Request
Cylinder #8 Ignition Correction Request
Tunable Parameters
Tunable Parameters
Dwell Time
Dwell Time
Dwell Time
Measurements
Measurements
Dwell Time Requested
Tunable Parameters
Tunable Parameters
Base Dwell Time
Base Dwell Time Modifier
Dwell Time Manifold Absolute Pressure Correction
Dwell Time Maximum Limit
Dwell Time Minimum Limit
Ignition Angle
Ignition Angle
Ignition Angle
Measurements
Measurements
Base Ignition Angle
Base Ignition Angle Map Selected
Ignition Angle Average
Ignition Angle Requested
Tunable Parameters
Tunable Parameters
Base Ignition Angle (Map #1)
Base Ignition Angle Map #2
Base Ignition Angle Map #3
Base Ignition Angle Map #4
Cranking Ignition Angle
Flex Fuel Base Ignition Angle Blending (Map #1)
Flex Fuel Base Ignition Angle Blending Map #2
Flex Fuel Base Ignition Angle Blending Map #3
Flex Fuel Base Ignition Angle Blending Map #4
Flex Fuel Base Ignition Angle Map #1 (High Octane)
Flex Fuel Base Ignition Angle Map #2 (High Octane)
Flex Fuel Base Ignition Angle Map #3 (High Octane)
Flex Fuel Base Ignition Angle Map #4 (High Octane)
Idle Ignition Angle
Ignition Angle ECT Correction
Ignition Angle ECT Correction Multiplier
Ignition Angle IAT Correction
Ignition Angle IAT Correction Multiplier
Ignition Angle Maximum Limit
Ignition Angle Minimum Limit
Ignition Cut
Ignition Cut
Ignition Cut
Measurements
Measurements
Ignition Active
Ignition Target Demand
Measurements
Measurements
Ignition #1 Active
Ignition #2 Active
Ignition #3 Active
Ignition #4 Active
Ignition #5 Active
Ignition #6 Active
Ignition #7 Active
Ignition #8 Active
Ignition - # of Cylinders Active
Ignition Angle #1 Demanded
Ignition Angle #2 Demanded
Ignition Angle #3 Demanded
Ignition Angle #4 Demanded
Ignition Angle #5 Demanded
Ignition Angle #6 Demanded
Ignition Angle #7 Demanded
Ignition Angle #8 Demanded
Traction Control Ignition Cut Demanded
Tunable Parameters
Tunable Parameters
Dwell Time Demanded
Ignition #1 Enabled
Ignition #2 Enabled
Ignition #3 Enabled
Ignition #4 Enabled
Ignition #5 Enabled
Ignition #6 Enabled
Ignition #7 Enabled
Ignition #8 Enabled
Ignition Angle Override Demand
Ignition Angle Override Enabled
Ignition Cut Source
Nitrous Deactivation Ignition Cut Delay Cycles
Individual Cylinder Ignition Correction Average
Shift Ignition Cut
Shift Ignition Cut
Shift Ignition Cut
Measurements
Measurements
Gear Shift Ignition Retard
Normal Mode Gear Shift Ignition Retard
Performance Mode Gear Shift Ignition Retard
Tunable Parameters
Tunable Parameters
Normal Mode Down Shift Ignition Retard 2 To 1
Normal Mode Down Shift Ignition Retard 3 To 2
Normal Mode Down Shift Ignition Retard 4 To 3
Normal Mode Down Shift Ignition Retard Delay
Normal Mode Gear Shift Ignition Retard Rate Limiter Down
Normal Mode Gear Shift Ignition Retard Rate Limiter Up
Normal Mode Up Shift Ignition Retard 1 To 2
Normal Mode Up Shift Ignition Retard 2 To 3
Normal Mode Up Shift Ignition Retard 3 To 4
Normal Mode Up Shift Ignition Retard Delay
Performance Mode Down Shift Ignition Retard 2 To 1
Performance Mode Down Shift Ignition Retard 3 To 2
Performance Mode Down Shift Ignition Retard 4 To 3
Performance Mode Down Shift Ignition Retard Delay
Performance Mode Gear Shift Ignition Retard Rate Limiter Down
Performance Mode Gear Shift Ignition Retard Rate Limiter Up
Performance Mode Up Shift Ignition Retard 1 To 2
Performance Mode Up Shift Ignition Retard 2 To 3
Performance Mode Up Shift Ignition Retard 3 To 4
Performance Mode Up Shift Ignition Retard Delay
Turbolamik Transmission Ignition Retard
Throttle
Throttle
Pedal Request
Pedal Request
Pedal Request
Mesurements
Mesurements
Throttle Position Requested Via Accelerator Pedal
Throttle Position Requested Via Pedal Map Selected
Tunable Parameters
Tunable Parameters
Throttle Position Per Accelerator Pedal Request (Map #1)
Throttle Position Per Accelerator Pedal Request Map #2
Throttle Position Per Accelerator Pedal Request Map #3
Throttle Position Per Accelerator Pedal Request Map #4
Stuck Throttle
Stuck Throttle
Stuck Throttle
Measurements
Measurements
Stuck Throttle Cut Requested
Stuck Throttle Position Error
Stuck Throttle Security Active
Tunable Parameters
Tunable Parameters
Stuck Throttle Cut Delay
Stuck Throttle Position Activation Delay
Stuck Throttle Position Error Threshold
Stuck Throttle Security Enabled
Throttle Position Automatic Calibration
Measurements
Measurements
Throttle Position 1 Sensor (TPS 1) Voltage Full Close
Throttle Position 1 Sensor (TPS 1) Voltage Full Open
Throttle Position 2 Sensor (TPS 2) Voltage Full Close
Throttle Position 2 Sensor (TPS 2) Voltage Full Open
Throttle Position Automatic Calibration Active
Throttle Position Automatic Calibration Demand
Throttle Position Automatic Calibration Duty Cycle Demand
Throttle Position Automatic Calibration Enabled
Throttle Position Automatic Calibration Pre-Check Successful
Throttle Position Automatic Calibration Start Successful
Throttle Position Automatic Calibration State
Throttle Position Automatic Calibration Terminated
Throttle Position Automatic Calibration Type
Tunable Parameters
Tunable Parameters
Throttle Position (TPS) Correlation Activation Delay
Throttle Position (TPS) Correlation Error Threshold
Throttle Position Automatic Calibration Demand Rate Limiter Down
Throttle Position Automatic Calibration Demand Rate Limiter Up
Throttle Position Regulation
Measurements
Measurements
Electronic Throttle 1 (DBW) Position
Electronic Throttle 2 (DBW) Position
Secondary Demanded Throttle Position (ETC)
Secondary Throttle Position (ETC) Derivative Term
Secondary Throttle Position (ETC) Error
Secondary Throttle Position (ETC) Feed Forward Term
Secondary Throttle Position (ETC) Integral Term
Secondary Throttle Position (ETC) Proportional Term
Throttle Position Demanded
Throttle Position Derivative Term
Throttle Position Feed Forward Term
Throttle Position Integral Term
Throttle Position Proportional Term
Wide Open Throttle Active
Tunable Parameters
Tunable Parameters
Electronic Throttle Close Loop Maximum
Electronic Throttle Close Loop Minimum
Electronic Throttle Control Integral Enable Maximum Threshold
Electronic Throttle Control Integral Enable Minimum Threshold
Electronic Throttle Derivative Filter Enabled
Electronic Throttle Derivative Filter Frequency
Electronic Throttle Derivative Gain
Electronic Throttle Derivative Term Maximum
Electronic Throttle Derivative Term Minimum
Electronic Throttle Dither Amplitude
Electronic Throttle Dither Disable Threshold
Electronic Throttle Dither Enable Hysteresis
Electronic Throttle Dither Enabled
Electronic Throttle Dither Frequency
Electronic Throttle Feed Forward
Electronic Throttle Integral Deadband
Electronic Throttle Integral Gain
Electronic Throttle Integral Reset Request
Electronic Throttle Integral Reset Value
Electronic Throttle Integral Term Maximum
Electronic Throttle Integral Term Minimum
Electronic Throttle Proportional Gain
Electronic Throttle Proportional Term Maximum
Electronic Throttle Proportional Term Minimum
Throttle Body (TPS) Type
Wide Open Throttle Threshold
Wide Open Throttle Threshold Hysteresis
Throttle Position Sensor (TPS)
Measurements
Measurements
Throttle (TPS) Limp Control Requested
Throttle Position
Throttle Position #1 (TPS 1) DTC Fault Active
Throttle Position #2 (TPS 2) DTC Fault Active
Tunable Parameters
Tunable Parameters
Throttle Position 1 (TPS 1) Filter Frequency
Throttle Position 1 (TPS 1) Scaled Endpoints
Throttle Position 1 (TPS 1) Sensor Input
Throttle Position 1 Sensor (TPS 1) DTC Maximum
Throttle Position 1 Sensor (TPS 1) DTC Maximum Volts
Throttle Position 1 Sensor (TPS 1) DTC Minimum
Throttle Position 1 Sensor (TPS 1) DTC Minimum Volts
Throttle Position 2 (TPS 2) Filter Frequency
Throttle Position 2 (TPS 2) Scaled Endpoints
Throttle Position 2 (TPS 2) Sensor Input
Throttle Position 2 Sensor (TPS 2) DTC Maximum
Throttle Position 2 Sensor (TPS 2) DTC Maximum Volts
Throttle Position 2 Sensor (TPS 2) DTC Minimum
Throttle Position 2 Sensor (TPS 2) DTC Minimum Volts
Throttle Sensor Error Position
Throttle Target
Throttle Target
Throttle Target
Measurements
Measurements
Electronic Throttle 1 (DBW) Output Status
Electronic Throttle 2 (DBW) Output Status
Maximum Torque Demand Source
Throttle Position Setpoint
Traction Control Throttle Position Cut Demanded
Tunable Parameters
Tunable Parameters
Electronic Throttle Position Maximum
Pedal Rate Limit Down
Pedal Rate Limit Up
Throttle Position Setpoint Override Enabled
Throttle Position Setpoint Override Value
Throttle Target Demand
Measurements
Measurements
Electronic Throttle Actuator 2 Source Duty Cycle
Electronic Throttle Actuator Source Duty Cycle
Electronic Throttle Inhibit Mode Active
Electronic Throttle Override DTC Active
Tunable Parameters
Tunable Parameters
Electronic Throttle Actuator (H-Bridge) Output Frequency
Electronic Throttle Actuator (H-Bridge) Output Inverted
Electronic Throttle Actuator 2 (H-Bridge 2) Output Frequency
Electronic Throttle Actuator 2 (H-Bridge 2) Output Inverted
Electronic Throttle Actuator 2 Duty Cycle Correction
Electronic Throttle Actuator 2 Output
Electronic Throttle Actuator Output
Electronic Throttle Control Inhibit Manual
Electronic Throttle Override Demand
Electronic Throttle Override Enabled
Traction Control
Traction Control
Intelligent Traction Control
Tunable Parameters
Tunable Parameters
AI Traction Control Slip Setpoint
Target Wheel Spin
Slip Calculation
Slip Calculation
Measurements
Measurements
Slip
Tunable Parameters
Tunable Parameters
Drive Type
Traction Control Cut
Traction Control Current Cylinder Number Ignition Cut
Traction Control Current Cylinder Number Injection Cut
Traction Control Current Synchronous Event
Traction Control Cylinder 1 Ignition Cut Active
Traction Control Cylinder 1 Injection Cut Active
Traction Control Cylinder 2 Ignition Cut Active
Traction Control Cylinder 2 Injection Cut Active
Traction Control Cylinder 3 Ignition Cut Active
Traction Control Cylinder 3 Injection Cut Active
Traction Control Cylinder 4 Ignition Cut Active
Traction Control Cylinder 4 Injection Cut Active
Traction Control Cylinder 5 Ignition Cut Active
Traction Control Cylinder 5 Injection Cut Active
Traction Control Cylinder 6 Ignition Cut Active
Traction Control Cylinder 6 Injection Cut Active
Traction Control Cylinder 7 Ignition Cut Active
Traction Control Cylinder 7 Injection Cut Active
Traction Control Cylinder 8 Ignition Cut Active
Traction Control Cylinder 8 Injection Cut Active
Traction Control Cylinder Ignition Cut Count (# of Cylinder to Cut)
Traction Control Cylinder Ignition Cut Count Requested
Traction Control Cylinder Injection Cut Count (# of Cylinder to Cut)
Traction Control Cylinder Injection Cut Count Requested
Traction Control Ignition Cut Active
Traction Control Ignition Retard
Traction Control Injection Cut Active
Traction Control Throttle Position Correction
Traction Control Wastegate Duty Cycle Correction
Traction Control Demand
Measurements
Measurements
Slip Error
Slip Setpoint
Traction Control Allowed
Traction Control Cut Active
Traction Control Freeze Active
Traction Control Integral Gain
Traction Control Proportional Gain
Tunable Parameters
Tunable Parameters
Slip Setpoint
Slip Setpoint Threshold Hysteresis
Traction Control Engine Speed Threshold
Traction Control Engine Speed Threshold Hysteresis
Traction Control Mode
Traction Control Throttle Position Threshold
Traction Control Throttle Position Threshold Hysteresis
Traction Control Vehicle Speed Threshold
Traction Control Vehicle Speed Threshold Hysteresis
Traction Control Regulation
Measurements
Measurements
Traction Control Active
Traction Control Feed Forward Term
Traction Control Integral Term
Traction Control Proportional Term
Traction Control Slip Correction
Traction Control Slip Requested
Tunable Parameters
Tunable Parameters
Traction Control Closed Loop Maximum
Traction Control Closed Loop Minimum
Traction Control Integral Deadband
Traction Control Integral Term Maximum
Traction Control Integral Term Minimum
Traction Control Proportional Term Maximum
Traction Control Proportional Term Minimum
Traction Control Slip Correction Maximum
Traction Control Slip Correction Minimum
Transmission
Transmission
Clutch Pedal
Clutch Pedal
Measurements
Measurements
Clutch Pedal Active
Clutch Pedal Sensor Voltage
Tunable Parameters
Tunable Parameters
Clutch Pedal Sensor Default
Clutch Pedal Sensor Input
Clutch Pedal Sensor Inverted
Gear Selection Demand
Measurements
Measurements
Drive Gear Downshift 3 To 2 Actuator Duty Cycle
Drive Gear Downshift 3 To 2 Actuator Output Status
Drive Gear Selection Actuator #1 Duty Cycle
Drive Gear Selection Actuator #1 Source Status
Drive Gear Selection Actuator #2 Duty Cycle
Drive Gear Selection Actuator #2 Output Status
Tunable Parameters
Tunable Parameters
Drive Gear 1 Actuator #1 Status
Drive Gear 1 Actuator #2 Status
Drive Gear 2 Actuator #1 Status
Drive Gear 2 Actuator #2 Status
Drive Gear 3 Actuator #1 Status
Drive Gear 3 Actuator #2 Status
Drive Gear 4 Actuator #1 Status
Drive Gear 4 Actuator #2 Status
Drive Gear Downshift 3 To 2 Actuator Output Frequency
Drive Gear Selection Demand #1 Actuator Output
Drive Gear Selection Demand #1 Actuator Output Frequency
Drive Gear Selection Demand #2 Actuator Output
Drive Gear Selection Demand #2 Actuator Output Frequency
Gear Selector
Gear Selector
Measurements
Measurements
Gear Selector 1 Sensor Status
Gear Selector 2 Sensor Status
Gear Selector 3 Sensor Status
Gear Selector Position
Voltage Based Gear Selector Sensor Voltage
Tunable Parameters
Tunable Parameters
Gear Selector #1 Sensor Input
Gear Selector #2 Sensor Input
Gear Selector #3 Sensor Input
Gear Selector Type
Voltage Based Gear Selector Gear 1 Voltage
Voltage Based Gear Selector Gear 2 Voltage
Voltage Based Gear Selector Gear 3 Voltage
Voltage Based Gear Selector Gear 4 Voltage
Voltage Based Gear Selector Gear 5 Voltage
Voltage Based Gear Selector Gear 6 Voltage
Voltage Based Gear Selector Gear 7 Voltage
Voltage Based Gear Selector Gear 8 Voltage
Voltage Based Gear Selector Gear Neutral Voltage
Voltage Based Gear Selector Gear Park Voltage
Voltage Based Gear Selector Gear Reverse Voltage
Voltage Based Gear Selector Sensor Input
Voltage Based Gear Selector Tolerance Voltage
Input Shaft
Input Shaft
Measurements
Measurements
Input Shaft Speed (ISS)
Input Shaft Speed (ISS) Sensor Frequency
Tunable Parameters
Tunable Parameters
Input Shaft Speed (ISS) Default
Input Shaft Speed (ISS) Filter Coefficient
Input Shaft Speed (ISS) Noise Filter Frequency
Input Shaft Speed (ISS) Noise Threshold
Input Shaft Speed (ISS) Persistent Noise Filter Frequency
Input Shaft Speed (ISS) Persistent Noise Threshold
Input Shaft Speed (ISS) Persistent Noise Time Threshold
Input Shaft Speed (ISS) Sensor DTC Maximum
Input Shaft Speed (ISS) Sensor DTC Maximum Frequency
Input Shaft Speed (ISS) Sensor DTC Minimum
Input Shaft Speed (ISS) Sensor DTC Minimum Frequency
Input Shaft Speed (ISS) Sensor Input
Input Shaft Speed (ISS) Stuck Time Threshold
Number of Teeth on Input Shaft Speed (ISS)
Line Pressure Demand
Measurements
Measurements
Line Pressure Actuator Duty Cycle
Line Pressure Actuator Output Status
Tunable Parameters
Tunable Parameters
Line Pressure (Trans Pr) Actuator Output Inverted
Line Pressure (Trans Pr) Actuator Override
Line Pressure (Trans Pr) Actuator Override Demand
Line Pressure (Trans Rx) Actuator Output
Line Pressure (Trans Rx) Actuator Output Frequency
Manual Transmission Drive Gear
Measurements
Measurements
Gear Ratio Delta
Manual Trans Gear Detection Active
Manual Transmission Active Gear
Manual Transmission Gear Ratio
Neutral Position Switch Sensor Status
Neutral Position Switch Sensor Voltage
Tunable Parameters
Tunable Parameters
Gear Ratio Delta Threshold
Gear Ratio Delta Threshold Hysteresis
Manual Transmission Gear Ratio #1
Manual Transmission Gear Ratio #2
Manual Transmission Gear Ratio #3
Manual Transmission Gear Ratio #4
Manual Transmission Gear Ratio #5
Manual Transmission Gear Ratio #6
Manual Transmission Gear Ratio Reverse
Neutral Position Switch Sensor Input
Neutral Position Switch Sensor Inverted
Reverse Lockout Demand
Measurements
Measurements
Reverse Lock-out Active
Reverse Lock-out Actuator Duty Cycle
Reverse Lock-out Actuator Output Status
Tunable Parameters
Tunable Parameters
Reverse Lock-out Actuator Output Frequency
Reverse Lock-out Actuator Output Inverted
Reverse Lock-out Enable Vehicle Speed Threshold
Reverse Lock-out Override
Shift Parameters
Shift Parameters
Measurements
Measurements
Auto Trans Active Drive Gear
Transmission Shift Mode Selected
Tunable Parameters
Tunable Parameters
Automatic Transmission Active Drive Gear Override Demand
Automatic Transmission Active Drive Gear Override Enabled
Drive Gear Shift Active Time
Dual Throttle Position Activation Delay
Dual Throttle Position Error Threshold
Normal Mode Down Shift Vehicle Speed 2 To 1
Normal Mode Down Shift Vehicle Speed 3 To 2
Normal Mode Down Shift Vehicle Speed 4 To 3
Normal Mode Up Shift Vehicle Speed 1 To 2
Normal Mode Up Shift Vehicle Speed 2 To 3
Normal Mode Up Shift Vehicle Speed 3 To 4
Normal Mode Wide Open Throttle Down Shift Engine Speed 2 To 1
Normal Mode Wide Open Throttle Down Shift Engine Speed 3 To 2
Normal Mode Wide Open Throttle Down Shift Engine Speed 4 To 3
Normal Mode Wide Open Throttle Down Shift Engine Speed Maximum
Normal Mode Wide Open Throttle Down Shift Vehicle Speed 2 To 1
Normal Mode Wide Open Throttle Down Shift Vehicle Speed 3 To 2
Normal Mode Wide Open Throttle Down Shift Vehicle Speed 4 To 3
Normal Mode Wide Open Throttle Shift Engine Speed Hysteresis
Normal Mode Wide Open Throttle Up Shift Engine Speed 1 To 2
Normal Mode Wide Open Throttle Up Shift Engine Speed 2 To 3
Normal Mode Wide Open Throttle Up Shift Engine Speed 3 To 4
Normal Mode Wide Open Throttle Up Shift Vehicle Speed 1 To 2
Normal Mode Wide Open Throttle Up Shift Vehicle Speed 2 To 3
Normal Mode Wide Open Throttle Up Shift Vehicle Speed 3 To 4
Performance Mode Down Shift Vehicle Speed 2 To 1
Performance Mode Down Shift Vehicle Speed 3 To 2
Performance Mode Down Shift Vehicle Speed 4 To 3
Performance Mode Up Shift Vehicle Speed 1 To 2
Performance Mode Up Shift Vehicle Speed 2 To 3
Performance Mode Up Shift Vehicle Speed 3 To 4
Performance Mode Wide Open Throttle Down Shift Engine Speed 2 To 1
Performance Mode Wide Open Throttle Down Shift Engine Speed 3 To 2
Performance Mode Wide Open Throttle Down Shift Engine Speed 4 To 3
Performance Mode Wide Open Throttle Down Shift Engine Speed Maximum
Performance Mode Wide Open Throttle Down Shift Vehicle Speed 2 To 1
Performance Mode Wide Open Throttle Down Shift Vehicle Speed 3 To 2
Performance Mode Wide Open Throttle Down Shift Vehicle Speed 4 To 3
Performance Mode Wide Open Throttle Shift Engine Speed Hysteresis
Performance Mode Wide Open Throttle Up Shift Engine Speed 1 To 2
Performance Mode Wide Open Throttle Up Shift Engine Speed 2 To 3
Performance Mode Wide Open Throttle Up Shift Engine Speed 3 To 4
Performance Mode Wide Open Throttle Up Shift Vehicle Speed 1 To 2
Performance Mode Wide Open Throttle Up Shift Vehicle Speed 2 To 3
Performance Mode Wide Open Throttle Up Shift Vehicle Speed 3 To 4
Secondary Electronic Throttle (Etc) Feed Forward
Transmission Type
Shift Pressures
Shift Pressures
Measurements
Measurements
Drive Gear Down Shift 2 To 1 Active
Drive Gear Down Shift 3 To 2 Active
Drive Gear Down Shift 4 To 3 Active
Drive Gear Up Shift 1 To 2 Active
Drive Gear Up Shift 2 To 3 Active
Drive Gear Up Shift 3 To 4 Active
Gear Shift Active
Line Pressure Setpoint
Normal Mode Gear Shift Line Pressure
Normal Mode In Gear Line Pressure
Performance Mode Gear Shift Line Pressure
Performance Mode In Gear Line Pressure
Performance Mode Line Pressure
Tunable Parameters
Tunable Parameters
Line Pressure Setpoint Maximum
Line Pressure Setpoint Minimum
Normal Mode Down Shift Line Pressure 2 To 1
Normal Mode Down Shift Line Pressure 3 To 2
Normal Mode Down Shift Line Pressure 4 To 3
Normal Mode Line Pressure Gear #1
Normal Mode Line Pressure Gear #2
Normal Mode Line Pressure Gear #3
Normal Mode Line Pressure Gear #4
Normal Mode Line Pressure Gear #park
Normal Mode Line Pressure Gear #reverse
Normal Mode Up Shift Line Pressure 1 To 2
Normal Mode Up Shift Line Pressure 2 To 3
Normal Mode Up Shift Line Pressure 3 To 4
Performance Mode Down Shift Line Pressure 2 To 1
Performance Mode Down Shift Line Pressure 3 To 2
Performance Mode Down Shift Line Pressure 4 To 3
Performance Mode Line Pressure Gear #1
Performance Mode Line Pressure Gear #2
Performance Mode Line Pressure Gear #3
Performance Mode Line Pressure Gear #4
Performance Mode Line Pressure Gear #park
Performance Mode Line Pressure Gear #reverse
Performance Mode Up Shift Line Pressure 1 To 2
Performance Mode Up Shift Line Pressure 2 To 3
Performance Mode Up Shift Line Pressure 3 To 4
Trans Current Gear
Shift Time
Shift Time
Measurements
Measurements
Drive Gear Down Shift 2 To 1 Time
Drive Gear Down Shift 3 To 2 Time
Drive Gear Down Shift 4 To 3 Time
Drive Gear Up Shift 1 To 2 Time
Drive Gear Up Shift 2 To 3 Time
Drive Gear Up Shift 3 To 4 Time
Tunable Parameters
Tunable Parameters
Gear Shift Time Maximum
Gear Shift Time Minimum
Normal Mode Down Shift Time 2 To 1
Normal Mode Down Shift Time 3 To 2
Normal Mode Down Shift Time 4 To 3
Normal Mode Up Shift Time 1 To 2
Normal Mode Up Shift Time 2 To 3
Normal Mode Up Shift Time 3 To 4
Performance Down Shift Time 2 To 1
Performance Down Shift Time 3 To 2
Performance Down Shift Time 4 To 3
Performance Mode Up Shift Time 1 To 2
Performance Mode Up Shift Time 2 To 3
Performance Mode Up Shift Time 3 To 4
Torque Converter
Torque Converter
Measurements
Measurements
Torque Converter (Tcc) Apply Enabled
Torque Converter (Tcc) Apply Time
Torque Converter (Tcc) State
Tunable Parameters
Tunable Parameters
Normal Mode Torque Converter Apply Vehicle Speed Gear #2
Normal Mode Torque Converter Apply Vehicle Speed Gear #3
Normal Mode Torque Converter Apply Vehicle Speed Gear #4
Normal Mode Torque Converter Release Tps Threshold Gear #2
Normal Mode Torque Converter Release Tps Threshold Gear #3
Normal Mode Torque Converter Release Tps Threshold Gear #4
Normal Mode Torque Converter Release Vehicle Speed Gear #2
Normal Mode Torque Converter Release Vehicle Speed Gear #3
Normal Mode Torque Converter Release Vehicle Speed Gear #4
Normal Mode Wide Open Throttle Torque Converter Apply Engine Speed
Performance Mode Torque Converter Apply Vehicle Speed Gear #2
Performance Mode Torque Converter Apply Vehicle Speed Gear #3
Performance Mode Torque Converter Apply Vehicle Speed Gear #4
Performance Mode Torque Converter Release Tps Threshold Gear #2
Performance Mode Torque Converter Release Tps Threshold Gear #3
Performance Mode Torque Converter Release Tps Threshold Gear #4
Performance Mode Torque Converter Release Vehicle Speed Gear #2
Performance Mode Torque Converter Release Vehicle Speed Gear #3
Performance Mode Torque Converter Release Vehicle Speed Gear #4
Performance Mode Wide Open Throttle Torque Converter Apply Engine Speed
Torque Converter (Tcc) Apply During Shift Enabled
Torque Converter (Tcc) Apply Enable Drive Gear Minimum
Torque Converter (Tcc) Apply Enable Engine Coolant Temperature Minimum
Torque Converter (Tcc) Apply Enable Throttle Position Maximum
Torque Converter (Tcc) Apply Enable Throttle Position Minimum
Torque Converter Demand
Measurements
Measurements
Torque Converter (Tcc) Pwm Solenoid Valve Actuator Duty Cycle
Torque Converter (Tcc) Pwm Solenoid Valve Actuator Output Status
Torque Converter (Tcc) Solenoid Valve Actuator Duty Cycle
Torque Converter (Tcc) Solenoid Valve Actuator Output Status
Tunable Parameters
Tunable Parameters
Torque Converter (TCC) PWM Solenoid Valve Actuator Output Inverted
Torque Converter (TCC) PWM Solenoid Valve Actuator Override
Torque Converter (TCC) PWM Solenoid Valve Actuator Override Demand
Torque Converter (Pwm) Solenoid Valve Actuator Output
Torque Converter (Tcc) Pwm Solenoid Valve Actuator Maximum Duty Cycle
Torque Converter (Tcc) Pwm Solenoid Valve Actuator Minimum Duty Cycle
Torque Converter (Tcc) Pwm Solenoid Valve Actuator Output Frequency
Torque Converter (Tcc) Pwm Solenoid Valve Apply Duty Cycle
Torque Converter (Tcc) Pwm Solenoid Valve Release Duty Cycle
Torque Converter (Tcc) Solenoid Valve Actuator Output Frequency
Trans Brake Control
Trans Brake Control
Measurements
Measurements
Trans-brake Actuator Duty Cycle
Trans-brake Actuator Output Status
Trans-brake BUMP/CREEP Active
Trans-brake Bump Actuator Output Status
Trans-brake Bump Count
Trans-brake Bump Duty Cycle
Trans-brake Control Active
Tunable Parameters
Tunable Parameters
Trans-Brake Control Lockout Time
Trans-brake Actuator Output Frequency
Trans-brake Bump Actuator Channel
Trans-brake Bump Time
Trans-brake Control Enable Vehicle Speed Threshold
Trans-brake Control Enabled
Trans-brake Override
Trans-brake Override Demand
Measurements
Measurements
Transmission Line Pressure (Trans Pr)
Transmission Line Pressure (Trans Pr) Dtc Active
Transmission Line Pressure (Trans Pr) Sensor Voltage
Tunable Parameters
Tunable Parameters
Transmission Line Pressure (Trans Pr) Filter Coefficient
Transmission Line Pressure (Trans Pr) Scaled Endpoints
Transmission Line Pressure (Trans Pr) Sensor Default
Transmission Line Pressure (Trans Pr) Sensor Dtc Maximum
Transmission Line Pressure (Trans Pr) Sensor Dtc Maximum Voltage
Transmission Line Pressure (Trans Pr) Sensor Dtc Minimum
Transmission Line Pressure (Trans Pr) Sensor Dtc Minimum Voltage
Transmission Line Pressure (Trans Pr) Sensor Input
Transmission Line Pressure (Trans Pr) Sensor Inverted
Measurements
Measurements
Transmission Oil Temperature (Trans Temp) Sensor Resistance
Transmission Oil Temperature (Trans Temp) Dtc Active
Transmission Oil Temperature (Trans Temp) Sensor Voltage
Tunable Parameters
Tunable Parameters
Transmission Oil Temperature (Trans Temp) Filter Coefficient
Transmission Oil Temperature (Trans Temp) Scaled Endpoints
Transmission Oil Temperature (Trans Temp) Sensor Default
Transmission Oil Temperature (Trans Temp) Sensor Dtc Maximum
Transmission Oil Temperature (Trans Temp) Sensor Dtc Maximum Voltage
Transmission Oil Temperature (Trans Temp) Sensor Dtc Minimum
Transmission Oil Temperature (Trans Temp) Sensor Dtc Minimum Voltage
Transmission Oil Temperature (Trans Temp) Sensor Input
TurboLamik Trans Input
Measurements
Measurements
Turbolamik Trans Adaptation State
Turbolamik Trans Blip Active
Turbolamik Trans Burnout Active
Turbolamik Trans Converter Lockup State
Turbolamik Trans Current Gear
Turbolamik Trans Error Code
Turbolamik Trans Estimated Wheel Torque
Turbolamik Trans Foot Brake State
Turbolamik Trans Gear Shift Active
Turbolamik Trans Gear Shift Stuck Active
Turbolamik Trans Gearbox Calculated Engine Torque
Turbolamik Trans Gearbox Clutch Slip
Turbolamik Trans Gearbox Converter Slip
Turbolamik Trans Gearbox Mode
Turbolamik Trans Gearbox Oil Fan State
Turbolamik Trans Gearbox Program Mode
Turbolamik Trans Hand Brake State
Turbolamik Trans Input Shaft Speed
Turbolamik Trans Launch Control Active
Turbolamik Trans Lockup Clutch Percentage
Turbolamik Trans Neutral Active
Turbolamik Trans Oil Temperature
Turbolamik Trans Output Shaft Speed
Turbolamik Trans Parking Active
Turbolamik Trans Safe Mode
Turbolamik Trans Target Engine Torque
Turbolamik Trans Target Gear
Turbolamik Trans Torque Reduction Active
Turbolamik Trans Torque Reduction Request
Turbolamik Trans Vehicle Speed
Turbolamik Transmission Transbrake Active
Vehicle Inputs
Vehicle Inputs
Air Conditioner
Air Conditioner
Measurements
Measurements
Air Conditioner Active
Air Conditioner Engine Fan Mode Requested
Air Conditioner Idle Speed Setpoint Adder
Tunable Parameters
Tunable Parameters
Air Conditioner Active Delay
Air Conditioner Enabled
Air Conditioner Engine Speed Maximum Threshold
Air Conditioner Engine Speed Maximum Threshold Hysteresis
Air Conditioner Engine Speed Minimum Threshold
Air Conditioner Engine Speed Minimum Threshold Hysteresis
Air Conditioner Refrigerant Pressure Threshold
Air Conditioner Refrigerant Pressure Threshold Hysteresis
Air Conditioner Refrigerant Temperature Threshold
Air Conditioner Refrigerant Temperature Threshold Hysteresis
Air Conditioner Throttle Position Threshold
Air Conditioner Throttle Position Threshold Hysteresis
Minimum Air Conditioner Engine Run Time
Air Conditioner Demand
Measurements
Measurements
Air Conditioner (Ac) Actuator Output Status
Tunable Parameters
Tunable Parameters
Measurements
Measurements
Air Conditioner (Ac) Refrigerant Pressure
Air Conditioner (Ac) Refrigerant Pressure Dtc Active
Air Conditioner (Ac) Refrigerant Pressure Sensor Voltage
Tunable Parameters
Tunable Parameters
Air Conditioner (Ac) Refrigerant Pressure Filter Coefficient
Air Conditioner (Ac) Refrigerant Pressure Scaled Endpoints
Air Conditioner (Ac) Refrigerant Pressure Sensor Default
Air Conditioner (Ac) Refrigerant Pressure Sensor Dtc Maximum
Air Conditioner (Ac) Refrigerant Pressure Sensor Dtc Maximum Volts
Air Conditioner (Ac) Refrigerant Pressure Sensor Dtc Minimum
Air Conditioner (Ac) Refrigerant Pressure Sensor Dtc Minimum Voltage
Air Conditioner (Ac) Refrigerant Pressure Sensor Input
Air Conditioner (Ac) Refrigerant Pressure Sensor Inverted
Measurements
Measurements
Air Conditioner (AC) Refrigerant Temperature Sensor Resistance
Air Conditioner (Ac) Refrigerant Temperature
Air Conditioner (Ac) Refrigerant Temperature Dtc Active
Air Conditioner (Ac) Refrigerant Temperature Sensor Voltage
Tunable Parameters
Tunable Parameters
Air Conditioner (Ac) Refrigerant Temperature Endpoints
Air Conditioner (Ac) Refrigerant Temperature Filter Coefficient
Air Conditioner (Ac) Refrigerant Temperature Sensor Default
Air Conditioner (Ac) Refrigerant Temperature Sensor Dtc Maximum
Air Conditioner (Ac) Refrigerant Temperature Sensor Dtc Maximum Voltage
Air Conditioner (Ac) Refrigerant Temperature Sensor Dtc Minimum
Air Conditioner (Ac) Refrigerant Temperature Sensor Dtc Minimum Voltage
Air Conditioner (Ac) Refrigerant Temperature Sensor Input
Base
Base
Tunable Parameters
Tunable Parameters
Vehicle Tire Diameter
Brake Pedal
Brake Pedal
Measurements
Measurements
Front Brake Pressure Dtc Fault Active
Rear Brake Pressure
Rear Brake Pressure Dtc Fault Active
Rear Brake Pressure Sensor Voltage
Tunable Parameters
Tunable Parameters
Brake Switch Sensor Default
Brake Switch Sensor Inverted
Rear Brake Pressure Scaled Endpoints
Rear Brake Pressure Sensor Default
Rear Brake Pressure Sensor Dtc Maximum
Rear Brake Pressure Sensor Dtc Maximum Voltage
Rear Brake Pressure Sensor Dtc Minimum
Rear Brake Pressure Sensor Dtc Minimum Voltage
Rear Brake Pressure Sensor Input
Rear Brake Pressure Sensor Inverted
Brakes
Brakes
Measurements
Measurements
Brakes Active
Front Brake Pressure Sensor Voltage
Tunable Parameters
Tunable Parameters
Brake Pedal Strategy
Brake Switch Sensor Input
Front Brake Pressure Dtc Maximum
Front Brake Pressure Dtc Maximum Voltage
Front Brake Pressure Dtc Minimum
Front Brake Pressure Dtc Minimum Voltage
Front Brake Pressure Filter Frequency
Front Brake Pressure Scaled Endpoints
Front Brake Pressure Sensor Default
Front Brake Pressure Sensor Input
Front Brake Pressure Sensor Inverted
Front Brake Pressure Threshold
Burnout Control
Burnout Control
Measurements
Measurements
Burnout Control Active
Burnout Control Cut Request
Burnout Control State
Tunable Parameters
Tunable Parameters
Burnout Control Cut Mode
Burnout Control Enabled
Burnout Control Engine Speed Threshold
Burnout Control Engine Speed Threshold Hysteresis
Burnout Control Lockout Time
Driver Switches
Driver Switches
Measurements
Measurements
Air Conditioner Arming Switch Active
Boost Switch Active
Burnout Switch Active
Fuel Tank Capacity Reset Switch Active
Master Odometer Reset Switch Active
Nitrous Arming Switch Active
Nitrous (Nos) Bottle Heater Arming Switch Active
Racing Transmission Up Shift Switch Active
Scramble (Boost/nos) Arming Switch Active
Traction Control Arming Switch Active
Trans-brake Arming Switch Active
Transmission Shift Mode Arming Switch Position
Trip Reset Switch Active
Vehicle Speed Limiter Arming Switch Active
Tunable Parameters
Tunable Parameters
Air Conditioner Arming Switch Input Inverted
Air Conditioner Arming Switch Sensor Input
Boost Switch Input
Boost Switch Input Inverted
Burnout Switch Engage (Press) Time
Burnout Switch Input
Burnout Switch Input Inverted
Fuel Tank Capacity Reset Switch Input Inverted
Fuel Tank Capacity Reset Switch Sensor Input
Launch Control Arming Switch Input Inverted
Launch Control Arming Switch Sensor Input
Master Odometer Reset Switch Input Inverted
Master Odometer Reset Switch Sensor Input
Nitrous (Nos) Arming Switch Input Inverted
Nitrous (Nos) Arming Switch Sensor Input
Nitrous (Nos) Bottle Heater Arming Switch Input
Nitrous (Nos) Bottle Heater Arming Switch Input Inverted
Scramble (Boost/nos) Arming Switch Engage (Press) Time
Scramble (Boost/nos) Arming Switch Input
Scramble (Boost/nos) Arming Switch Input Inverted
Scramble Switch Mode
Traction Control Arming Switch Input Inverted
Traction Control Arming Switch Sensor Input
Trans-brake Arming Switch Engage (Press) Time
Trans-brake Arming Switch Input
Trans-brake Arming Switch Input Inverted
Trans-brake Bump Arming Switch Input
Trans-brake Bump Arming Switch Input Inverted
Transmission Shift Mode Arming Switch Input
Transmission Shift Mode Arming Switch Input Inverted
Trip Reset Switch Input Inverted
Trip Reset Switch Sensor Input
Vehicle Speed Limiter Arming Switch Input Inverted
Vehicle Speed Limiter Arming Switch Sensor Input
Fans
Fans
Fans
Measurements
Measurements
Fan 1 Active
Fan 1 Requested
Fan 2 Active
Fan 2 Requested
Tunable Parameters
Tunable Parameters
Engine Off Fan Run Time
Fan 1 Actuator Output
Fan 1 Engine Coolant Temperature Threshold
Fan 1 Engine Coolant Temperature Threshold Hysteresis
Fan 1 Override Demand
Fan 1 Override Enabled
Fan 2 Actuator Output
Fan 2 Engine Coolant Temperature Threshold
Fan 2 Engine Coolant Temperature Threshold Hysteresis
Fan 2 Override Demand
Fan 2 Override Enabled
Generic Output
Generic Output
Measurements
Measurements
Generic Actuator 1 Output Status
Generic Actuator 2 Output Status
Generic Actuator 3 Output Status
Generic Actuator 4 Output Status
Generic Output 1 Active
Generic Output 2 Active
Generic Output 3 Active
Generic Output 4 Active
Tunable Parameters
Tunable Parameters
Generic Actuator 1 Output Inverted
Generic Actuator 2 Output Inverted
Generic Actuator 3 Output Inverted
Generic Actuator 4 Output Inverted
Generic Output 1 Activation Mode
Generic Output 1 Enabled
Generic Output 1 Engine Speed Maximum Threshold
Generic Output 1 Engine Speed Maximum Threshold Hysteresis
Generic Output 1 Engine Speed Minimum Threshold
Generic Output 1 Engine Speed Minimum Threshold Hysteresis
Generic Output 1 Launch Confirmed Time In
Generic Output 1 Launch Confirmed Time Out
Generic Output 1 Manifold Absolute Pressure Maximum Threshold
Generic Output 1 Manifold Absolute Pressure Maximum Threshold Hysteresis
Generic Output 1 Manifold Absolute Pressure Minimum Threshold
Generic Output 1 Manifold Absolute Pressure Minimum Threshold Hysteresis
Generic Output 1 Override
Generic Output 1 Throttle Position Maximum Threshold
Generic Output 1 Throttle Position Maximum Threshold Hysteresis
Generic Output 1 Throttle Position Minimum Threshold
Generic Output 1 Throttle Position Minimum Threshold Hysteresis
Generic Output 2 Activation Mode
Generic Output 2 Enabled
Generic Output 2 Engine Speed Maximum Threshold
Generic Output 2 Engine Speed Maximum Threshold Hysteresis
Generic Output 2 Engine Speed Minimum Threshold
Generic Output 2 Engine Speed Minimum Threshold Hysteresis
Generic Output 2 Launch Confirmed Time In
Generic Output 2 Manifold Absolute Pressure Maximum Threshold
Generic Output 2 Manifold Absolute Pressure Maximum Threshold Hysteresis
Generic Output 2 Manifold Absolute Pressure Minimum Threshold
Generic Output 2 Manifold Absolute Pressure Minimum Threshold Hysteresis
Generic Output 2 Override
Generic Output 2 Throttle Position Maximum Threshold
Generic Output 2 Throttle Position Maximum Threshold Hysteresis
Generic Output 2 Throttle Position Minimum Threshold
Generic Output 2 Throttle Position Minimum Threshold Hysteresis
Generic Output 3 Activation Mode
Generic Output 3 Enabled
Generic Output 3 Engine Speed Maximum Threshold
Generic Output 3 Engine Speed Maximum Threshold Hysteresis
Generic Output 3 Engine Speed Minimum Threshold
Generic Output 3 Engine Speed Minimum Threshold Hysteresis
Generic Output 3 Launch Confirmed Time In
Generic Output 3 Launch Confirmed Time Out
Generic Output 3 Manifold Absolute Pressure Maximum Threshold
Generic Output 3 Manifold Absolute Pressure Maximum Threshold Hysteresis
Generic Output 3 Manifold Absolute Pressure Minimum Threshold
Generic Output 3 Manifold Absolute Pressure Minimum Threshold Hysteresis
Generic Output 3 Override
Generic Output 3 Throttle Position Maximum Threshold
Generic Output 3 Throttle Position Maximum Threshold Hysteresis
Generic Output 3 Throttle Position Minimum Threshold
Generic Output 3 Throttle Position Minimum Threshold Hysteresis
Generic Output 4 Activation Mode
Generic Output 4 Enabled
Generic Output 4 Engine Speed Maximum Threshold
Generic Output 4 Engine Speed Maximum Threshold Hysteresis
Generic Output 4 Engine Speed Minimum Threshold
Generic Output 4 Engine Speed Minimum Threshold Hysteresis
Generic Output 4 Launch Confirmed Time In
Generic Output 4 Launch Confirmed Time Out
Generic Output 4 Manifold Absolute Pressure Maximum Threshold
Generic Output 4 Manifold Absolute Pressure Maximum Threshold Hysteresis
Generic Output 4 Manifold Absolute Pressure Minimum Threshold
Generic Output 4 Manifold Absolute Pressure Minimum Threshold Hysteresis
Generic Output 4 Override
Generic Output 4 Throttle Position Maximum Threshold
Generic Output 4 Throttle Position Maximum Threshold Hysteresis
Generic Output 4 Throttle Position Minimum Threshold
Generic Output 4 Throttle Position Minimum Threshold Hysteresis
Generic Pressure Sensors
Measurements
Measurements
Generic Pressure 1
Generic Pressure 1 Sensor Voltage
Generic Pressure 2
Generic Pressure 2 Sensor Voltage
Generic Pressure 3
Generic Pressure 3 Sensor Voltage
Generic Pressure 4
Generic Pressure 4 Sensor Voltage
Generic Pressure 5
Generic Pressure 5 Sensor Voltage
Generic Pressure 6
Generic Pressure 6 Raw
Generic Pressure 6 Sensor Voltage
Tunable Parameters
Tunable Parameters
Generic Pressure 1 Default
Generic Pressure 1 Filter Coefficient
Generic Pressure 1 Sensor Input
Generic Pressure 1 Sensor Inverted
Generic Pressure 1 Sensor Scaled Endpoints
Generic Pressure 2 Default
Generic Pressure 2 Filter Coefficient
Generic Pressure 2 Sensor Input
Generic Pressure 2 Sensor Inverted
Generic Pressure 2 Sensor Scaled Endpoints
Generic Pressure 3 Default
Generic Pressure 3 Filter Coefficient
Generic Pressure 3 Sensor Input
Generic Pressure 3 Sensor Inverted
Generic Pressure 3 Sensor Scaled Endpoints
Generic Pressure 4 Default
Generic Pressure 4 Filter Coefficient
Generic Pressure 4 Sensor Input
Generic Pressure 4 Sensor Inverted
Generic Pressure 4 Sensor Scaled Endpoints
Generic Pressure 5 Default
Generic Pressure 5 Filter Coefficient
Generic Pressure 5 Sensor Input
Generic Pressure 5 Sensor Inverted
Generic Pressure 5 Sensor Scaled Endpoints
Generic Pressure 6 Default
Generic Pressure 6 Filter Coefficient
Generic Pressure 6 Sensor Input
Generic Pressure 6 Sensor Inverted
Generic Pressure 6 Sensor Scaled Endpoints
Generic Temperature Sensors
Measurements
Measurements
Generic Temperature 1
Generic Temperature 1 Sensor Resistance
Generic Temperature 1 Sensor Voltage
Generic Temperature 2
Generic Temperature 2 Sensor Resistance
Generic Temperature 2 Sensor Voltage
Generic Temperature 3
Generic Temperature 3 Sensor Resistance
Generic Temperature 3 Sensor Voltage
Tunable Parameters
Tunable Parameters
Generic Temperature 1 Filter Coefficient
Generic Temperature 1 Scaled Endpoints
Generic Temperature 1 Sensor Input
Generic Temperature 2 Filter Coefficient
Generic Temperature 2 Scaled Endpoints
Generic Temperature 2 Sensor Input
Generic Temperature 3 Filter Coefficient
Generic Temperature 3 Scaled Endpoints
Generic Temperature 3 Sensor Input
Ignition Switch
Ignition Switch
Measurements
Measurements
Ignition Switch Active
Ignition Switch Sensor Voltage
Tunable Parameters
Tunable Parameters
Ignition Switch Sensor Input
Ignition Switch Voltage Filter Coefficient
Line Lock
Line Lock
Measurements
Measurements
Line Lock Active
Line Lock Actuator Duty Cycle
Line Lock Actuator Output Status
Tunable Parameters
Tunable Parameters
Line Lock Activation Mode
Line Lock Actuator Output Frequency
Line Lock Actuator Output Inverted
Line Lock Control Enabled
Line Lock Override
Malfunction Indicator Lamp (MIL)
Measurements
Measurements
MIL Indicator (Check Engine) Actuator Output Status
MIL Indicator Active
Tunable Parameters
Tunable Parameters
MIL Indicator (Check Engine) Actuator Output Frequency
MIL Indicator (Check Engine) Actuator Output Inverted
MIL Indicator (Check Engine) Override
Racing Transmission
Racing Transmission
Measurements
Measurements
Racing Transmission Actuator Duty Cycle
Racing Transmission Actuator Output Active
Racing Transmission Actuator Output Status
Racing Transmission Current Gear
Racing Transmission Timer
Tunable Parameters
Tunable Parameters
Racing Transmission - Number Of Gears
Racing Transmission Actuator Output Frequency
Racing Transmission Actuator Output Inverted
Racing Transmission After Shift Inactive Time 1 To 2
Racing Transmission After Shift Inactive Time 2 To 3
Racing Transmission After Shift Inactive Time 3 To 4
Racing Transmission After Shift Inactive Time 4 To 5
Racing Transmission After Shift Inactive Time 5 To 6
Racing Transmission After Shift Inactive Time 6 To 7
Racing Transmission After Shift Inactive Time 7 To 8
Racing Transmission Ignition Cut Delay Up Shift 1 To 2
Racing Transmission Ignition Cut Delay Up Shift 2 To 3
Racing Transmission Ignition Cut Delay Up Shift 3 To 4
Racing Transmission Ignition Cut Delay Up Shift 4 To 5
Racing Transmission Ignition Cut Delay Up Shift 5 To 6
Racing Transmission Ignition Cut Delay Up Shift 6 To 7
Racing Transmission Ignition Cut Delay Up Shift 7 To 8
Racing Transmission Ignition Cut Enabled
Racing Transmission Ignition Cut Time Up Shift 1 To 2
Racing Transmission Ignition Cut Time Up Shift 2 To 3
Racing Transmission Ignition Cut Time Up Shift 3 To 4
Racing Transmission Ignition Cut Time Up Shift 4 To 5
Racing Transmission Ignition Cut Time Up Shift 5 To 6
Racing Transmission Ignition Cut Time Up Shift 6 To 7
Racing Transmission Ignition Cut Time Up Shift 7 To 8
Racing Transmission Ignition Retard Enabled
Racing Transmission Ignition Retard Up Shift 1 To 2
Racing Transmission Ignition Retard Up Shift 2 To 3
Racing Transmission Ignition Retard Up Shift 3 To 4
Racing Transmission Ignition Retard Up Shift 4 To 5
Racing Transmission Ignition Retard Up Shift 5 To 6
Racing Transmission Ignition Retard Up Shift 6 To 7
Racing Transmission Ignition Retard Up Shift 7 To 8
Racing Transmission Override
Racing Transmission Pedaling Activation Throttle Position
Racing Transmission Pedaling Timer Mode
Racing Transmission Timer Activation Engine Speed
Racing Transmission Timer Up Shift Time 1 To 2
Racing Transmission Timer Up Shift Time 2 To 3
Racing Transmission Timer Up Shift Time 3 To 4
Racing Transmission Timer Up Shift Time 4 To 5
Racing Transmission Timer Up Shift Time 5 To 6
Racing Transmission Timer Up Shift Time 6 To 7
Racing Transmission Timer Up Shift Time 7 To 8
Racing Transmission Up Shift Activation Mode
Racing Transmission Up Shift Engine Speed 1 To 2
Racing Transmission Up Shift Engine Speed 2 To 3
Racing Transmission Up Shift Engine Speed 3 To 4
Racing Transmission Up Shift Engine Speed 4 To 5
Racing Transmission Up Shift Engine Speed 5 To 6
Racing Transmission Up Shift Engine Speed 6 To 7
Racing Transmission Up Shift Engine Speed 7 To 8
Racing Transmission Up Shift Time 1 To 2
Racing Transmission Up Shift Time 2 To 3
Racing Transmission Up Shift Time 3 To 4
Racing Transmission Up Shift Time 4 To 5
Racing Transmission Up Shift Time 5 To 6
Racing Transmission Up Shift Time 6 To 7
Racing Transmission Up Shift Time 7 To 8
Rotary Switches
Rotary Switches
Measurements
Measurements
Map Selection Rotary Switch Voltage
Map Selection Switch Position
Tunable Parameters
Tunable Parameters
Map Selection Rotary Switch DTC Maximum Voltage
Map Selection Rotary Switch DTC Minimum Voltage
Map Selection Rotary Switch Input
Map Selection Rotary Switch Position 1
Map Selection Rotary Switch Position 1 Voltage
Map Selection Rotary Switch Position 2
Map Selection Rotary Switch Position 2 Voltage
Map Selection Rotary Switch Position 3
Map Selection Rotary Switch Position 3 Voltage
Map Selection Rotary Switch Position 4
Map Selection Rotary Switch Position 4 Voltage
Map Selection Rotary Switch Tolerance Voltage
Map Selection Switch Type
Map Selection Toggle Switch Input
Map Selection Toggle Switch Input Inverted
Vehicle Gauges
Vehicle Gauges
Measurements
Measurements
Speedometer Actuator Frequency
Tachometer Actuator Frequency
Tunable Parameters
Tunable Parameters
Speedometer Actuator Duty Cycle
Speedometer Actuator Frequency (Measurement)
Speedometer Actuator Frequency Override Demand
Speedometer Actuator Frequency Override Enabled
Speedometer Actuator Output
Tachometer Actuator Duty Cycle
Tachometer Actuator Frequency (Measurement)
Tachometer Actuator Frequency Override Demand
Tachometer Actuator Frequency Override Enabled
Tachometer Actuator Output
Measurements
Measurements
Trans Current Gear Number
Vehicle Speed Limiter Feed Forward Term
Vehicle Speed Limiter Ignition Cut Pattern Requested
Vehicle Speed Limiter Ignition Retard
Vehicle Speed Limiter Ignition Retard Active
Vehicle Speed Limiter Ignition Retard Decay
Vehicle Speed Limiter Integral Term
Vehicle Speed Limiter Map Selected
Vehicle Speed Limiter Proportional Term
Vehicle Speed Limiter Threshold
Vehicle Speed Limiter Throttle Position Requested
Vehicle Speed Limiter Vehicle Speed Error
Tunable Parameters
Tunable Parameters
Vehicle Speed Arming Delay
Vehicle Speed Limiter Closed Loop Maximum
Vehicle Speed Limiter Closed Loop Minimum
Vehicle Speed Limiter Enabled
Vehicle Speed Limiter Feed Forward (Map #1)
Vehicle Speed Limiter Feed Forward Map #2
Vehicle Speed Limiter Feed Forward Map #3
Vehicle Speed Limiter Feed Forward Map #4
Vehicle Speed Limiter Ignition Retard (Map #1)
Vehicle Speed Limiter Ignition Retard Decay (Measurement)
Vehicle Speed Limiter Ignition Retard Map #2
Vehicle Speed Limiter Ignition Retard Map #3
Vehicle Speed Limiter Ignition Retard Map #4
Vehicle Speed Limiter Integral Gain
Vehicle Speed Limiter Integral Term Maximum
Vehicle Speed Limiter Integral Term Minimum
Vehicle Speed Limiter Proportional Gain
Vehicle Speed Limiter Proportional Term Maximum
Vehicle Speed Limiter Proportional Term Minimum
Vehicle Speed Limiter Threshold (Map #1)
Vehicle Speed Limiter Threshold Hysteresis (Map #1)
Vehicle Speed Limiter Threshold Hysteresis Map #2
Vehicle Speed Limiter Threshold Hysteresis Map #3
Vehicle Speed Limiter Threshold Hysteresis Map #4
Vehicle Speed Limiter Threshold Map #2
Vehicle Speed Limiter Threshold Map #3
Vehicle Speed Limiter Threshold Map #4
Vehicle Speed Limiter Throttle Position Rate Limiter Down
Vehicle Speed Limiter Throttle Position Rate Limiter Up
Measurements
Measurements
Vehicle Speed
Vehicle Speed (VSS) DTC Fault Active
Vehicle Speed Sensor Frequency
Tunable Parameters
Tunable Parameters
Number of Teeth on Transmission Gear
Number of Wheel Speed Sensors
Rear End Gear Ratio
Vehicle Speed Calculation Mode
Vehicle Speed Filter (VSS) Coefficient
Vehicle Speed Sensor (VSS) Input
Vehicle Speed Sensor Type
Wheel Speed
Wheel Speed
Measurements
Measurements
Front Wheel 1 Speed
Front Wheel 1 Speed Sensor Frequency
Front Wheel 2 Speed
Front Wheel 2 Speed Sensor Frequency
Rear Wheel 1 Speed
Rear Wheel 1 Speed Sensor Frequency
Rear Wheel 2 Speed
Rear Wheel 2 Speed Sensor Frequency
Tunable Parameters
Tunable Parameters
Front Wheel 1 Speed Filter Coefficient
Front Wheel 1 Speed Sensor Input
Front Wheel 2 Speed Filter Coefficient
Front Wheel 2 Speed Sensor Input
Number of Teeth on Front Wheel
Number of Teeth on Rear Wheel
Rear Wheel 1 Speed Filter Coefficient
Rear Wheel 1 Speed Sensor Input
Rear Wheel 2 Speed Filter Coefficient
Rear Wheel 2 Speed Sensor Input
CORE VCM Live
CORE VCM Live
CORE VCM Live
Introduction
Introduction
Introduction
System Requirements
Getting Started
VCM Live Changelog
User Interface
User Interface
User Interface
Menu Bar
Editing Tunable Parameters
Editing Tables
Editing Tables
Editing Tables
The Table Editor Toolbar
Using Histogram View
Table Editor Right-Click Menu
Renumbering Table Axes
Upgrading and Comparing Tunes
Live Tracing
Live Tracing
Live Tracing
Using Time Graph Subwindows
Trigger Scope
Trigger Scope
Triger Scope
Layouts
Layouts
Layouts
Sub Windows
Sub Windows
Subwindows
Adding a Gauge
Gauge Parameters
Adding a Time Graph
Time Graph Parameters
Adding a Measurement List
Measurement Parameters
Adding a Gauge Group
Adding a Table Editor
Editor Parameters
Adding a Characteristic List
Characteristics Parameters
Virtual Measurements
Expression Variables
CAN Bus Configuration
Diagnostics & Information
Third Party Controllers
Contacting Customer Support
Electrical Schematics
Knowledge Base Articles
Changing a VIN
E41 VATS Autolearn
Find Most Recent APP Key
Licenses vs. Credits
ProLink Wiring
VCM Suite Beta Version 5.3.6 Update
How to Create VCM Editor & Scanner Shortcuts for your Desktop
MPVI3
MPVI3
MPVI3
Introduction
Introduction
Introduction
Registering Your Device
Connecting to a Vehicle
MPVI3 Face Plate Description
Introduction
Introduction
Introduction
MPVI4 Face Plate Description
Introduction
Installation Procedure
TDN APP & RTD4 User Guide
TDN APP / RTD4 User Guide
Getting Started
Getting Started
Getting Started
Installing the TDN APP
Initial Device Setup Android
User Interface
User Interface
User Interface
Reading and Writing Tunes
Advanced Write Options
Data Logging
Data Logging
Generating a Data Log
Deleting Unwated Log Files
The Setup / Tools Menu
RTD Face Plate Description
FCC Statement for Users
TDN Tuner Portal Help System
TDN Tuner Portal
Getting Started
Getting Started
Getting Started
Adding and Removing Customers
Receiving Customer Files
Assigning a Tune To a Vehicle
Adding Asset Groups
Deployed Assets
Vehicle Link Triggers
TDN APP Support
TDN APP Support
TDN APP Support
Toyota Smart Access Cable
Toyota Smart Access Cable Install Guide
Introduction
Supported Vehicles
TrackAddict User Guide
Getting Started
Getting Started
Introduction
Getting Started
User Interface
Track Mode & Selection
Camera & Recording Setup
Recording a Session
Recording a Session
Recording a Session
Viewing Your Session Data
Additional APP Enhanced Options
Additional App Enhanced Options
USB File Transfer
USB File Transfer
USB File Transfer
Track List
Track List
Track List
Tuner Tools
Tuner Tools
Tuner Tools
Getting Started
Getting Started
Introduction
Getting Started
Converting Binary Files Using Tune Translation
Stock File Provider
Stock File Provider
Stock File Provider
Training
Training
Training
Introduction
Introduction
Introduction
System Requirements
Getting Started
Licensing Vehicles
VCM Editor Changelog
Remote Tuning
Remote Tuning
Remote Tuning
Reading a Vehicle
Reading a Vehicle
Reading a Vehicle
Locating Parameters
Locating Parameters
Locating Parameters
Tab Style Navigation
Parameter Navigator
Using Favorites
Templates
Templates
Templates
Creating a New Template
Adding Specific Parameters
Importing Another Template
Importing Unsaved Parameters
Applying a Template To a Tune
Template Editor
Template Applicator
User Defined Parameter Guide
Introduction
Introduction
Introduction
System Requirements
Getting Started
Scanning Architecture
File Architecture
VCM Scanner Chanelog
Channels
Channels
Overview
Adding a Channel
Transforming a Channel
MPVI Interface (s)
MPVI Interface (s)
Overview
Connecting a Sensor
MPVI2 Interface
MPVI2 Interface
Pro Link
Serial Port
Serial Port
Overview
Connecting a Sensor
Vehicle
Vehicle
Vehicle Profiles
MPVI Interface
MPVI2 Interface
Layouts
Layouts
Overview
Gauge
Graph
Chart v.s Time
Selecting a Parameter
Filters
Math Parameters
Math Parameters
Math Parameters
HP TUNERS
OBDII ADAPTER CABLE (S)
QUICK START GUIDE
Lets Get Started!
