Adding Asset Groups🔗
An asset group is an automated implementation for customer(s) to receive certain files based on TDN dealer defined criteria. Their are three types of asset groups, which are as follows:
Asset Group Type Description
HTT Template Once the end user vehicle is read and synced to TDN portal, TDN will deploy the "Template" asset and from there the customer has to sync files to accept the template asset.
Tune Used for specific vehicle conditions, if these conditions are met the tuner can utilize this asset group to deploy the customers.
ScannerConfig Used only for custom tuning, customers must send a datalog to utilize ScannerConfig assets.
  1. Select Asset Groups from the sidebar menu.
    A1 Image
  2. Click the Add Asset Group button.
  3. Write a description based on your Asset Group, Click Submit.
  4. Select the Asset Group you would like to deploy, then the asset deploy window will appear.
  5. Select Add Asset, Click and drop the file you would like to deploy to your customers, then select Add.
    A1 Image
    • "Scramble OS (if possible)" is for select FORD applications only with applicable permissions.
    • See Vehicle Link Triggers to assign the recently added asset group.
