Dual Injection Configuration🔗
There are 16 injectors on the CORE ECU. Eight injectors are used for primary injection, eight are used for secondary. The secondary injectors are mated to the primary injectors and will match the firing order of the primary. They must be connected to the same cylinder.
The following injectors must be paired together when using dual injection:
Pair Primary Injector Secondary Injector
#1 Injection Output 1 Injection Output 9
#2 Injection Output 2 Injection Output 10
#3 Injection Output 3 Injection Output 11
#4 Injection Output 4 Injection Output 12
#5 Injection Output 5 Injection Output 13
#6 Injection Output 6 Injection Output 14
#7 Injection Output 7 Injection Output 15
#8 Injection Output 8 Injection Output 16
The firing order can be configured by using the "Cylinder Firing Order" characteristic in VCM Live (Refer to the VCM Live User Guide to add a characteristic list), however, the pairs of injectors are non-configurable.
