Supported Controllers & Models🔗
The four available OBDII Adapter Cables are listed below with their supported controllers and models:
Item
OBDII Adapter Cable
Description
(Models format: year / model / displacement / part number)
1 OBDII Adapter Cable - Yamaha Outboard (34 Pin ECU, Style 1)
The Yamaha models and controllers this adpater can connect to can be found below:
MODELS:
- 2017-2024 / F150 / 2.8L / 6HP
- 2022-2025 / F200 / 2.8L / 6LH
- 2010-2021 / F225 / 4.2L / 6CL
- 2008-2010 / F250 / 3.3L / 6BR
- 2009-2021 / F250 / 4.2L / 6CB
- 2010-2021 / F250 / 4.2L / 6CG
- 2010-2021 / F300 / 4.2L / 6CE
- 2007-2009 / F300 / 4.2L / 6BJ
- 2020-2024 / F300 / 4.2L / 6KA
- 2007-2019 / F350 / 5.3L / 6AW
CONTROLLER:
- Yamaha Mitsubishi 1024K Marine
2 OBDII Adapter Cable - Yamaha Outboard (34 Pin ECU, Style 2)
MODELS:
- 2005-2025 / F50 / 1.0L / 6C1
- 2005-2024 / F60 / 1.0L / 6C5
- 2010-2024 / F70 / 1.0L / 6CJ
- 2005-2017 / F75 / 1.6L / 6D6
- 2005-2017 / F90 / 1.6L / 6D8
- 2011-2014 / F115 / 1.8L / 68V
- 2014-2025 / F115 / 1.8L / 6EK
CONTROLLER:
- Yamaha Mitsubishi 512K Marine
3 OBDII Adapter Cable - Yamaha 3-Pin
The OBDII Adapter Cable - Yamaha 3-Pin supports all models and controllers listed below and above.
4 OBDII Adapter Cable - Yamaha Outboard (44 Pin ECU, Style 2)
MODELS:
- 2005-2010 / F115 / 1.8L / 68V
- 2005-2024 / F150 / 2.7L / 63P
- 2005-2010 / F225 / 3.3L / 69J
CONTROLLER:
- Mitsubishi 512K Marine
  • The OBDII Adapter Cable - Yamaha 3-Pin is used for diagnostics and generating data logs through the 3 pin diagnostic port and is compatible with all other OBDII Adapter Cables.
