OBDII Adapter Cable Installation Procedure🔗
The following steps outline the recommended procedures for utilizing your OBDII Adapter Cable.
Required Tools/Items🔗
  • MPVI4
  • 12v Battery
  1. Connect the positive and negative alligator clips to the marine applications 12v battery.
    Caution
    • To reduce the risk of sparks or electrical damage, always connect the positive (+/red) terminal first.
  2. Connect your outboard pin connector to your marine applications ECM connector.
    Caution
    • Ensure power to your marine applications ECM is off (e.g., power switch knob or removing key from ignition).
  3. Connect your MPVI4 to the OBDII adapter cable.
    • The above image is referencing the Yamaha outboard 44 pin connector, style 2.
  4. Mount the 2 amp fuse away from any and all moving objects.
  5. Using a USB-C cable, connect your laptop to your MPVI4 device.
  6. Download and connect to VCM Suite and begin tuning!
