Connecting to a Vehicle🔗
When used with VCM Suite, a USB connection to your PC is recommended:
- Connect the provided USB-C cable to the MPVI device and the opposite end to your laptop with VCM Suite Installed.
- When you are ready to scan or reprogram the vehicle, plug the large, molded OBD-II connector on the other side of the interface device into the vehicle's diagnostic port.
Warning
- A 20A maximum size fuse is required ahead of the unit. Consult your vehicle owner's manual for the location and rating of the OBD port fuse.
- If you are connecting your vehicle via TDN APP, refer to the TDN APP User Guide.
