File Architecture🔗
Use this to better understand the complexity of VCM Scanners open/save dialogs.
Most files are saved in .xml format to enable outside modification if desired, for advanced users.
Architecture By Function🔗
VCM Scanner🔗
  • Stores the active Channel Configuration
  • Stores the active Channel Display Properties
  • Stores the active Layout Configuration
  • Stores the active Layout Display Properties
  • Stores user Math Parameters
  • Stores user Transforms
  • Stores user Preferences
Channels🔗
  • Reloaded from VCM Scanner.cfg on open
  • Saved to VCM Scanner.cfg on close
  • Can be saved/loaded from user saved files
Layout🔗
Architecture By File Type🔗
VCM Suite.cfg🔗
  • Created by the VCM Scanner/Editor applications only
  • Shared between VCM Scanner/Editor instances
  • Application Keys
  • Unit System
  • Tuning Path
VCM Scanner.cfg🔗
  • Created by the VCM Scanner application only
  • Shared between VCM Scanner instances
  • Stores Active Channel Configuration
  • Stores Active Channel Display Properties
  • Stores Active Layout Configuration
  • Stores Active Layout Display Properties
  • Stores User Math Parameters
  • Stores User Transforms
  • Stores Application Preferences & Settings
*.Channels.xml🔗
  • Default Location: \My Documents\HP Tuners\VCM Scanner\Channel Configs\
  • Created by users only
  • Stores Parameter ID and Source
  • Stores Channel Polling Intervals
  • Stores Channel Transforms
*.ChannelDisplay.xml🔗
  • Stores Channel Display Fonts and Colors
*.Layouts.xml🔗
  • Default Location: \My Documents\HP Tuners\VCM Scanner\Layouts\
Architecture By File Type - Gauges🔗
*.Gauges.xml🔗
  • Default Location: \My Documents\HP Tuners\VCM Scanner\Gauges\
  • Stores all gauges on the selected display
*.Gauge.xml🔗
  • Stores a single Gauge
*.GaugeDisplay.xml🔗
  • Stores Gauge Display Fonts and Colors
Architecture By File Type - Graphs🔗
*.Graphs.xml🔗
  • Default Location: \My Documents\HP Tuners\VCM Scanner\Graphs\
  • Stores all graphs on the selected display
*.Table.xml🔗
  • Stores a single Table
*.GraphDisplay.xml🔗
  • Stores Graph Display Fonts and Colors
Architecture By File Type - Charts🔗
*.Charts.xml🔗
  • Default Location: \My Documents\HP Tuners\VCM Scanner\Charts\
  • Stores all charts on the selected display
*.Chart.xml🔗
  • Stores a single Chart and its associated Series
*.Series.xml🔗
  • Stores a single series
*.ChartDisplay.xml🔗
  • Stores Chart Display Fonts and Colors
