Using Favorites🔗
Adding your most commonly-used parameters to the Favorites window allows you to quickly access all of them in the same place.
Parameters displayed here can be modified using the same methods you would use in either the Tab Navigation interface or Parameter Navigator.
To open this window, click the Favorites icon in the toolbar.
  • This window will display only the favorites included in the file you are currently editing. If the file does not contain one or more of your favorite parameters, the missing parameters will not be displayed.
Adding Favorites🔗
To add a favorite to the Favorites window:
  1. In either the Tab Navigation interface or Parameter Navigator, locate the parameter you wish to add.
  2. Right click on the colored background of the parameter's name. The Parameter Options menu appears.
  3. Select Favorites > Add to Favorites.
    • If you are in the Table Editor, you can also add the table by clicking the Add Favorite icon in the editor's toolbar.
Removing Favorites🔗
  1. Locate the parameter you want to remove in the Favorites Window or using either of the navigation interfaces.
  3. Select Favorites > Remove from Favorites.
