Adding Specific Parameters🔗
When editing a template in Template Editor, you can manually select parameters to add.
  1. Open the tune file that contains the parameters you wish to import.
  2. In the Template Editor toolbar, click . The Parameter Selector window appears.
  3. Check the box for each parameter or group of parameters you wish to add.
  4. Click OK.
