Applying a Template To a Tune🔗
Open the tune file to which you want to apply the template.
In the menu bar, select Edit > Template Applicator. The Template Applicator window appears.
In the Template Applicator toolbar, click the
icon. -
Browse for and select the template you wish to apply. The parameters in the selected template appear in the left pane of the window.
- By default, the box next to each parameter in the template will be checked. If you do not wish to apply a particular parameter to the open tune, uncheck the box.
If you want to make changes to the values of the included parameters before application, they can be edited on the Preview tab. However, template changes made in this window cannot be saved.
Select the Apply Changes tab.
Click the
icon. VCM Editor will apply the parameters that can be applied. Success or failure of the application will appear below.
- If the application was successful, you should see no entries in the Failed or Not Found columns.
You can now save the tune with the template applied.
