Creating a New Template🔗
Follow these steps to create a template:
In VCM Editor's toolbar, select Tools > Tune Template Editor. The Template Editor window appears.
In the Template Editor toolbar, click
.a. A new, empty template opens in the editor.
Add parameters to the new template using one or more of the following toolbar icons:
Icon Description
Import parameters from an existing template. See Importing Another Template.
Select specific parameters from the currently loaded tune. See Adding Specific Parameters.
Import unsaved changes from the currently loaded tune. See Importing Unsaved Parameters.
When comparing two tune files, import the compare file version of parameters that differ from the main file. See Importing Compare File Differences. -
The imported parameters should now be displayed on the right side of the window. If desired, edit the values of the imported parameters.
Click
to save your changes.
