Importing Compare File Differences🔗
When editing a template in Template Editor, you can the parameters the differ between two tune files.
  1. If they're not already open, open the two tune files to compare:
    a. Open the first of the two files you wish to compare by selecting File > Open in the menu bar and then browsing for the file.
    b. Once the first file has been opened, select Compare > Open Compare File in the menu bar.
    c. Browse for and select the compare file.
  2. In the Template Editor window, click .
  • The parameters that differ will be imported from the compare file.
