Template Applicator🔗
The Template Applicator allows you to apply a saved set of parameter values to your currently loaded tune.
The parameters included in the template are selected in Template Editor, but you can edit the values of the parameters in this window before you apply them.
- To open this window, select Edit > Template Applicator in the toolbar.
Opening a Template File🔗
To open a saved template file, click the icon and browse for the template file that contains the parameters you want to apply.
The Parameter Tree🔗
When a template file is open, the parameters included in the template will be listed in the tree on the left side of the window. There are two things you can do with this list:
Parameters that have a check next to them will be applied to the current tune file. If you do not wish to apply a particular parameter, uncheck the box.
Select a parameter or group of parameters. The selected parameter(s) will be displayed in the Preview tab to the right.
Preview Tab🔗
The parameters selected in the tree to the left will be displayed on this tab. You can edit the values of the parameters here before you apply them to a tune. However, this process has the same limitations as editing parameters in the Template Editor window. See Editing Parameter Values for more information.
Apply Changes Tab🔗
Select this tab when you are ready to apply the template's parameters to the tune being configured.
Click the
icon to apply the parameters that are checked in the tree to the left. The results of the application process will be indicated in the space below:
Skipped: These are template parameters that were not checked.
Success: These template parameters applied OK.
Failed: The template parameter failed to apply. Error messages will be included describing the parameter and error.
Not Found: These are template parameters that do not exist in the currently loaded Tune.
