Table Editor Right-Click Menu🔗
Right clicking on a table in the table editor displays the following options:
Copy🔗
Copy a selected cell or section of the table to the clipboard.
Copy with Axis🔗
This function copies a selected cell or section of a table and includes the axis data. When used in conjunction with the Paste Special function, Copy With Axis allows the data to be pasted into another table without selecting the destination cell. Because the data was copied with axis labels, the software will automatically place the pasted data accordingly.
  • This is similar to the function in VCM Scanner's Graph panel and RTT Editor.
Paste🔗
Pastes a cell or table section into a selected cell. When pasting a copied region, the selected cell will become the top left cell in the pasted region.
Paste Special🔗
This function pastes data copied using the Copy With Axis feature into the current table.
The contents of the clipboard must be of the same dimensions as the contents of your table.
Function Description
Add Add the contents of the clipboard to the table.
Subtract Subtract the contents of the clipboard from the table.
Multiply % Multiply the contents of the table by the clipboard values as a percentage.
Multiply % - Half Multiply the contents of the table by the clipboard values as a percentage divided in half.
Average Average the values between the clipboard and the table.
Import from File🔗
Export the selected cells to a file. Data is saved in the .csv format.
Export to File🔗
Import a range of cells from a .csv file.
Column Axis🔗
Includes options to copy the labels from the column axis and edit the column axis, or change the units of the column axis.
Row Axis🔗
Includes options to copy the labels from the row axis and edit the row axis, or change the units of the row axis.
