Adding a Measurement List🔗
A measurement list is simply a list of measurements, displayed as a two-column table, with the signal name in the left column and the current output value of the signal in the right column.
To add a measurment list,
In the menu bar, select Layout > Add Control > Add Measurement > Add Measurement List. The below window will appear.
Add measurements to the list (see below for instructions).
When configuration is complete, Click Create Window.
Adding a Measurement To The List🔗
Click
- Step 1 is not necessary for the first measurement added. One unconfigured measurement is already present in a new list.
Search for the desried measurement.
Double-click on the measurement whose output you want to display.
Complete signal setup by configuring the signal's parameters.
Editing an Existing Measurment🔗
Select the name of the signal in the column on the left.
Modify the signal parameters displayed on the right.
Toolbar🔗
| Parameter | Description |
| Add a new measurement to the list. To complete signal setup, you must configure the signal's parameters. | |
| Delete the measurement selected in the left column. | |
| Duplicate the signal measurement selected in the column on the left. | |
Move the signal selected in the left column upwards in the list. |
Move the signal selected in the left column downwards in the list. |
