Time Graph Parameters🔗
When you select an individual signal (measurement) in the left column of Time Graph configuration window, the configurable properties for that signal appear to the right.
Parameter Description
Label The name of this signal. This will be displayed in the legend on the left side of the Time Graph subwindow.
Measurement Click this link to select the measurement whose output values will be charted.
Unit Once the Measurement is selected, use this dropdown to select the units for the graphed measurement. For example, speed could be in mph or km/h.
Decimals The number of decimal places displayed for this measurement on the Time Graph subwindow.
Min Value The minimum signal value that will be displayed in the graph. This value will correspond to the bottom edge of the graph. Values below this will be cut off.
Max Value The maximum signal value that will be displayed in the graph. This value will correspond to the top edge of the graph. Values above this will be cut off.
Color The signal's color in the Time Graph subwindow.
