Cuts-Out & Misses Diagnostics🔗
  • Cut-out and misses issues occur when the engine begins jerking that follows engine speed, usually pronounced as the engine load increases but normally felt below 2,000 RPM. The exhaust has a steady spitting sound at idle, low speed, or hard acceleration for the fuel starvation that can cause the engine to cut-out.
Checks Action
Preliminary Checks N/A
Ignition System Checks 1. Start the engine.
2. Check ignition for proper voltage output with a spark tester.
3. Check for any cylinder misfires.
4. Verify all spark plugs are gapped correctly.
Remove all spark plugs and check for the below conditions:
- Burned electrodes
- Any and all deposits
- Improper spark plug gaps
- Any and all wear and tear
Check the secondary ignition for the below conditions:
- Ignition wires for arcing and proper routing
- Ignition coils for any cracks and carbon tracking
- Cross-firing
Engine Mechanical Checks Perform a cylinder compression check for all cylinders. Check all cylinders for the following conditions:
- Worn rocker arms
- Worn camshaft lobes
- Broken valve springs
- Improper valve timing
- Improper valve clearance
Fuel System Checks Check the fuel system for the below conditions:
- Low pressure
- Plugged filters
Additional Checks Check the routing for the secondary wires and their ground circuits.
