Hesitation Diagnostics🔗
  • Hesitation is when the engine has a lack of response when putting it under load, this condition may cause the engine to stall if severe enough.
Checks Action
Preliminary Checks N/A
Fuel System Checks - Check the TMAP sensor response and accuracy
- Check fuel pump
Ignition System Checks - Check for proper ignition voltage output
- Check to see if the proper OEM spec spark plugs are being used and are gapped correctly
- Check for faulty spark plugs wires
- Check for fouled spark plugs
Additional Checks - Check for proper alternator voltage output
- Check for proper manifold vacuum
