DTC P0112 - Intake Air Temperature Sensor Circuit Low🔗
Conditions for Setting DTC P0112🔗
  • Intake Air Temperature Sensor ≤ 0.1 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P0112
Both the Terminated Gen III Drive-By-Cable & Gen IV Drive-By-Wire harnesses will have a 5 wire MAF that integrates with the IAT. Customers will have to purchase an adapter harness from EFI to split the 3 wire MAF sensor.
Step Action Value(s) YES NO
1 Key on, Engine running. Within VCM Live, open the IAT sensor DTC parameter, does the IAT sensor parameter display less than 0.1 volts? ≤ 0.1 volts Go to Step 2 Intermittent Issue - Refer to Intermittent Diagnostics
2 Key Off. Disconnect the IAT sensor connector from the wiring harness. Jump the IAT signal cavity "A". Key On. Does VCM Live display IAT voltage of 4.5 volts or greater? Go to Step 3 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
3 Inspect IAT connector and pins for corrosion, contamination or any physical damage. Any issues found? Repair any issues found and retest Go to Step 4
4 Key off. Disconnect the CORE connector "C". Check continuity between the IAT sensor connector signal cavity "E" and ECU IAT signal pin C4-9. Do you have continuity between them? Go to Step 5 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
5 Check for continuity between the IAT sensor connector 5 volt reference cavity "C" and ECU pin SP9. Do you have continuity between them? Go to Step 6 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
6 Check for continuity between the IAT sensor connector ground cavity "D" and ECU ground pin SP49. Do you have continuity between them? Go to Step 7 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
7 Replace IAT Sensor. Is the replacement of the IAT sensor complete? Go to Step 8
8 Clear any DTC from the ECU. Turn the ignition off and wait 30 seconds. Start the engine and operate the engine to full operating temperature. Observe the Check Engine Light on the Menu bar in VCM Live. After operating the engine within the test parameters, check for any stored codes. Does the engine operate without any stored DTCs? System is now operational and ready to be tuned Contact HP Tuners Support
