DTC P1522 - Oil Pressure Below Minimum Threshold🔗
Conditions for Setting DTC P1522🔗
- Engine Running
- Oil Pressure Sensor ≤ 0.0 psi
- The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1522
| 1 | - Use a mechanical oil pressure gauge to verify the oil pressure - Does the mechanical gauge read 0.0 psi or less? |
≤ 0.0 psi | Go to Step 2 | Intermittent Issue — - Refer to Intermittent Diagnostics |
| 2 | - Key ON - Disconnect the Oil Pressure sensor connector - With a DVOM check cavity 2 the 5 volt reference from the ECU - Do you have 4.5 volts from cavity 2? |
4.5 volts | Go to Step 4 | Go to Step 3 |
| 3 | - Disconnect the ECU connector "C" - With a DVOM check the 5 volt reference connector "C" pin 18 (for Drive-By-Cable harness) & Pin 41 (for Drive-By-Wire harness) - Do you have 5 volts coming from the ECU side? |
Repair faulty wiring between the ECU and Oil Pressure Sensor | Go to Step 4 | |
| 4 | - Replace the oil pressure sensor - Is the replacement complete? |
Go to Step 5 | N/A | |
| 5 | - Clear any DTC from the ECU - Turn the ignition off and wait 30 seconds - Start the engine and operate the engine to full operating temperature - Observe the Check Engine Light on the Menu bar in VCM Live - After operating the engine within the test parameters, check for any store codes - Does the engine operate without any stored DTCs? |
