No Start Diagnostics🔗
  • No start issues occur when the engine cranks but does not start.
Checks Action
Preliminary Checks N/A
ECU Checks - Check for proper communication with the ECU
- Check all fuses and relays for any damage
- Check battery power, ignition power and ground circuits to the ECU
Sensor Checks - Check the MAP sensor
- Check the cam sensor for proper RPM output
Fuel System Checks - Check the air intake components for any leakage
- Check for proper fuel pressure
Ignition System Checks - Check for proper ignition voltage output
- Check the spark plugs for proper gap, cracks, heavy deposits, wet plugs, wear, and ensure to also check the ignition wires
Engine Mechanical Checks Check for all of the below items:
- Vacuum leaks
- Improper valve timing
- Low compression
- Worn rocker arms
- Improper valve clearance
- Broken or weak valve springs
- Worn camshaft lobes
Exhaust System Checks Check for all of the below conditions:
- Inspect the exhaust system for damaged or collapsed pipes
- Check for plugged catalytic converter
