DTC P1363 - Fuel Pressure Above Maximum Threshold🔗
Conditions for Setting DTC P1363🔗
  • Fuel Pressure Sensor ≥ 2,900.75 psi
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1363
Step Action Value(s) YES NO
1 - Key ON, Engine Running
- Within VCM Live, open the Fuel Pressure sensor DTC Maximum parameter, does the Fuel Pressure sensor parameter display 2,900.75 psi or greater?
≥ 2,900.75 psi Go to Step 2 Intermittent Issue — - Refer to Intermittent Diagnostics
2 - Check the fuel pressure using a manual fuel pressure gauge
- Does the manual fuel pressure gauge read 2,900.75 psi or greater?
≥ 2,900.75 psi Go to Step 3 Go to Step 4
3 - Check the fuel pressure hoses for proper installation, routing, and blockages
- Any issues found?
Repair the hoses as necessary Go to Step 4
4 - Replace the fuel pressure sensor
Go to Step 5 N/A
5 - Clear any DTC from the ECU
