DTC P2228 - Barometric Pressure Sensor Circuit Low🔗
Conditions for Setting DTC P2228🔗
  • Barometric Pressure Sensor ≤ 0.1 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P2228
Step Action Value(s) YES NO
1 - Key on, Engine running
- Within VCM Live, open the Baro sensor DTC Minimum voltage parameter, does the Baro sensor parameter display 0.1 volts or less?
≤ 0.1 volts Go to Step 2 Intermittent Issue - Refer to Intermittent Diagnostics
2 - Key off
- Disconnect the CORE connector "C"
- Check continuity between the Baro sensor connector signal cavity 3 and ECU baro signal connector "C" pin 29
Go to Step 3 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
3 - Check for continuity between the baro sensor connector 5 volt reference cavity 2 and ECU splice SP6
- Do you have continuity?
4 - Check for continuity between the baro sensor connector low reference cavity 1 and ECU splice SP3
5 - Replace the baro sensor
Go to Step 6 N/A
6 - Clear any DTC from the ECU
