DTC P2132 - Acceleration Pedal Position 2 Sensor Circuit Low🔗
Conditions for Setting DTC P2132🔗
  • Acceleration Pedal Position 2 Sensor ≤ 0.1 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P2132
Step Action Value(s) YES NO
1 - Key ON, Engine OFF
- Within VCM Live, open the Accel Pedal 2 Sensor DTC Minimum parameter, does the Accel Pedal 2 sensor parameter display 0.1 volts or less?
≤ 0.1 volts Go to Step 2 Intermittent Issue - Refer to Intermittent Diagnostics
2 - Slowly increase the acceleration pedal while observing the Accel Pedal 2 sensor voltage
- Does the parameter ever display 0.1 volts or less?
≤ 0.1 volts Go to Step 3 Intermittent Issue — Refer to Intermittent Diagnostics (Page 41)
3 - Disconnect the APP sensor connector and the ECU connector "D"
- Check for continuity between the APP sensor connector cavity "B" and ECU connector "D" pin 20
4 - Disconnect the APP sensor connector and the ECU connector "C"
- Check for continuity between the APP sensor signal connector cavity "E" and ECU connector "C" pin 11
5 - Disconnect the APP sensor connector and the ECU connector "C" & "D"
- Check for continuity between both APP sensor 5 volt reference connector cavity "C" & "D" and ECU connector "C" pin 11 & Connector "D" pin 11
Go to Step 6 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
6 - Inspect all pins and terminals for any corrosion, physical damage, and contamination
- Any issues found?
Repair any pins or terminals that have been damaged. Go to Step 7
7 - Replace the ACC Pedal 2 Sensor
Go to Step 8 N/A
8 - Clear any DTC from the ECU
