DTC P0522 - Oil Pressure Sensor Circuit Low🔗
Conditions for Setting DTC P0522🔗
  • Oil Pressure Sensor ≤ 0.1 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P0522
Step Action Value (s) YES NO
1 - Key on, Engine running
- Within VCM Live, open the Oil Pressure sensor DTC parameter, does the Oil Pressure sensor parameter display 0.1 volts or less?
Go to Step 2 Intermittent Issue — Refer to Intermittent Diagnostics
2 - Key OFF
- Disconnect the Oil Pressure sensor connector & the Oil Pressure sensor ECU connector "C"
- Using a DVOM check for continuity between the oil pressure sensor signal connector cavity 3 (for Drive-By-Cable harness) cavity 1 (for Drive-By-Wire Harness) & the ECU connector "C" pin 19 (for Drive-By-Cable harness & Drive-By-Wire harnesses)
Go to Step 3 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
3 - Key OFF
- Using a DVOM check for continuity between the oil pressure sensor 5 volt reference connector cavity 2 (for Drive-By-Cable harness & Drive-By-Wire harnesses) & the ECU connector "C" pin SP6 (for Drive-By-Cable harness & Drive-By-Wire harnesses)
4 - Key OFF
- Using a DVOM check for continuity between the oil pressure sensor low reference connector cavity 1 (for Drive-By-Cable harness) cavity 3 (for Drive-By-Wire Harness) & the ECU connector "C" pin SP3 (for Drive-By-Cable harness & Drive-By-Wire harnesses)
5 - Replace Oil Pressure Sensor
Go to Step 6 N/A
6 - Clear any DTC from the ECU
