Adding a Gauge🔗
A gauge can be created to display value of any numerical stream of data provided by the ECU.
  1. In the menu bar, select Layout > Add Control > Add Measurement. A list of gauge types appears.
  2. Select the type of gauge to add: Dial Gauge, Bar Gauge or Value Gauge. A window showing the properties for the new gauge appears.
    New_Adding_Gauge_Window
    • The configurable properties in this window vary by type of gauge.
  3. Click the Measurement box. A list of signals appears.
    New_Measurement_Box
  4. Select the signal whose value you want the gauge to display.
  5. Click Add Selected Parameters.
  6. Configure the remaining parameters for the gauge.
  7. Click Create Window.
