DTC P0332 - Knock Bank 2 Sensor Circuit Low🔗
Conditions for Setting DTC P0332🔗
- Engine Running
- Knock Bank 2 Sensor ≤ 0.1 volts
- The above must be present for a period of 128 instances/cycles or greater to trigger DTC P0332
| Step | Action | Value (s) | YES | NO |
| 1 | - Key on, Engine running - Within VCM Live, open the knock sensor DTC parameter, does the knock sensor parameter display 0.1 volts or less? |
Go to Step 2 | Intermittent Issue — Refer to Intermittent Diagnostics | |
| 2 | - Key OFF - Disconnect the Knock 2 sensor connector and the ECU harness connector "D" - Using a DVOM check for continuity between the Knock 2 sensor signal cavity "A" (for Drive-By-Wire Harness) & the ECU connector "D" pin 8 (for Drive-By-Wire harnesses) - Do you have continuity between them? |
Go to Step 3 | Repair the circuit as necessary, locate any wires that need to be repaired or replaced | |
| 3 | - Key OFF - Disconnect the Knock 2 sensor connector and the ECU harness connector "D" - Using a DVOM check for continuity between the Knock 2 sensor low reference 2 cavity "B" (for Drive-By-Wire harness) & the ECU connector "D" pin SP3 (for both Drive-By-Wire harness) - Do you have continuity between them? |
| 4 | - Replace Knock 2 sensor - Is the replacement complete? |
Go to Step 5 | N/A | |
| 5 | - Clear any DTC from the ECU - Turn the ignition off and wait 30 seconds - Start the engine and operate the engine to full operating temperature - Observe the Check Engine Light on the Menu bar in VCM Live - After operating the engine within the test parameters, check for any stored codes - Does the engine operate without any stored DTCs? |
