DTC P0333 - Knock Bank 2 Sensor Circuit High🔗
Conditions for Setting DTC P0333🔗
  • Knock Bank 2 Sensor ≥ 4.9 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P0333
Step Action Value (s) YES NO
1 - Key on, Engine running
- Within VCM Live, open the knock sensor DTC parameter, does the knock sensor parameter display 4.9 volts or higher?
Go to Step 2 Intermittent Issue — Refer to Intermittent Diagnostics
2 - Key OFF
- Disconnect the Knock 2 sensor connector and the ECU harness connector "D"
- Using a DVOM check for continuity between the Knock 2 sensor signal cavity "A" (for Drive-By-Wire Harness) & the ECU connector "D" pin 8 (for Drive-By-Wire harnesses)
Go to Step 3 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
3 - Key OFF
- Using a DVOM check for continuity between the Knock 2 sensor low reference 2 cavity "B" (for Drive-By-Wire harness) & the ECU connector "D" pin SP3 (for both Drive-By-Wire harness)
4 - Replace Knock 2 sensor
Go to Step 5 N/A
5 - Clear any DTC from the ECU
