DTC P2122 - Throttle Position 2 Sensor Circuit Low🔗
Conditions for Setting DTC P2122🔗
- Engine Running
- Throttle Position 2 Sensor ≤ 0.1 volts
- The above must be present for a period of 128 instances/cycles or greater to trigger DTC P2122
| 1 | - Key ON, Engine OFF - Within VCM Live, open the TPS 2 DTC Minimum parameter, does the TPS sensor parameter display 0.1 volts or less? |
Go to Step 3 | Go to Step 2 | |
| 2 | - Slowly depress the foot pedal while observing the TPS voltage parameter within VCM Live - Does the TPS voltage ever fall below 0.2 volts? |
Go to Step 3 | Intermittent Issue - Refer to Intermittent Diagnostics | |
| 3 | - Key OFF - Disconnect the TPS connector and jump the 5 volt reference cavity 1 & the TPS signal cavity 3 together at the TPS connector - Key ON - Does the TPS parameter within VCM Live display a voltage of 4.0 volts or greater? |
Go to Step 6 | Go to Step 4 | |
| 4 | - Key OFF - Disconnect the ECU harness connector "C" - Using a DVOM check continuity between the TPS connector signal cavity 3 & the ECU connector "C" pin 25 - Do you have continuity between them? |
Go to Step 5 | Repair the circuit as necessary, locate any wires that need to be repaired or replaced | |
| 5 | - Replace the ECU - Is the replacement complete? |
Go to Step 8 | N/A | |
| 6 | - Inspect the TPS wire harness connector terminals for corrosion or contamination - Any issues found? |
Repair the circuit as necessary and fix any pins with corrosion or contamination | Go to Step 7 | |
| 7 | - Replace the TPS - Is the replacement complete? |
| 8 | - Clear any DTC from the ECU - Turn the ignition off and wait 30 seconds - Start the engine and operate the engine to full operating temperature - Observe the Check Engine Light on the Menu bar in VCM Live - After operating the engine within the test parameters, check for any store codes - Does the engine operate without any stored DTCs? |
