DTC P1843 - Transmission Line Pressure Above Maximum Threshold🔗
Conditions for Setting DTC P1843🔗
  • Transmission Line Pressure Sensor ≥ 14.69 psi
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1843
Step Action Value(s) YES NO
1 - Key on, Engine running
- Within VCM Live, open the Trans Pressure Sensor DTC Maximum parameter, does the Trans pressure sensor parameter display 14.69 psi or greater?
≥ 14.69 psi Go to Step 2 Intermittent Issue - Refer to Intermittent Diagnostics
2 - Disconnect the trans line pressure sensor connector and the sub harness connector
- With a DVOM check for continuity between the trans pressure control solenoid valve pin 3 & cavity "C"
Go to Step 3 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
3 - Disconnect the trans line pressure sensor connector and the sub harness connector
- With a DVOM check for continuity between the trans line pressure low reference pin 12 & cavity "D"
4 - Inspect the Trans Line Pressure Sensor connector and pins for corrosion, contamination or any physical damage.
- Any issues found?
Repair any issues found and retest. Go to Step 5
5 - Replace the Trans Pressure Sensor
Go to Step 6 N/A
6 - Clear any DTC from the ECU
