DTC P0562 - Battery Voltage Low🔗
Conditions for Setting DTC P0562🔗
  • Ignition On
  • Battery Voltage Sensor ≤ 9.0 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P0562
Step Action Value (s) YES NO
1 - Key on, Engine running
- Within VCM Live, open the Battery Voltage Sensor DTC minimum parameter characteristic, does the parameter display 9.0 volts or less?
Go to Step 2 Intermittent Issue — Refer to Intermittent Diagnostics
2 - Check the condition of the battery and battery terminals for any corrosion, physical damage, or contamination
- Any issues found?
Replace battery or battery terminals Go to Step 3
3 - Check the charging system for any corrosion, physical damage, or contamination
- Any issues found?
Replace the charging system Go to Step 4
4 - Check all of the below ECU ground by using a DVOM and measuring voltage between each of the below pins and battery positive
1. ECU Connector "A" pin 26
2. ECU Connector "A" pin 34
3. ECU Connector "B" pin 20
4. ECU Connector "B" pin 26
5. ECU Connector "C" pin 10
6. ECU Connector "D" pin 26
- Any issues found?
Repair the circuit as necessary, locate any wires that need to be repaired or replaced Go to Step 5
5 - Replace ECU
Go to Step 6 N/A
6 - Clear any DTC from the ECU
