DTC P1107 - Manifold Absolute Pressure Below Minimum Threshold🔗
Conditions for Setting DTC P1107🔗
  • Manifold Absolute Pressure Sensor ≤ 0.73 psi
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1107
Step Action Value (s) YES NO
1 - Key ON, Engine Running at full operating temperature
- Within VCM Live, open the MAP sensor DTC Minimum parameter, does the MAP sensor parameter display 0.73 psi or less?
Go to Step 2 Intermittent Issue — Refer to Intermittent Diagnostics
2 - Key OFF
- Disconnect the MAP sensor connector
- Key ON
- Does the MAP sensor parameter within VCM Live display less than 0.5 psi?
Go to Step 3 Go to Step 5
3 - Probe the MAP ground connector cavity "A" (for Drive-By-Cable harness) cavity 2 (for Drive-By-Wire harness) with a test light connected to battery voltage
- Does the test light come on?
Go to Step 4 Go to Step 6
4 - Check the MAP mechanical vacuum connection for correct mounting or any possible physical damage that may cause leakage
- Any issues found?
Go to Step 5 Repair any issues found
5 - Key OFF
- Disconnect the ECU connector "C" and inspect the terminals for any physical damage or corrosion and contamination
- Any issues found?
Go to Step 6 Repair the pins as necessary and circuit
6 - Replace the MAP sensor
- Is the repair complete?
Go to Step 7 N/A
7 - Clear any DTC from the ECU
