DTC P1713 - Transmission Oil Temperature Above Maximum Threshold🔗
Conditions for Setting DTC P1713🔗
- Engine Running
- Transmission Oil Temperature Sensor ≥ 302 °F
- The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1713
| 1 | - Key on, Engine running - Within VCM Live, open the Trans Temp sensor DTC Maximum parameter, does the Trans Temp sensor parameter display 302 °F or greater? |
≥ 302 °F | Go to Step 2 | Intermittent Issue - Refer to Intermittent Diagnostics |
| 2 | - Disconnect the trans Oil Temp sensor connector and the sub harness connector - With a DVOM check for continuity between the trans fluid temp signal pin 1 & cavity "L" |
Go to Step 3 | Repair the circuit as necessary, locate any wires that need to be repaired or replaced | |
| 3 | - Disconnect the trans Oil Temp sensor connector and the sub harness connector - With a DVOM check for continuity between the trans fluid temp low reference pin 12 & cavity "M" |
| 4 | - Inspect the Trans Temp Sensor connector and pins for corrosion, contamination or any physical damage. - Any issues found? |
Repair any issues found and retest. | Go to Step 5 | |
| 5 | - Replace the Trans Temp Sensor - Is the replacement complete? |
Go to Step 6 | N/A | |
| 6 | - Clear any DTC from the ECU - Turn the ignition off and wait 30 seconds - Start the engine and operate the engine to full operating temperature - Observe the Check Engine Light on the Menu bar in VCM Live - After operating the engine within the test parameters, check for any store codes - Does the engine operate without any stored DTCs? |
