DTC P1102 - Mass Airflow Below Minimum Threshold🔗
Conditions for Setting DTC P1102🔗
  • Mass Airflow Sensor ≤ 0.00 lb/min
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1102
Step Action Value (s) YES NO
1 - Key ON, Engine running at full operating temperature
- Within VCM Live, open the MAF sensor DTC Minimum parameter, does the MAF sensor parameter display less than 0.00 lb/min?
Go to Step 2 Intermittent Issue — Refer to Intermittent Diagnostics
2 - Key OFF
- Disconnect the MAF sensor
- Key ON
- Does the MAF sensor parameter within VCM Live display pressure less than 0.05 lb/min?
Go to Step 3 Go to Step 5
3 - Probe the MAF connector ground cavity "B" with a test light connected to battery voltage
- Does the test light come on?
Go to Step 4 Go to Step 7
4 - Check the location of the MAF, ensure the location is free from physical damage or any and all debris that can cause restriction of airflow
- Is the MAF sensor location area OK?
Go to Step 5 Repair the location that has physical damage and clean any debris that was found
5 - Key OFF
- Disconnect the ECU connector "B" and inspect the pins for any physical damage or corrosion
- Are the pins OK?
Go to Step 6 Repair the circuit and pins as necessary, locate any wires that need to be repaired or replaced
6 - Replace the MAF sensor
Go to Step 8 N/A
7 - Disconnect the ECU connector "B" and check for continuity between the MAF sensor connector ground cavity "B" & ECU ground pin SP4
Go to Step 8 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
8 - Clear any DTC from the ECU
