DTC P2109 - Electronic Throttle Override🔗
Conditions for Setting DTC P2109🔗
- Engine Running
- Parameter "Electronic Throttle Override Enabled" set to "Yes"
- The above must be present for a period of 128 instances/cycles or greater to trigger DTC P2109
Caution
When parameter "Electronic Throttle Override Enabled" is set to "Yes", the vehicles fuel & spark will be shut down.
