DTC P2123 - Throttle Position 2 Sensor Circuit High🔗
Conditions for Setting DTC P2123🔗
  • Throttle Position 2 Sensor ≥ 4.9 volts
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P2123
Step Action Value(s) YES NO
1 - Key ON, Engine OFF
- Within VCM Live, open the TPS 2 DTC Maximum parameter, does the TPS sensor parameter display 0.1 volts or less?
Go to Step 3 Go to Step 2
2 - Slowly depress the foot pedal while observing the TPS voltage parameter within VCM Live
- Does the TPS voltage ever fall below 0.2 volts?
Go to Step 3 Intermittent Issue - Refer to Intermittent Diagnostics
3 - Key OFF
- Disconnect the TPS connector and jump the 5 volt reference cavity 1 & the TPS signal cavity 3 together at the TPS connector
- Key ON
- Does the TPS parameter within VCM Live display a voltage of 4.0 volts or greater?
Go to Step 6 Go to Step 4
4 - Key OFF
- Disconnect the ECU harness connector "C"
- Using a DVOM check continuity between the TPS connector signal cavity 3 & the ECU connector "C" pin 25
5 - Replace the ECU
Go to Step 8 N/A
6 - Inspect the TPS wire harness connector terminals for corrosion or contamination
- Any issues found?
Repair the circuit as necessary and fix any pins with corrosion or contamination Go to Step 7
7 - Replace the TPS
Go to Step 8 N/A
8 - Clear any DTC from the ECU
