CORE ECU DTC List🔗
| DTC Code | Description |
VCM Live Parameter (below are both characteristic and measurement parameters) |
| P0102 | Mass Airflow Sensor Circuit Low | Mass Airflow (MAF) Sensor DTC Minimum Frequency |
| P0103 | Mass Airflow Sensor Circuit High | Mass Airflow (MAF) Sensor DTC Maximum Frequency |
| P0107 | Manifold Absolute Pressure Sensor Circuit Low | Manifold Absolute Pressure (MAP) Sensor DTC Minimum Voltage |
| P0108 | Manifold Absolute Pressure Sensor Circuit High | Manifold Absolute Pressure (MAP) Sensor DTC Maximum Voltage |
| P0112 | Intake Air Temperature Sensor Circuit Low | Intake Air Temperature (IAT) Sensor DTC Minimum Voltage |
| P0113 | Intake Air Temperature Sensor Circuit High | Intake Air Temperature (IAT) Sensor DTC Maximum Voltage |
| P0117 | Engine Coolant Temperature Sensor Circuit Low | Engine Coolant Temperature (ECT) Sensor DTC Minimum Voltage |
| P0118 | Engine Coolant Temperature Sensor Circuit High | Engine Coolant Temperature (ECT) Sensor DTC Maximum Voltage |
| P0130 | Lambda Bank 1 Sensor 1 Circuit Failure | Lambda Sensor 1 DTC Status |
| P0131 | Lambda Bank 1 Sensor 1 Circuit Low | Lambda Sensor DTC Minimum Voltage |
| P0132 | Lambda Bank 1 Sensor 1 Circuit High | Lambda Sensor DTC Maximum Voltage |
| P0134 | Lambda 1 Sensor Heater Status Not Ok | Lambda Sensor 1 Heater Status Ok |
| P0135 | Lambda 1 Sensor Heater Timed Out | Lambda Sensor 1 DTC Status |
| P0150 | Lambda Bank 2 Sensor 1 Circuit Failure | Lambda Sensor DTC Minimum Voltage |
| P0151 | Lambda Bank 2 Sensor 1 Circuit Low | Lambda Sensor DTC Minimum Voltage |
| P0152 | Lambda Bank 2 Sensor 1 Circuit High | Lambda Sensor DTC Maximum Voltage |
| P0154 | Lambda 2 Sensor Heater Status Not Ok | Lambda Sensor 2 Heater Status Ok |
| P0155 | Lambda 2 Sensor Heater Timed Out | Lambda Sensor 2 DTC Status |
| P0178 | Flex Fuel Composition Sensor Circuit Low | Flex Fuel Sensor DTC Minimum Frequency |
| P0179 | Flex Fuel Composition Sensor Circuit High | Flex Fuel Sensor DTC Maximum Frequency |
| P0227 | Throttle Position 1 Sensor Circuit Low | Throttle Position 1 Sensor (TPS 1) DTC Minimum Voltage |
| P0228 | Throttle Position 1 Sensor Circuit High | Throttle Position 1 Sensor (TPS 1) DTC Maximum Voltage |
| P0327 | Knock Bank 1 Sensor Circuit Low | Knock Bank 1 Sensor DTC Minimum Voltage |
| P0328 | Knock Bank 1 Sensor Circuit High | Knock Bank 1 Sensor DTC Maximum Voltage |
| P0332 | Knock Bank 2 Sensor Circuit Low | Knock Bank 2 Sensor DTC Minimum Voltage |
| P0333 | Knock Bank 2 Sensor Circuit High | Knock Bank 2 Sensor DTC Maximum Voltage |
| P0511 | Idle Air Control Circuit Failure | Idle Air Control Valve Fault |
| P0522 | Oil Pressure Sensor Circuit Low | Oil Pressure Sensor DTC Minimum Voltage |
| P0523 | Oil Pressure Sensor Circuit High | Oil Pressure Sensor DTC Maximum Voltage |
| P0532 | Air Conditioner Refrigerant Pressure Sensor Circuit Low | Air Conditioner (AC) Refrigerant Pressure Sensor DTC Minimum Voltage |
| P0533 | Air Conditioner Refrigerant Pressure Sensor Circuit High | Air Conditioner (AC) Refrigerant Pressure Sensor DTC Maximum Voltage |
| P0537 | Air Conditioner Refrigerant Temperature Sensor Circuit Low | Air Conditioner (AC) Refrigerant Temperature Sensor DTC Minimum Voltage |
| P0538 | Air Conditioner Refrigerant Temperature Sensor Circuit High | Air Conditioner (AC) Refrigerant Temperature Sensor DTC Maximum Voltage |
| P0562 | Battery Voltage Low | Battery Voltage Sensor DTC Minimum |
| P0563 | Battery Voltage High | Battery Voltage Sensor DTC Maximum |
| P0570 | Front Brake Pressure Below Minimum Threshold | Front Brake Pressure Sensor DTC Minimum |
| P0571 | Front Brake Pressure Above Maximum Threshold | Front Brake Pressure Sensor DTC Maximum |
| P0572 | Front Brake Pressure Sensor Circuit Low | Front Brake Pressure Sensor DTC Minimum Voltage |
| P0573 | Front Brake Pressure Sensor Circuit High | Front Brake Pressure Sensor DTC Maximum Voltage |
| P0668 | Internal Thermistor (ECU) Temperature Below Minimum Threshold | Internal Thermistor Temperature Sensor DTC Minimum |
| P0669 | Internal Thermistor (ECU) Temperature Above Maximum Threshold | Internal Thermistor Temperature Sensor DTC Maximum |
| P06B1 | Power Supply 5V Sensor 1 Status Not Ok | Power Supply 5v Sensor 1 Status Ok |
| P06B4 | Power Supply 5V Sensor 2 Status Not Ok | Power Supply 5v Sensor 2 Status Ok |
| P0712 | Transmission Oil Temperature Sensor Circuit Low | Transmission Oil Temperature (Trans Temp) Sensor DTC Minimum Voltage |
| P0713 | Transmission Oil Temperature Sensor Circuit High | Transmission Oil Temperature (Trans Temp) Sensor DTC Maximum Voltage |
| P0719 | Rear Brake Pressure Below Minimum Threshold | Rear Brake Pressure Sensor DTC Minimum |
| P0720 | Rear Brake Pressure Above Maximum Threshold | Rear Brake Pressure Sensor DTC Maximum |
| P0721 | Rear Brake Pressure Sensor Circuit Low | Rear Brake Pressure Sensor DTC Minimum Voltage |
| P0722 | Rear Brake Pressure Sensor Circuit High | Rear Brake Pressure Sensor DTC Maximum Voltage |
| P0842 | Transmission Line Pressure Sensor Circuit Low | Transmission Line Pressure Sensor DTC Minimum Voltage |
| P0843 | Transmission Line Pressure Sensor Circuit High | Transmission Line Pressure Sensor DTC Maximum Voltage |
| P1102 | Mass Airflow Below Minimum Threshold | Mass Airflow (MAF) Sensor DTC Minimum |
| P1103 | Mass Airflow Above Maximum Threshold | Mass Airflow (MAF) Sensor DTC Maximum |
| P1107 | Manifold Absolute Pressure Below Minimum Threshold | Manifold Absolute Pressure (MAP) Sensor DTC Minimum |
| P1108 | Manifold Absolute Pressure Above Maximum Threshold | Manifold Absolute Pressure (MAP) Sensor DTC Maximum |
| P1112 | Intake Air Temperature Below Minimum Threshold | Intake Air Temperature (IAT) Sensor DTC Minimum |
| P1113 | Intake Air Temperature Above Maximum Threshold | Intake Air Temperature (IAT) Sensor DTC Maximum |
| P1117 | Engine Coolant Temperature Below Minimum Threshold | Engine Coolant Temperature (ECT) Sensor DTC Minimum |
| P1118 | Engine Coolant Temperature Above Maximum Threshold | Engine Coolant Temperature (ECT) Sensor DTC Maximum |
| P1122 | Throttle Position 2 Below Minimum Threshold | Throttle Position 2 Sensor (TPS 2) DTC Minimum |
| P1123 | Throttle Position 2 Above Maximum Threshold | Throttle Position 2 Sensor (TPS 2) DTC Maximum |
| P1127 | Acceleration Pedal 1 Sensor Circuit Low | Acceleration Pedal Position 1 Sensor DTC Minimum Voltage |
| P1128 | Acceleration Pedal 1 Sensor Circuit High | Acceleration Pedal Position 1 Sensor DTC Maximum Voltage |
| P1129 | Acceleration Pedal 2 Below Minimum Threshold | Acceleration Pedal Position 2 Sensor DTC Minimum |
| P1130 | Acceleration Pedal 2 Above Maximum Threshold | Acceleration Pedal Position 2 Sensor DTC Maximum |
| P1131 | Lambda Bank 1 Sensor 1 Below Minimum Threshold | Lambda Sensor DTC Minimum |
| P1132 | Lambda Bank 1 Sensor 1 Above Maximum Threshold | Lambda Sensor DTC Maximum |
| P1151 | Lambda Bank 2 Sensor 1 Below Minimum Threshold | Lambda Sensor DTC Minimum |
| P1152 | Lambda Bank 2 Sensor 1 Above Maximum Threshold | Lambda Sensor DTC Maximum |
| P1178 | Flex Fuel Composition Below Minimum Threshold | Flex Fuel Composition Sensor DTC Minimum |
| P1179 | Flex Fuel Composition Above Maximum Threshold | Flex Fuel Composition Sensor DTC Maximum |
| P1226 | Throttle Position 1 Above Maximum Threshold | Throttle Position 1 Sensor (TPS 1) DTC Maximum |
| P1227 | Throttle Position 1 Below Minimum Threshold | Throttle Position 1 Sensor (TPS 1) DTC Minimum |
| P1228 | Barometric Pressure Below Minimum Threshold | Barometric Pressure (Baro) Sensor DTC Minimum |
| P1229 | Barometric Pressure Above Maximum Threshold | Barometric Pressure (Baro) Sensor DTC Maximum |
| P1347 | Nitrous Pressure Sensor Circuit Low | Nitrous Pressure (NOS) Sensor DTC Minimum Voltage |
| P1348 | Nitrous Pressure Sensor Circuit High | Nitrous Pressure (NOS) Sensor DTC Maximum Voltage |
| P1350 | Dome (Co²) Pressure Below Minimum Threshold | Dome Pressure Sensor DTC Minimum |
| P1351 | Dome (Co²) Pressure Above Maximum Threshold | Dome Pressure Sensor DTC Maximum |
| P1360 | Dome (Co²) Pressure Sensor Circuit Low | Dome Pressure Sensor DTC Minimum Voltage |
| P1361 | Dome (Co²) Pressure Sensor Circuit High | Dome Pressure Sensor DTC Maximum Voltage |
| P1362 | Fuel Pressure Below Minimum Threshold | Fuel Pressure Sensor DTC Minimum |
| P1363 | Fuel Pressure Above Maximum Threshold | Fuel Pressure Sensor DTC Maximum |
| P1364 | Fuel Pressure Sensor Circuit Low | Fuel Pressure Sensor DTC Minimum Voltage |
| P1365 | Fuel Pressure Sensor Circuit High | Fuel Pressure Sensor DTC Maximum Voltage |
| P1366 | Nitrous Pressure Below Minimum Threshold | Nitrous Pressure (NOS) Sensor DTC Minimum |
| P1367 | Nitrous Pressure Above Maximum Threshold | Nitrous Pressure (NOS) Sensor DTC Maximum |
| P1522 | Oil Pressure Below Minimum Threshold | Oil Pressure Sensor DTC Minimum |
| P1523 | Oil Pressure Above Maximum Threshold | Oil Pressure Sensor DTC Maximum |
| P1532 | Air Conditioner Refrigerant Pressure Below Minimum Threshold | Air Conditioner (AC) Refrigerant Pressure Sensor DTC Minimum |
| P1533 | Air Conditioner Refrigerant Pressure Above Maximum Threshold | Air Conditioner (AC) Refrigerant Pressure Sensor DTC Maximum |
| P1537 | Air Conditioner Refrigerant Temperature Below Minimum Threshold | Air Conditioner (AC) Refrigerant Temperature Sensor DTC Minimum |
| P1538 | Air Conditioner Refrigerant Temperature Above Maximum Threshold | Air Conditioner (AC) Refrigerant Temperature Sensor DTC Maximum |
| P1712 | Transmission Oil Temperature Below Minimum Threshold | Transmission Oil Temperature (Trans Temp) Sensor DTC Minimum |
| P1713 | Transmission Oil Temperature Above Maximum Threshold | Transmission Oil Temperature (Trans Temp) Sensor DTC Maximum |
| P1842 | Transmission Line Pressure Below Minimum Threshold | Transmission Line Pressure (Trans Pr) Sensor DTC Minimum |
| P1843 | Transmission Line Pressure Above Maximum Threshold | Transmission Line Pressure (Trans Pr) Sensor DTC Maximum |
| P2109 | Electronic Throttle Override | Electronic Throttle Override Enabled |
| P2122 | Throttle Position 2 Sensor Circuit Low | Throttle Position 2 Sensor (TPS 2) DTC Minimum Voltage |
| P2123 | Throttle Position 2 Sensor Circuit High | Throttle Position 2 Sensor (TPS 2) DTC Maximum Voltage |
| P2129 | Acceleration Pedal 1 Below Minimum Threshold | Acceleration Pedal Position 1 (Accel Pedal 1) Sensor DTC Minimum |
| P2130 | Acceleration Pedal 1 Above Maximum Threshold | Acceleration Pedal Position 1 (Accel Pedal 1) Sensor DTC Maximum |
| P2132 | Acceleration Pedal Position 2 Sensor Circuit Low | Acceleration Pedal Position 2 (Accel Pedal 2) Sensor DTC Minimum Voltage |
| P2133 | Acceleration Pedal Position 2 Sensor Circuit High | Acceleration Pedal Position 2 (Accel Pedal 2) Sensor DTC Maximum Voltage |
| P2228 | Barometric Pressure Sensor Circuit Low | Barometric Pressure (Baro) Sensor DTC Minimum Voltage |
| P2229 | Barometric Pressure Sensor Circuit High | Barometric Pressure (Baro) Sensor DTC Maximum Voltage |
