DTC P1228 - Barometric Pressure Below Minimum Threshold🔗
Conditions for Setting DTC P1228🔗
  • Barometric Pressure Sensor ≤ 1.51 psi
  • The above must be present for a period of 128 instances/cycles or greater to trigger DTC P1228
Step Action Value(s) YES NO
1 - Key on, Engine running
- Within VCM Live, open the Baro sensor DTC Minimum parameter, does the Baro sensor parameter display 1.51 psi or less?
≤ 1.51 psi Go to Step 2 Intermittent Issue - Refer to Intermittent Diagnostics
2 - Disconnect the Baro pressure sensor connector and ECU connector "C"
- Check for continuity between Baro pressure sensor low reference cavity 1 and ECU connector SP3
- Do you have continuity?
Go to Step 3 Repair the circuit as necessary, locate any wires that need to be repaired or replaced
3 - Disconnect the Baro pressure sensor connector and ECU connector "C"
- Check for continuity between Baro pressure sensor 5 volt reference cavity 2 and ECU connector SP6
4 - Disconnect the Baro pressure sensor connector and ECU connector "C"
- Check for continuity between Baro pressure sensor signal cavity 3 and ECU connector "C" pin 29
5 - Disconnect the Baro pressure sensor connector and ECU connector "C"
- Check for any physical damage, corrosion, or contamination of any of the pins
- Any issues found?
Repair any pins and circuit as necessary. Go to Step 6
6 - Replace the Baro Pressure Sensor
Go to Step 7 N/A
7 - Clear any DTC from the ECU
