Viewing Your Session Data🔗
  1. Tap on the icon.
  2. Tap the session you want to view.
    swipe left to delete any session.
  3. Once a session is open you can tap Detail to view that sessions recorded data.
    • 0–60 MPH, 0–100 MPH, and similar metrics are displayed when acceleration begins from a standstill at the start of the session, as is typical in Drag Race and some Segment recordings.
    • Theoretical Best Lap and Best Sector Times are displayed for Circuit recordings where sector split points are defined and multiple complete laps have been recorded.
    • Sector Times are displayed below each Lap (Circuit) or Run (Segment & Trail) when sector split points are defined for the track.
    • Drag Race recordings display the completed run time for the selected track length, along with each timing split and trap speed (330', 1/8 mile, 1000', 1/4 mile, etc.).
    0.000 Sector Time
    • A 0.000 sector time typically indicates that a sector split trigger was missed, which can indicate a GPS problem, an incorrect sector split point for the course configuration, or that the sector split points were driven in reverse order or out of order.
    • The fastest sector times of the session will be displayed in bold or underlined text.
  4. Tap either of the three options on the bottom of the screen.
    • VIDEO: Allows users to replay the video and any associated data.
    • SHARE: Allows users to share their recorded data
    • FILE: Allows users to rename, move, or delete the session or video.
